US
This Question is Answered
1 "correct" answer available (5 pts) 1 "helpful" answer available (3 pts)
27 Replies Last post: Mar 10, 2010 2:57 AM by sliding_billy   1 2 Previous Next
Zaserty   4 posts since
Sep 29, 2008
Oct 26, 2009 3:33 PM
Line 6 Edit on Windows 7 32bit
I installed Line 6 Edit version 3.02(which says "This version of Line 6 Edit is compatible with JRE 6") on a Windows 7 32bit PC. I also installed the Java environment JRE 6 Update 16.
I'm getting "Could not find valid Java runtime" error message when I launch Line 6 Edit.
Any idea on how i could resolve this issue?
Thanks alot for your time,
Z
Meechman   1 posts since
Mar 29, 2009
1. Oct 26, 2009 8:46 PM in response to: Zaserty
Re: Line 6 Edit on Windows 7 32bit
Ive got the same problem. Still havent figured it out. Will keep everyone posted. NEED HELP!!!
Crusty_Old_Rocker Checkoutthebigbrain... 1,959 posts since
Jan 24, 2007
2. Oct 26, 2009 9:47 PM in response to: Zaserty
Have you tried downloading and running Java 5 as well as Java 6.  Although it's compatible with Java 6, Edit still needs Java 5.  Just give it a go and see what happens.
Cheers,
Crusty
withlin   26 posts since
Jan 3, 2008
3. Oct 27, 2009 4:57 AM in response to: Crusty_Old_Rocker
I am having this same problem on Vista 64 bit.
Jan 24, 2007
4. Oct 27, 2009 6:12 AM in response to: withlin
Install Java 5 and everything will work fine.  Line 6 Edit needs Java 5.
Cheers,
Crusty
b3_4wv   4 posts since
Feb 17, 2008
6. Oct 28, 2009 7:13 AM in response to: Zaserty
What is JBuster and how do I get it.  My new laptop is running Windows 7 and I've tried everything to get Line6 edit to work.  Line 6 really needs to create a patch.  Anyone heard from Line6?
Jan 3, 2008
7. Oct 28, 2009 12:36 PM in response to: b3_4wv
Installing Java 5 did not work for me either.
Jan 24, 2007
8. Oct 28, 2009 4:48 PM in response to: withlin
With the correct version of Java 5 (1.5.0_13) and Line 6 Edit 3.02 (make sure it's 3.02), you won't need JBuster.  But you must have the correct version of Java installed and running.  Check your Java settings to make sure that you have 1.5.0_13 installed and running.
Double check that Java 6 didn't switch off Java 1.5.0_13.
Cheers,
Crusty
Jan 3, 2008
10. Oct 31, 2009 6:03 AM in response to: Crusty_Old_Rocker
"With the correct version of Java 5 (1.5.0_13) and Line 6 Edit 3.02 (make sure it's 3.02), you won't need JBuster."
Tried that and it still does not work.
Feb 17, 2008
11. Oct 31, 2009 6:40 AM in response to: withlin
me,too.  getting a little frustrated.  wish somebody from line 6 would chime in, or better yet fix all of this mess.
Jan 3, 2008
12. Oct 31, 2009 6:48 AM in response to: b3_4wv
Installed JBuster and it works.
Feb 17, 2008
13. Nov 7, 2009 12:20 PM in response to: withlin
JBuster worked!!!!  I'm back in the saddle!
thorneven Juststartin' 122 posts since
Jan 29, 2009
14. Nov 14, 2009 1:24 PM in response to: b3_4wv
Interesting.  I had the same symptom on my Windows 7 Pro x64 system (Line6 Edit cannot find Java).  I have Java 6 loaded.  I next loaded Java 5, jre-1_5_0_11-windows-i586-p-iftw.exe, and Line6 Edit worked without JBuster.  I wonder how Line6 Edit is programmed that it must use Java5 classes.  Seems to defeat the whole purpose of Java programming, the "program once, run everywhere" language...  LOL.  (Sorry, I hate Java and I'm a programmer for 30 years)  thorne
