US
This Question is Answered
1 "correct" answer available (5 pts) 2 "helpful" answers available (3 pts)
7 Replies Last post: Nov 19, 2009 8:50 AM by Line6Miller
jmg41483   3 posts since
Nov 11, 2009
Nov 11, 2009 4:24 PM
registration issues
hi i have inherited my line6 flextone 3 from my deceased grandfather, i have downloaded the line6 monkey and line 6 edit and niether will recognize my product. i registered it but the serial number identifies it as a flextone 3 xl ((21)f3x1p5535002877) by the input it only says flextone iii. i registered it as a flextone 3 xl but with it being registered that way the software still does not recognize the correct amp. can you please help me? thank you!
james gardner
Line6Miller Line6Support 7,472 posts since
Mar 28, 2006
1. Nov 16, 2009 4:16 PM in response to: jmg41483
RE: registration issues
Hello,
  It looks like your Flextone is registered correctly.
  Your software issues should have nothing to do with registration.
  Can you tell me exactly what kind of MIDI to USB interface you are using to connect to your computer?
  Also, what are your computer specs and what versions of Line 6 software do you have installed on your computer? What software are you trying to connect to specifically?
  Line6Miller
spaceatl Iknowathingortwo 1,197 posts since
Jan 24, 2007
4. Nov 17, 2009 8:00 AM in response to: jmg41483
Re: registration issues
Flex 3, 3+ and 3XL all use the exact same firmware....The only differences?
Flex 3, mono 60 watt power amp...No XLR outs
Flex 3+ and 3XL are actually the exact same amp...stereo 150 watt and have XLR outs....The only difference is that the XL has two 12s and the + has one...Is it still a Flextone III?
BTW-My condolances about your grandpa...
s0c9 Iknowathingortwo 243 posts since
Feb 9, 2007
5. Nov 17, 2009 8:53 AM in response to: spaceatl
And...  do NOT use Line6 Monkey with the FLEX series... known issues with firmware updates, and it does not support patch editing on the Flex.
Save yourself some headaches, and remove it from your PC if the Flex is the only L6 product you currently have !!
Use the Line6 Edit for "deep" patch editing [or tweakwiz from vettaville.nl]. Both will allow you to backup your patches. Line6 Monkey does backups on the Flex, but the resulting file is unuseable.
Nor do you need to register the Flex to have L6Edit work for you.
and. welcome.
Mar 28, 2006
6. Nov 17, 2009 10:20 AM in response to: jmg41483
Hello,
  As mentioned by our community members here, you do not need Line 6 Monkey for your amp. All you need is Line 6 Edit.
  What happens exactly when you try to connect your amp to Line 6 Edit?
  Line6Miller
Mar 28, 2006
7. Nov 19, 2009 8:50 AM in response to: jmg41483
Hello,
  It's been a couple of days since we've heard from you. We're going to assume your question has been answered and close this thread. If you still have questions please feel free to open a new question with us and we will answer your questions accordingly. Thanks!
  Line6Miller
