US
This Question is Answered
1 "correct" answer available (5 pts) 2 "helpful" answers available (3 pts)
4 Replies Last post: Nov 25, 2009 8:31 AM by Line6Hugo
bikeman01   11 posts since
Oct 24, 2009
Nov 20, 2009 8:07 AM
pocket pod install problems windows xp
When I connect my pocket pod windows says found new hardware line 6 but then says it can't install.
Also I have installed line 6 monkey but when it starts up it does not list pocket pod in the hardware list.
How do I resolve?
Thanks
Line6Andy Line6Support 4,031 posts since
Jun 5, 2006
2. Nov 23, 2009 4:59 PM in response to: bikeman01
RE: pocket pod install problems windows xp
  Hello,
    Pocketpod uses "class compliant" drivers, so you will want to make sure your version of XP is "up to date".  You should also check the following document on USB connections to make sure there are no problems, as well as optimizing your computer to work with Line 6 gear.  See the following links for more info:
  USB Connectivity with Line 6 Devices
  http://line6.com/community/docs/DOC-1484
  Computer System Audio Optimization
  http://line6.com/community/docs/DOC-4201
  Please let us know if you need further assistance, or close out the ticket as “answered” if your situation has been resolved.
Line6Hugo Line6Support 2,821 posts since
Apr 8, 2007
3. Nov 23, 2009 5:00 PM in response to: bikeman01
Please make sure to disconnect all other USB devices from the computer (except for a mouse and keyboard) while troubleshooting this issue. Completely remove ANY USB hubs, even if not in use and test the PODxt on all of the USB ports on your computer.
  Line 6 Monkey will not give Pocket POD as an option, but the Pocket POD will be picked up by Monkey once it makes the connection.
  If the problem persists, you should isolate the problem by trying on a different computer.
  Regards,
  Line6Hugo
Apr 8, 2007
4. Nov 25, 2009 8:31 AM in response to: bikeman01
Hello,
  It's been a few days since we've heard from you. We're going to assume your question has been answered and close this thread. If you still have questions please feel free to re-open this thread or create a new question with us and we will answer your questions accordingly. Thanks!
  Regards,
  Line6Hugo
