Been playing the JM4 for a couple of months now with no troubles
yesterday i went to a gig and when i plugged it in i got most of the lights except the light in the rectangular screen that tells you what preset you are using etc.
I get no sound whatsoever from the out to amp, the stereo out or the headphones out.
the unit was not dropped or otherwise mistreated.
any ideas what this might be causing this behavior?
I would recommend performing a factory reset on the JM4 by holding the 'TONE/SETTINGS' button on the JM4 as you power it on by plugging in the power cable. Keep in mind this will erase any saved settings and presets, but your recordings will still be intact. If the problem persists, you may want to try re-installing the flash memory on the JM4 using the procedure on the following document:
http://line6.com/community/docs/DOC-1338
If the problem persists, you will need to take it to an authorized service center:
http://line6.com/support/serviceCenters/
Regards,
Line6Hugo
Hello,
It's been a few days since we've heard from you. We're going to assume your question has been answered and close this thread. If you still have questions please feel free to open a new question with us and we will answer your questions accordingly. Thanks!
Regards,
Line6Hugo
i purchased a new px-2 power supply and the problem resolved itself .
i will be buying another power supply next payday so i have a spare
: Privacy Policy : Terms of Use | ||
| : Job Opportunities : Company Info : Press Resources : Contact Us | © 2009 Line 6, Inc. All Rights Reserved. |
