US
This Question is Answered
1 "correct" answer available (5 pts)
16 Replies Last post: Dec 13, 2009 8:17 PM by jonspall   1 2 Previous Next
daemonicwhim   8 posts since
Jun 25, 2008
Nov 7, 2009 6:26 PM
Crackling in monitors, using Toneport UX1
I've tried the recommendations that have already been posted, including optimizing my computer settings, downloading the latest drivers and software versions, and trying different settings for buffer size, bitrate, and so on.  I've checked all the hardware (monitors are brand new, cables are new/not damaged).  My computer should be plenty fast enough (and when I'm not using monitors, it handles the recording software fine, with processing and memory to spare).  So I've kind of reached my wits end...I just spent a bunch of money on these monitors and I can't hear anything but crackling static.
Hardware:
Laptop (Windows Vista, 64bit, 2.10GHz, 4.0GB RAM)
Toneport UX1 (connected by USB 2.0)
M-Audio Studio Monitors (connected by two 1/4" cables to Output from Toneport)
Guitar or Amp (into 1/4" Instrument input on Toneport)
Software:
Line6 Gearbox (usually set on bypass, if I'm recording direct from an amp)
Ableton LiveLite 7.0
Rowbi Guru 3,105 posts since
Nov 25, 2006
1. Nov 8, 2009 1:15 AM in response to: daemonicwhim
Re: Crackling in monitors, using Toneport UX1
okay just a sanity check on a few things, as I've seen the things below happen on here before.
okay, just a thought i assume you're using mono cables from the toneport analog outputs to your monitors (i.e. 2x mono = stereo).
also when you say you have your amp connected to the instrument input.  i hope you mean a direct output from your amp and not a speaker output as that may kill your toneport and even your speakers.  amp soeaker outputs are for one thing... connecting to speakers!
can you get sound out of the toneports headphone output to headphones??
have you tried any other speakers or even your guitar amp from the analog outputs?  anything just to test that both outputs aren't faulty.
have you tried your nea monitors with something else to check they're not faulty?
let us know how you get on with those ideas...
Line6Perry Line6Support 2,379 posts since
Dec 26, 2007
3. Nov 9, 2009 2:46 PM in response to: daemonicwhim
RE: Crackling in monitors, using Toneport UX1
  Did you try a different USB port on your computer to see if that connection provides cleaner digital audio streaming? Let us know.
  Regards,
  L6Perry
Line6Miller Line6Support 7,439 posts since
Mar 28, 2006
5. Nov 13, 2009 9:21 AM in response to: daemonicwhim
Hello,
  What have you done system wise to optimize your computer?
  Have you turned off any wireless services, disabled your internal sound card?
  Also, the crackles only happen when you use the TonePort as an ASIO devices? In other words, what happens when the TonePort is set as your sound card when you stream music or video?
  Line6Miller
Mar 28, 2006
7. Nov 17, 2009 10:04 AM in response to: daemonicwhim
Hello,
  Thanks for the reply. I think at this point we should escalate your issue to our QA department and see if there is anything they can pick up on that we haven't.
  Just to be absolutely thorough though, can you please verify for me that you have done the following 2 things?
  1. Checked all physical cables and connections.
  2. Watched this video and tried everything called out.
  http://line6.com/community/docs/DOC-1490
  Please let me know if you've tried all of these things. If so, we'll take your issue off line via a support ticket and continue to troubleshoot with QA. Thanks!
  Line6Miller
Mar 28, 2006
8. Nov 19, 2009 8:41 AM in response to: daemonicwhim
Hello,
  It's been a couple of days since we've heard from you. We're going to assume your question has been answered and close this thread. If you still have questions please feel free to open a new question with us and we will answer your questions accordingly. Thanks!
  Line6Miller
Mar 28, 2006
11. Nov 20, 2009 4:57 PM in response to: daemonicwhim
Hello,
  What model computer are you using? I'm asking because we've seen some issues with certain HP DV series laptops with AMD Turion processors.
  A lot of people have inserted powered USB 2.0 hubs in line with their TonePorts and the noises have gone away.
  Line6Miller
Mar 28, 2006
13. Nov 23, 2009 8:36 AM in response to: daemonicwhim
Hello,
  We're still looking into why these USB hubs improve the sound quality but at this time we aren't completely sure. I think it may have somethign to do with the way our POD Farm devices interface with the on board ports of those laptops. One theory is that they do not provide enough power to the POD Farm device.
  Has this answer been helpful?
  Line6Miller
