US
This Question is Answered
1 "correct" answer available (5 pts) 2 "helpful" answers available (3 pts)
7 Replies Last post: Nov 13, 2009 8:18 AM by Line6Miller
Equi_librium   4 posts since
Nov 8, 2009
Nov 8, 2009 7:25 AM
Noise on Spider Jam
Hello, first of all sorry for my english. I'm Italian and I bought a used Spider Jam just yesterday. I already did the firmware upgrade to 2.09, everything seems to work perfectly. I noticed a noise coming up suddenly when I play on a song base or drum base. It appears while I'm playing and it decreases the global volume (base and guitar) and you can hear that something is not working properly. I stop my playing and I can clearly hear this noise-vibration. The only way to stop it, is to take out and re-insert the jack of my cable one-two or more times. Doing that, this noise stop. Just to be sure, I have used several cables, all of them new, the problem is still there. Any idea? Thanks a lot.
joegillespie Poweruser 517 posts since
Mar 31, 2007
3. Nov 9, 2009 4:33 AM in response to: Equi_librium
Re: Noise on Spider Jam - additional info 2
If your amp is out of warranty and you want to try fixing it yourself, I have instructions here - http://www.joesjamblog.com/troubleshooting.html
Bad connections are quite common with this amp due to the push-on connectors used. It usually just requires them to be wiggled around a bit using a non-metallic stick. I use a wooden chopstick. First of all, read the disclaimer and safety notes.
If your amp is still in warranty or you not confident about doing such things, take it to a service center.
Line6Miller Line6Support 7,472 posts since
Mar 28, 2006
4. Nov 9, 2009 10:42 AM in response to: Equi_librium
RE: Noise on Spider Jam
Hello,
  That noise is not expected behavior. If you are still under warranty you should contact your local Line 6 distributor and have the amp repaired.
  Lemi S.r.l.
  Via Paolo Ferrari, 6
  Torino
  10154
  +39 011 231092 (phone)
  +39 011 2475618 (fax)
  lemi.torino@lemi.org
  Has this answered your question?
  Line6Miller
Mar 28, 2006
6. Nov 11, 2009 9:23 AM in response to: Equi_librium
I'd at least try to get in touch with your distributor. That noise sounds like it could be an issue we ran into when the Spider Jam was first released. We can cover that under warranty if it is a tech bulletin in our service manual.
  Call your distributor and find out if there is a tech bulletin for that issue.
  Line6Miller
Mar 28, 2006
7. Nov 13, 2009 8:18 AM in response to: Equi_librium
Hello,
  It's been a couple of days since we've heard from you. We're going to assume your question has been answered and close this thread. If you still have questions please feel free to open a new question with us and we will answer your questions accordingly. Thanks!
  Line6Miller
