US
This Question is Answered
2 "helpful" answers available (3 pts)
13 Replies Last post: Jun 10, 2009 1:59 AM by carnigetot
carnigetot   21 posts since
Jan 23, 2009
Jun 4, 2009 4:15 AM
Pod X3 conectivity problem
heya,
yesterday i connected my POD x3 to my computer and i used it with gearbox. It worked fine. Then i closed gearbox and after a little while i wanted to star gearbox again. It got stuck at the splash screen at the message: "Initializing subscriber services". I ttried to close gearbox using ctrl+alt+del( i use windows XP) and it didn't work. Then i turned the POD off and it closed... so i left it like that. Today i wanted to use my pod with gearbox again but when i connected my POD to my computer it wasn't recognized anymore, my computer saw it as a Usb Device. So i uninstalled my drivers and gearbox and i connected the POD again, but still the same problem, the computer doesn't recognize it as "POD X3" it just sees it as "USB Device". What can i do? Please help
Alex
silverhead Checkoutthebigbrain... 1,183 posts since
Apr 1, 2009
2. Jun 4, 2009 2:31 PM in response to: carnigetot
Re: Pod X3 conectivity problem
Did you reinstall your drivers again? If not, you should.
In your 2nd post you say, before taking it to the service centre you tried it on another computer. Did that other computer have the X3 driver installed? The computer at the service centre probably did have the driver installed, which may be why it recognized it.
Line6Andy Line6Support 2,936 posts since
Jun 5, 2006
3. Jun 4, 2009 3:05 PM in response to: carnigetot
Hello,
  This information is helpful. Please go the following link to download/install the latest Gearbox software for your Operating System, which also includes the Line 6 monkey intelligent updater and the latest drivers for your Line 6 product.
http://line6.com/software/
See the following links for additional Line 6 software information:
Line 6 Monkey Installation and F.A.Q.
http://line6.com/community/docs/DOC-3898
Installing Drivers For Your Line 6 Device
http://line6.com/community/docs/DOC-4427
Gearbox Program manual
http://line6.com/community/docs/DOC-4839
Use the information in this link to optimize your computer to work with Line 6 Gear:
Computer System Audio Optimization
http://line6.com/community/docs/DOC-4201
See the following information for setting up your Line 6 device as the soundcard on your computer:
Setting up your Line 6 device as External Sound Card within Windows XP: Video
http://line6.com/community/docs/DOC-1427
Assigning your Line 6 Device as a Sound Card on your Windows XP Computer
http://line6.com/community/docs/DOC-1452
See the following info for USB connection FAQs:
USB Connectivity with Line 6 Devices
http://line6.com/community/docs/DOC-4599
Please be sure to award Helpful and/or Correct points to community members who respond with helpful or correct answers!
Line6Andy
Line6Miller Line6Support 4,479 posts since
Mar 28, 2006
4. Jun 4, 2009 3:06 PM in response to: carnigetot
When you plug the POD into your computer manually update the driver from your Device Manager. This will kick start the Windows Hardware Wizard which will finish your driver install for you.
Check out this doc for more info.
Line6Miller
Line6Hugo Line6Support 1,935 posts since
Apr 8, 2007
7. Jun 5, 2009 11:05 AM in response to: carnigetot
Hmmmm, here is that link again:
Not sure why that other exact same link doesn't work.
Regards,
Line6Hugo
Apr 1, 2009
10. Jun 9, 2009 5:56 AM in response to: carnigetot
You might want to re-post this item again as a new question. This one is marked Answered so few people will visit it anymore.
Apr 1, 2009
12. Jun 9, 2009 3:55 PM in response to: carnigetot
I won't reply to yhe new post since I don't have any other suggestions at the moment - but I'm curious. You marked my earlier answer as 'correct' - where I suggested you reinstall the drivers. Did you do that? If so, you might want to add that info as a followup to your last post so that other readers don't suggest it again (I presume it didn't actually work).
