The much anticipated update to Vyzex PocketPOD is now officially released!
This version operates differently to the previous v1.05 version: It is a DIRECT mode editor that writes directly into your PocketPOD user bank whenever you store a preset. First timers will find this a lot easier to understand, and old pros will appreciate how easier the program is to use.
Also, we've reduced the height of the editor window by at least 25 pixels which should eliminate the window clipping that some users with smaller displays have reported in the earlier versions.
Don't forget to read through the new 'Vyzex PocketPOD Pilot's Guide' PDF, which replaces the old user's guide, Quick Start and Tone Managment documents.
To get your copy now, visit http://www.line6.com/software/ and select 'PocketPOD' as the product, 'Vyzex Editor' as the software, and your OS choice (WinXP, Vista or OSX), then hit the GO button.
NOTE: Windows 2000 and Mac OS 10.3.x are not supported by Vyzex PocketPOD. It's time to upgrade your OS!
Expiring the announcement will not delete it but will remove it from the public announcement list. Are you sure you want to expire this announcement?
Are you sure you want to delete this announcement?
