US
This Question is Answered
8 Replies Last post: Dec 5, 2009 11:50 PM by miguelcristi28
miguelcristi28   62 posts since
May 13, 2009
Nov 14, 2009 9:24 PM
ux8 usb firmware unknown
when im starting to power up my ux8, its working nicely. but after a few minutes turning on. the signal clips blinks on and off the line 6 monkey
detects that theres no usb firmware installed so i connect and reconnect again the usb, still the same. when itry to update that selection no response from the monkey
how can i resolve this? is my usb cable the problem?
Line6Miller Line6Support 7,457 posts since
Mar 28, 2006
1. Nov 18, 2009 11:46 AM in response to: miguelcristi28
RE: ux8 usb firmware unknown
Hello,
  I'll need you to provide me with more information.
  What kind of computer are you using? (detailed specs please)
  What operating system is installed on your computer?
  What other USB devices do you have connected to your computer?
  Have you tried other USB cables?
  Have you tried other USB ports on your computer?
  Have you tried reinstalling the drivers on your computer for the UX8?
  Line6Miller
Mar 28, 2006
3. Nov 19, 2009 9:38 AM in response to: miguelcristi28
Hello,
  So you've tried all available USB ports on your computer?
  Have you tried reinstalling the drivers for your UX8?
  Also, have you tried connecting the UX8 to another computer? This will tell us if you have a possible hardware issue or not.
  Line6Miller
Mar 28, 2006
6. Nov 23, 2009 8:40 AM in response to: miguelcristi28
Hello,
  We don't support Windows 7 right now so it's possible that there are bugs between this OS and our drivers.
  If what you are describing sounds like pops and clicks then you should try the following tips in order to troubleshoot this.
  1. Fill out your support profile at http://line6.com/account/supportprofile/
  2. Ensure that you have tested all cables to make sure that they are not defective (USB, audio, etc.)
  3. Ensure that you have all cables connections set up properly
  4. Adjust the Buffer Slider in the Line 6 Audio MIDI Control Panel. (Windows Users: Start/All Programs/Line6/Tools/Audio-MIDI Devices; Mac Users: System Preferences/Other/Audio-MIDI Devices)
  5. Adjust Sample Rates and Bit Depths in the Line 6 Audio MIDI Control Panel and ensure that the Sample Rates and Bit Depth settings in the Line 6 Audio MIDI Control Panel also match the project settings in your DAW/recording application
  6. Ensure that you have the Line 6 device set up in your operating system as the main input/output device (sound card); disable internal sound card in your operating system’s Device Manager control panel
  7. Ensure that your Line 6 USB Device is not connected to a powered USB hub; direct USB ports are required and please try ALL available direct USB ports during the troubleshooting process
  8. Remove all non-essential USB peripherals from the computer (not the mouse or keyboard)
  9. Disable any wireless cards on computer in Device Manager
  10. Set Power Schemes on computer in Control Panel (PC Only) to Always On
  11. There are also several other tips and optimizations you can make on your PC. Please refer to the following document for more information:
  http://line6.com/data/l/0a06007213339477ea0690cb2a/application/pdf/GearBox%203.5%20and%20later%20Windows%20XP%20&%20Vista%20Audio%20Tips%20&%20Optimizations%20(Rev%20A)%20-%20English.pdf
  Please try all of the above first and let us know if you continue to have any more problems. Thanks!
  Line6Miller
Mar 28, 2006
7. Nov 25, 2009 9:17 AM in response to: miguelcristi28
Hello,
  It's been a couple of days since we've heard from you. We're going to assume your question has been answered and close this thread. If you still have questions please feel free to open a new question with us and we will answer your questions accordingly. Thanks!
  Line6Miller
