US
This Question is Assumed Answered
1 "correct" answer available (5 pts) 2 "helpful" answers available (3 pts)
4 Replies Last post: Apr 17, 2009 11:59 AM by Line6Perry
rbe5000   4 posts since
Dec 31, 2008
Apr 13, 2009 9:17 AM
Network seems stuck accessing GuitarPort Online
I have tried everything listed in the forums and in help docs, but I still can't access Guitar Port Online. I can play through the guitar port, no problem, everything seems to be fine. I can use my web browser to surf to line 6 and guitarport.com no problem.
So, I hooked up a packet sniffer to figure out what the hell is going on with the network connection. It looks like it is getting stuck. Here is the pattern of http traffic I see when I launch guitarport online in Gearbox. Note, 66.150.189.11 is 4750.line6.net. It looks like /camel is a login address. It looks like login succeeds and then Gearbox asks for /mag/index.html, which seems not to exist, and the server then sends the browser, via redirect, to /subscribe/playhack.html. Then the browser goes back to /camel and maybe tries to login again. This loop of 4 http calls repeats endlessly.
POST 66.150.189.11/camel -> 200 OK Response
GET 66.150.189.11/mag/index -> 302 Redirect Response
GET 66.150.189.11/subscribe/playhack.html -> 200 OK Response
Any ideas what is going guys? I really want to use the subscription that I paid for, and it has been almost a month with no access.
Thanks,
Bob Evans
Line6Sach Checkoutthebigbrain... 1,607 posts since
Oct 31, 2008
2. Apr 13, 2009 4:42 PM in response to: rbe5000
Re: Network seems stuck accessing GuitarPort Online
Please try doing a license refresh:
In the 'Optional Add-Ons' tab of Line 6 Monkey, please click 'Activate Feature.' Instead of a license code, type the word "Refresh" in the text field and click 'Activate.' Follow any prompts that follow. Once complete, try GPO from GearBox. Also be sure that you have the newest version of GearBox which is 3.70.
Thanks
Line6Sach
Line6Perry Line6Support 2,423 posts since
Dec 26, 2007
4. Apr 17, 2009 11:59 AM in response to: rbe5000
It's looking like a connection issue on your end. The GPO Server is definitely up and running (we connect to it via an Internet connection just like customers 20+ miles away from this office building).
If you're running on Satellite Internet, this could be the root cause: Satellite connections are not supported connections to the GPO server. For more info: http://line6.com/community/docs/DOC-4161
If you're not on Satellite ISP, there still might be something in the setup of your gateway causing the issue. We aren't really able to troubleshoot those issues, though; you'll need a support tech from your Internet Service Provider to assist there.
If possible, please try connecting using a different computer/ISP location with the same hardware device/software/account login. This would at least give you feedback as to whether the problem is with your current location or not.
If that ends up being the cause, we can reimburse you and cancel the service.
