US
39 Replies Last post: Oct 3, 2009 10:48 PM by kprchrm   1 2 3 Previous Next
Slingy Juststartin' 250 posts since
Jan 25, 2007
Sep 10, 2009 12:02 AM
Free Pod Farm Plug In
Anyone see this yet? Now through Sep 30th Podfarm VST is free for all Line6 account users for Line6 devices or Ilok. Pretty cool if you ask me, though I already have Pod Studio UX2 with the plug in.
http://line6.com/news/offers/864
DoctorWu   194 posts since
Jan 27, 2007
1. Sep 10, 2009 7:40 AM in response to: Slingy
Re: Free Pod Farm Plug In
Yes.  I quickly took advantage of that offer.  You can't beat free.  I'd purchased a Toneport back before the Pod Farm plugin was included so I didn't have it.  I've tested the plugin with Sonar and it works great.  Thank you Line 6!
dingavinga   19 posts since
Feb 4, 2007
2. Sep 13, 2009 3:31 AM in response to: Slingy
Excellent offer! Thank-you Line 6!
Apologist Juststartin' 306 posts since
Jan 24, 2007
3. Sep 13, 2009 12:33 PM in response to: Slingy
Yes think you line 6 though I haven't figured out quite how to use this free stuff quite yet with just my Podxtl ... I will figure it out eventually.
cgtrox Iknowathingortwo 1,079 posts since
Jan 25, 2007
4. Sep 13, 2009 8:58 PM in response to: Slingy
Thanks Line 6!!! I'm guessing it only works for Line 6 gear that does NOT already have the model packs? Is there a way I can just download Ampfarm directly into my computer? Do I have to use an iLok???
cgtrox
dasvox Juststartin' 186 posts since
Jan 29, 2007
5. Sep 13, 2009 7:58 PM in response to: Apologist
I'm having the same problem. Any help would be appreciated if you have any breakthroughs. I'll hit you up if I get there myself.
bumpyroad   281 posts since
Jan 25, 2007
6. Sep 13, 2009 10:21 PM in response to: dasvox
A quick rundown on the plugin.
When you install Pod Farm - it installs the vst plugin in your default plugins folder if you have one if you tell it to - or else it installs it in a Line folder. Search for Pod Farm.dll and you'll find it. You can either copy it to your regular plugins folder - or point your recording software to the folder the dll is in.
When you download the free vst - you have to authorize it with monkey over the internet with the addons tab.
The Pod Farm plugin is like Guitar Rig, Amplitube etc. and only works as a vst plugin in your recording software.
Whatever model packs you have on the device will also be in the plugin. Buying more model packs for the device will also make them available in the plugin.
You "insert" in on an audio track.
For Pods - you have to use the dry sends (7 and 8 stereo) and you will be recording a dry track. You can monitor the Pod - or you can monitor the plugin according to the preset you have chosen. You are recording over usb - not the other outputs. So you select the Pod in the software if you normally use a different sound card.
For Toneports - you record the 1 and 2 input and monitor the plugin - or sends 3/4 which are dry - and monitor the Toneport. Leaving the Pod Farm and Gearbox standalones closed - will send the dry signal over sends 1 and 2.
If you monitor the device - you will be recording something different which sounds like the tuner (dry) unless you select a preset in the plugin which is the same as the settings on the Pod. But either way - the track will always be dry and gets processed by the plugin in real time. It's only when you mix it down that the tone becomes permanent.
I always monitor the plugin when I record - then turn off the monitor button when I'm done. Then I can change the presets all I want - without harming the recording. Cubase has a button for that.
I also record two tracks at a time with as many as 4 amps in total - then mix them up and experiment with the fx to see what it sounds like. It's great for satisfying your curiousity about "what if I had more or less of this or that?"
Ampfarm is a Protools thing supported by Digidesign - not Line 6.
stumpsout Juststartin' 519 posts since
Jan 28, 2007
7. Sep 13, 2009 10:52 PM in response to: Slingy
I already had it free with my X3L, but didn't have it for my Toneport KB37....which kinda sucked...and I didn't want to cough up another 100 US bucks.
So THANKS Line 6!
Jan 29, 2007
8. Sep 13, 2009 11:21 PM in response to: bumpyroad
Thanks. I couldn't find it in my Reaper VST list. I'll tomorrow to find where it is.
Jan 27, 2007
9. Sep 14, 2009 7:49 AM in response to: bumpyroad
You are correct, sir.  The VST plugin did not work, did not even show up in my list of installed VST plugins until I activated my free Pod Farm via Monkey.  It is free, but it still has to be actvated because it's the real deal.  Not a crippled down version in other words.
adda90   1 posts since
May 28, 2008
10. Sep 14, 2009 8:31 AM in response to: Slingy
Is this offer only for september or can you use it in october for example too, if you ahve downloaded it in september?
Jan 28, 2007
11. Sep 14, 2009 10:02 AM in response to: adda90
what you get is a free 'license' if you take advantage of your chance to do so in September.
Once you have a license..it's yours to keep using after that.
So they are giving away free licenses until after Sept 30.
Jan 24, 2007
12. Sep 14, 2009 8:35 PM in response to: bumpyroad
Thank you Bumpy the .dll search was successful and I put it in the proper vst folder in my DAW. Normally Sonar spots any new vst period ...anyway I got the vst plug-in working using the Podxtl and it is cool that it recognizes all my model pack add-ons for use and that I can apply dual tones when re-amping ...too
I wish there was someway way I could listen and adjust before recording it and applying it ...like monitoring in realtime my adjustments ...then when I find a dual tone I am happy with apply it and move on.
Or maybe there is and I just haevnt figured it out yet.
Jan 29, 2007
13. Sep 14, 2009 9:04 PM in response to: Apologist
I've done the search for the .dll and Vista can't find it. I've uninstalled and re-installed and still nada. Lil help. I'm using the latest version Reaper just now and like wise it usually detects new plugs.
P.S.
I've done all the verification and activation stuff.
Jan 25, 2007
14. Sep 14, 2009 10:26 PM in response to: dasvox
Apologist - there should be a "monitor" button on the track that lets you hear the processing of the plugin when you play. Otherwise you would hear a dry plunk plunk - unless you are monitoring the Pod - then you hear the Pod amps and effects.
After recording - you have to turn the monitor off or you won't hear the recording.
EDIT - if the monitor isn't on - you don't hear anything when you play - if you monitor a track with no plugin on it - you hear plunk plunk.
Dasvox open control panel - folder options - and check off "show hidden files and folder" and uncheck "hide extensions for known file types" - then the search will find it.
But if you re-install again - there is a screen that says it will install the vst in a line 6 folder. You can browse to your Reaper plugins folder and it will go there instead.
