US
This Question is Answered
1 "correct" answer available (5 pts) 2 "helpful" answers available (3 pts)
6 Replies Last post: Nov 18, 2009 8:53 AM by Line6Miller
surfketo   3 posts since
Nov 5, 2009
Nov 5, 2009 11:01 AM
Spider III 120
I have some problmes with mi Spider III 120 amp. I turn the amp on and everything seems ok. After 10 or 15 minutes of playing it makes a sound and lowers its volume after that it makes a very loud squeling and can't play no more. If I unplugged mi guitar the squealing stops, but at soons as the cable touches the input pulg the squeling is back. It seems to be a short circuit problem or grounding issue. I unscrew the electronics and put the hardware unit apart form the speakers and the problem seems to stop.
Have you heard of something like that?... do you have any suggestions I can make myself before I pay some checkup?. The amp is a year and a half old, I'm the first owner and it has have ver light use. I like the amp a lot but right know I'm kind of dissapointed that I'm starting having problmes so soon with that little use.
I hope you can help me.
Thanks!
Regards.
JsinR   2 posts since
Dec 27, 2008
1. Nov 5, 2009 11:16 PM in response to: surfketo
Re: Spider III 120
Sounds like multiple problems...check your guitar first. Sounds like a bad connection at the cable to the guitar...not the amp. Grounding sounds like a problem. Not sure where your located but if its not the US you may have some issues with ground in the place your plugging the amp in. Household grounds arent the best,or non-exsistant... especially in other countries.
Line6Miller Line6Support 7,472 posts since
Mar 28, 2006
3. Nov 12, 2009 11:57 AM in response to: surfketo
RE: Spider III 120
Hello,
  It sounds like your amp may have a couple of issues. Possibly a bad DSP or even some power amp problems.
  Where did you purchase the amp?
  How long have you had it?
  It sounds like you will need to take this amp in for service.
  Line6Miller
Mar 28, 2006
5. Nov 16, 2009 10:18 AM in response to: surfketo
RE: Spider III 120
Hello,
  There is no manufacturer bug or known issue that describes the issue you are experiencing. It still sounds like a hardware issue to me though.
  You should definitely contact your local repair center or distributor to arrange a repair.
  Line6Miller
Mar 28, 2006
6. Nov 18, 2009 8:53 AM in response to: surfketo
RE: Spider III 120
Hello,
  It's been a couple of days since we've heard from you. We're going to assume your question has been answered and close this thread. If you still have questions please feel free to open a new question with us and we will answer your questions accordingly. Thanks!
  Line6Miller
