Not many would have the guts to post this first attempt at using a whammy bar - but I do.
You will hear me nail the harmonics and really rock on.
I may need a bit of practice to perfect it though - when I get a whammy bar that's left-handed and easier to use.
What?............no compliments?
How many think that's three minutes they'll never get back?
I was going through some old Cubase projects for a backing track to practice with so I didn't have to record the keyboard. This one was particularly crappy so I thought I would practice the whammy bar and ignore the backing track.
I saw a lesson on Utube about pushing down on the whammy and hitting a harmonic and raising the bar.
This backwards whammy bar is too far from the strings and it was like trying to pick the strings while holding a hammer.
I got about one out of ten tries and thought it was hilarious.
I hope the metalheads don't think that's what I think metal is. ![]()
Okay, just a few comments...
1. It may be hard to believe, but some of us have a life
. I didn't even see this post until this morning.
2. Though I agree that Metal is very easy, the song you posted is about the furthest thing from Metal you can get.
3. Sounds like you're having a lot of fun with your new tremolo. It is a blast to play with and that's what it's all about (forget everything you know about the Hokey Pokey).
Here are some other whammy tricks to play with/learn/master...
Flutter
Basically, you hit a note and slap your whammy bar lightly. You're pressing the whammy bar down and letting it snap back. This will cause it to bounce back and forth very quickly causing your notes to get a strange "grrrrrrrrr" overtone. This may be easier for you if you put the whammy bar pointing straight to the back of the guitar. You can just pick a note, and quickly slap the bar with your picking hand.
Lizard Down the Throat
That's what Satriani calls it anyway. You'll slide a note (make sure it's a note you want to hear) up the neck to a note you want to eventually hit. As you slide the first note, you will depress the whammy bar so the note, though sliding up, isn't changing. As soon as you get to the final note, you let up on the whammy bar to express the final note. You'll get this really cool "r-r-r-r-r-r" as you slide up because the bar is bending the note smoothly and your note is creasing one fret at a time. Then, you get a cool "weeee" sound from releasing your bar to hit the final note. When you master this, you'll want to hit it fast and smooth. It will make ears do a double-take.
Screech Dive
This one is tough to find, but once you find it, you'll use it all over the place like so many of the whammy masters. There are two ways to do this. The easiest way is to lay your fretting hand across the strings around the neck pickup. You're looking for the harmonics that hit there (you'll want to use, at least, two fingers so the harmonics are a little "sloppy"). You will strike all the strings so they all ring that really high harmonic, then you will quickly depress your whammy. You will get a really cool, almost eagle-like screech that dives as you depress the bar. Also, you will get some really odd sympathetic, dissonant harmonics that ring with the strings are you depress the bar.
The other way to achieve this is to use the blade of your picking hand to hit those harmonics. You will reach under the neck, in front of the body with your picking hand to grab the whammy bar. This way is tougher, but is more visually stunning.
There are more that I'm sure others can explain, but these are the first three off the top of my head.
Here's a friend of mine by the name of Ponco Satrio. He's a fantastic guitar player and the absolute nicest guy on the planet. Here are some free lessons on the Whammy bar. He's Indonesian so some of these lessons are not in English. Still, you can see the techniques he's using very clearly:
http://www.youtube.com/watch?v=GrGuDghdsD8 (start this one about 2 minutes in for the Flutter technique)
If you just want some basic guitar lessons, he's got a metric, cubic, butt-ton of them on line: http://www.youtube.com/results?search_type=&search_query=ponco+satrio&aq=f
oooooooooooooooo....my head......what happened?![]()
I seem to have fallen off my chair...what's that playing in the headphones?
oooooooooooooooooo-<thud!>
Dude.
Ow.
Seriously. Ow.
That was the most godawful thing I've ever heard. Good job.
You just need some out of tune piano, a couple of off time drum hits and a bass solo, and it actually might kill somebody.
I was expecting you all to say it sounds just like Satriani and Vai.
I heard their names before and found their videos on Utube and copied their styles exactly.
I figure I'm as good as them and I just needed a whammy bar to really show off.
What a disappointment after all that practice. ![]()
Steve Vai
http://www.youtube.com/watch?v=nMXlaMiRxDs&feature=related
Joe Satriani
I was going to say drum solo, but I saw you posted and couldn't resist. ![]()
I'm sure you solo very well....hell, with all those strings, I know you can play.
and just to continue the bass player fun...
Q - What's the difference between a Bassist and a rhino that's just eaten a tin of baked beans?
A - One's a huge useless thing that makes a deep farting noise and the other is a rhino.
And not to leave drummers out...
Q - What's the difference between a drummer and a drum machine?
A - About four bars by the end of the song.
And let's not leave the guitars out....
Q - How many guitarists does it take to change a fluorescent tube?
A - Three, One to change it and the other two to tell him how much better incandescent bulbs are.
Ba dum bump sssssss....Thank you! I'll be here all week! Tip your waitresses and get home safe!
: Privacy Policy : Terms of Use | ||
| : Job Opportunities : Company Info : Press Resources : Contact Us | © 2009 Line 6, Inc. All Rights Reserved. |
