US
8 Replies Last post: Jun 18, 2009 12:26 PM by geekocaster
geekocaster   5 posts since
Mar 17, 2007
Jun 17, 2009 3:24 PM
FBV wah sweep not working
I have just upgraded from the FBV Short board to the FBV longboard, and the wah function on the longboard will not 'sweep'  when I kick it on i hear the wah model on but i cannot control it.
the wah models on the short board work no problem.
I purchased the FBV Longboard from American musical, and wanted to make sure it wasn't a user error before i send the pedal back for a refund.
bentele Juststartin' 30 posts since
Jan 25, 2007
1. Jun 18, 2009 1:23 AM in response to: geekocaster
Re: FBV wah sweep not working
Hi
Does the light turn on when you engage the Wah?  When these boards are new it can take quite a bit of pressure to turn on the pedal.  Also check the pedal assignment in the vetta itself.  The Wah could be assigned a different function.  The easiest way is with Line6 Edit but you can check it right on the vetta.
Hope this helps
Ben
jvblack Juststartin' 90 posts since
Oct 20, 2007
2. Jun 18, 2009 9:22 AM in response to: bentele
bentele wrote:
...The easiest way is with Line6 Edit ...
Hope this helps
Ben
True.  If you open the window for the pedals, you can actually see the knob moving in edit when you sweep the pedal if it's working correctly.
ALSO, it might be worth calibrating the pedal if it's new.  There's a link to the instructions for doing that in this thread:
http://line6.com/community/message/3762
Good Luck,
Joe
Oct 20, 2007
4. Jun 18, 2009 11:04 AM in response to: geekocaster
Did you try a different Cat5 cable?
You shouldn't have any problem with getting a replacement from AMS if it turns out to be a bad unit.
Joe
Jan 25, 2007
7. Jun 18, 2009 12:24 PM in response to: geekocaster
Glad to hear it was simple and all sorted out.
Enjoy
Ben
