Hello! I've had my variax 500 electric guitar a couple of years now and it has worked flawlessly until now. When I play barre chords with the lowest keynote on the a-string (for example a high E) the b-string and the g-string doesn't "agree" and i get that tremolo effect which occures when the guitar isn't in tune. However the guitar is perfectly tuned cause when checking the strings separately on those frets that are problematic they're in tune. And I tested to record when first playing on the b-string and then I dubbed that with playing on the g-string and it sounds perfect. It's only when they're played together at the same time it sounds out of tune. If i tune down the b-string just a little it dissapears, but then all other chords gets out of tune. As i've just had it in for intonation I know that that isn't the problem, and i've checked that all frets are in tune. My guess is that something is wrong with the technical part of the guitar, maybe the piezo mics are damaged or something in the "computer" of the guitar. I don't know what to do, I guess I need to get service, but when searching for a service center in sweden i get no results, why is that?
sounds like the first thing to do is to reflash the firmware.
Two suggestions:
1. Change your strings
2. Listen to the tuning *unplugged*. It might be a physical problem.
Idea: (You may already know this, but I will post it anyway for the benefit of the forum)
Tuning is a funny thing. For example, the note E needs to be tuned higher as the 5th of an A chord (A-C#-E) than as the 3rd of a C chord (C-E-G) to blend just right. Singers, violin players, trombone players, etc. do this instinctively. But on instruments like piano and guitar, where a note can only have one pitch, each note is tuned to the average spot so that it comes close, but is not perfect, for all chords.
If you tune so that the G string sounds just right on the 1st fret in the E chord (G# as the 3rd, E-G#-B) then it will sound flat open in a C chord (as the 5th, C-E-G). The only solution is to compromise - make the G string a little flat for the C chord but a little sharp for the E chord.
This "compromise" system is called equal temperament and is what electronic tuners automatically use.
yeah but i would need workbench for that right? i've never felt that i need workbench and it feels like a waste of my money to buy it just for that purpose. and if it doesn't solve the problem it will be even more of a waste.
I changed the strings just before I had it intonated. The problem was the same with the old strings. If this problem has to do with the tuning, then why haven't I had it the first 4-5 years? I think i bought my variax in 2004 and this problem occured in september this year. I have always used the same brand of strings, d'addario xl exl110, cause it was the sort of strings the guitar was delivered with.
the guitar sounds in tune when playing it unplugged. one way of how to test if it's the hardware that's defect would be to put a real pickup on the guitar and see how it sounds through that.
yes you need workbench to flash the chip. i see no service center in your area either. do you know anyone who has workbench that could do a reflash for you. you could try rigging a pickup like you already said just to test it but if it sounds right playing it not powered it will sound the same with a pickup. if thats what you need to do to be sure then do that but i still think you need to flash the chip. as far as the service center youll have to find the nearest one to you (i know theres none listed there) ship it both ways and pay for repair . im assuming your warrantee is long done.
i can't understand how they can't have a service center in sweden, the closest is in germany, and that will be really expensive, shipment and service costs. this is so annoying. it would be nice with a comment from someone at line 6. don't they answer any questions?
so if it is as supposed the chip, what may have happened? i mostly just use the t-model, the spanks and the lester, and haven't even saved any preset. the only thing i've done was to upgrade the firmware, but that was 2 years ago and the guitar was fine after that. i friend hade a floorpod xt so that's how was able to upgrade, but he has sold it. I don't think I know anyone else using any line 6 gear. How about the usb audio interfaces, does any of them have the function to plug in your variax and use monkey or something like that? that would at least be motivated to buy cause even if it doesn't solve the problem I probably can sell it or use it in my studio, a workbench bundle will be harder to get rid of and would be useless if it doesn't fix my guitar.
and about an external pickup, i'm thinking about using one from my old crap guitar, but i don't know if it will fit under the strings without carving a whole in my variax, which i'd rather not do. another idea I have is to record the guitar with a regular mic in front of it with quite much gain and then put on some distortion, just to see how that sounds.
There is a service center (actually the distributor for the nordic countries) in Stockholm called Luthman (www.luthman.se) but you need to go via a dealer since they normaly not are the frontend for end users.
If you for some reason can't go thru a dealer you might give them a call to see if they will help you anyway...
First I'd try to borrow a xt-live or x3-live from a music store or friend and use the free workbench software and reflash the guitar again to see if this helps. Then you don't have to buy the workbench hardware.
probably the only thing thats gonna fit under the strings is an old top mount guitar pickup or if you know someone with a dogear p90 laying around or someone with a roland gk pickup or maybe one of those thin acoustic pickups. what you could try is getting a support ticket that would put you intouch with a line 6 tech. i dont know how to do that because ive never had to but i know that you can work one on one with a tech that way.
the trouble woth the usb audio interface is getting it connected to the guitar if you look at the attatched photo of thw workbench hardware theres two cables and the interface. so it changes the guitar connector to usb that way. i think theres a chip in there that does something too.
yeah there is i just looked at it so it probably has some miniscule program on it.
The workbench hardware is an specialized thing that does (usb<-->midi).
Hello,
Outside of the software reflash and changing strings (to make sure there is not a string issue), you may want to have a qualified guitar luthier/tech go through the guitar to make sure there are no other problems with the nut or saddle piece that could be causing some other issue that would knock the intonation out of tune. You can also take a look at this Peterson FAQ where they discuss how to correctly intonate and setup a guitar, as well as the ideas behind tempered tunings:
http://www.petersontuners.com/index.cfm?category=85
Please be sure to award Helpful and/or Correct points to community members who respond with helpful or correct answers, and close out the ticket as “answered” if your situation has been resolved.
sorry, i'm so new here and didn't know about the award system.
i didn't do the intonation myself, i did let a tech do it in a guitar shop that a friend recommended as he always has his guitar intonated there. but maybe he wasn't qualified for the job or just made it really quick and just assumed it was an intonation issue. i've already changed strings 2 times so that cannot be the cause.
by the way, why doesn't any of the pod studio usb audio interfaces have a variax input?
oh and i forgot to ask, have there been issues similar to my problem where a reflash has fixed it, that you know of?
Hello,
You may want to have the tech redo the intonation to make sure there is no problem there.
None of the POD Studio devices have a Variax input, but you can submit your feature request at the following link:
Feature requests
http://line6.com/company/contact/productFeedback/?topic_id=3
Hello,
It's been a couple of days since we've heard from you. We're going to assume your question has been answered and close this thread. If you still have questions please feel free to open a new question with us and we will answer your questions accordingly. Thanks!
: Privacy Policy : Terms of Use | ||
| : Job Opportunities : Company Info : Press Resources : Contact Us | © 2009 Line 6, Inc. All Rights Reserved. |
