US
This Question is Assumed Answered
1 "correct" answer available (5 pts) 2 "helpful" answers available (3 pts)
11 Replies Last post: 2009-11-23 下午4:56 by chadaustin
pbassred   20 posts since
2006-9-19
2009-3-21 上午12:48
Why does my Bass Pod XT live go mental???
New forum and all the history dies, so I'll ask the question again.
When I use my Yamaha TRB5 through any other amp its perfect.  When I use any other bass through my  BOD xt Live still good.  When i use my YamahaTRB5 through the BOD xt live it can be fine for  30 min and then 1/2 way through a song, the volume and trebble both go through the roof.  The only way to correct it, is to unplug the input jack and then reconnect.
Any thoughts?
Jeraxle Juststartin' 186 posts since
2007-11-28
1. 2009-3-21 上午12:54 in response to: pbassred
Re: Why does my Bass Pod XT live go mental???
It looks like your Yamaha TRB5 has active electronics. You'll want to turn the PAD on when using your Yamaha.  It's the switch on the back next to your input.
2007-11-28
3. 2009-3-21 上午2:12 in response to: pbassred
When was the last time you changed the battery(ies) in your Yamaha?  I don't believe there is anything wrong with your XTL due to the fact that other basses (as well as another bass with active electronics) work fine with it.  Another thing to check is all the connections inside your Yamaha.  You described that the only way to make it 'reset' is to unplug the input and reinsert.  I would start with the output jack and work my way towards the pickups looking for a loose connection or a short.
2007-11-28
4. 2009-3-21 上午2:30 in response to: pbassred
Also, you didn't mention, but I assumed that you are using the same cable / wireless system with your Yamaha as your other basses.  Is this true?
greghfd   7 posts since
2007-10-4
7. 2009-10-18 上午4:07 in response to: pbassred
I'd realy like to know how your getting on with your #*%#^*#  XT. I have a guitar XT Live that is doing exactly the same thing
&  it dos'nt matter what I do with the pad switch. I use a Jackson & Strat and an FL2 that has a preamp but the good old XT
dos'nt care if the input is active or not as it will go biserk with either . No one seems to be able to help, ( it's out of warranty )
I dont dare gig with it & it's getting too anoying to practice with. All I can do is turn off, unplug, recalibrate the pedal & start
over untill it goes off it's head again, which can be between 5 minutes & 3 hours.
I've gone back to stomp boxes but would realy like to get this fixed.
This thing has lived in a well padded road case, never dropped or had anything spilled on it & this is the thanks I get !!!
Anyway " you are not alone "
rhhicks   14 posts since
2008-5-26
8. 2009-11-21 上午8:03 in response to: greghfd
I hope I'm not jacking this thread.  Like the poster just before me, I have a guitar Pod XT Live (not the bass model) with the very same symptoms.  While playing, the unit will spontaneously leap huge increments in volume, either upwards or downwards.  I'll readjust my amp gain to compensate and then eventually, wham... off it goes to a radically different new volume setting.  I'm not 100% on this, but I think I'm seeing this phenomenon more often when the unit is cold then after it has been powered on for some time.
Took it to an authorized repair shop in Wheaton, MD and after $100 and several round trips, it now seems to be a little worse.
No active electronics, just a passive Tom Anderson hollow drop-top directly into the unit.  Cables are fine.
One thing I've noticed just by diddling with the thing, sometimes, immediately after one of these spontaneous gain changes, if I either (1) whack the volume pedal with my foot or (2) wiggle and reposition the "Drive" knob, the unit gain will restore to what it was just prior to the madness, but sometimes not.  Last night I updated all of the unit software, reflashed the unit and calibrated the volume pedal.  If I knew of any other possible remedies, I'd try them as well.
Is anyone aware of a calibration or reset procedure for all of the rotary encoders on the unit?
Because the unit is so flaky now (despite being well taken care of - no drops, etc.), I can't trust it in a live performance situation.  The changes in gain are so prominent that it's disruptive to any performance.  Also, like one of the other posters earlier in this thread, it's also becoming too much of a pain in the *** to practice or rehearse with.  It's a shame because I am really fond of some of my home brew user patches, but I'm now afraid to use the thing.
Any deep knowledge Pod XT Live medicine men out there?
2008-5-26
9. 2009-11-21 上午8:06 in response to: rhhicks
I can' believe this board software blanked out A*S*S in my previous post.  What the H*E*L*L is wrong with A*S*S?
Mcgill Juststartin' 333 posts since
2007-1-25
10. 2009-11-21 上午8:12 in response to: rhhicks
If you´d end it with "hole" someone may not be too fond of it?
Just guessing though!
chadaustin   1 posts since
2009-11-23
11. 2009-11-23 下午4:56 in response to: Mcgill
I have the Bass Pod XT Live. It's in my smoke-free studio, and I use my Fender Jazz Bass, and has never been used in a live setting. I only use it for recording.
I can be playing happily along and lose gain completely.
It didn't always do this.
It hasn't been dropped or had anything spilled upon it.
It's not the cables. It's the unit itself.
For example, I turned it on a few minutes ago, and watched the display show the value of the DRIVE slowly increase from 0 to maybe 10o... this took place over the course of about 1.5 minutes.
Also, the Drive pot doesn't even work now.
It's sad because it's a great sounding unit. I would recommend it for the studio, but not live.
On the other hand, I have the Pod XT Live for guitar and have been using it live (MIDI'd up to a sequencer) for the last 2 years and I love it.
