I suspect this is the drifting knobs syndrome...likely the gain or channel volume...
You can connect you Flex to Edit and "see" if this is the case...What I recomend is parking all the knobs minus the master to zero, recall your patches. I have been using Line 6 for quite a while and every amp has done this...Parking the knobs at zero for performance prevents it...Unless there is something else going on like a failing transistor or a pot that is really broken...
Check out this thread for a more detailed explanation..
Hello,
+1 to the post above. If parking your knobs does not solve your problem you may have a faulty potentiometer which you should have replaced by a local authorized service center.
http://line6.com/support/serviceCenters/
If all of your questions have been answered please be sure to
award Helpful and/or Correct points to community members who
respond with helpful or correct answers, and close out the
ticket as “answered” if your situation has been resolved.
Thanks!
Line6Miller
: Privacy Policy : Terms of Use | ||
| : Job Opportunities : Company Info : Press Resources : Contact Us | © 2009 Line 6, Inc. All Rights Reserved. |
