JTV-59P-US
James Tyler-designed Single-cut Guitar with Variax Modeling
JTV-59P-US
Expertly crafted in the United States, JTV-59P-US places cutting-edge Variax® technology inside a classic tonewood combination established by the archetypal set-neck, single-cutaway solidbodies of the 1950s. The figured maple top is carved into a gentle arch and paired with a mahogany body and quarter-sawn mahogany neck. This combination of woods yields the full spectrum of warmth, depth, clarity and complexity that has made maple/mahogany construction legendary.
A pair of vintage-voiced P-90 soapbar pickups translates this guitar’s stunning tone to the amp of your choice. To complete the package, JTV-59P-US features a unique Tyler-designed, fully adjustable wraparound bridge (which redefines resonant coupling between strings and body); a supremely comfortable neck patterned after Tyler's own '59 neck shape, with a smoothly contoured heel; and jaw-dropping looks courtesy of five hand-sprayed finishes.
“From what you see in the guitars, you can tell that everybody involved in the process cares about what they do.” —Tim Wilson
Before your James Tyler® Variax® US Custom Series guitar reaches your hands, it passes through those of the most skilled woodworkers, painters and builders in the business. Representing over a century of experience, the talented team demonstrates deep passion, pride and guitar players’ sensibilities while bringing James Tyler’s designs to life. By delicately balancing cutting-edge manufacturing technology with painstaking hand craftsmanship, the US Custom Series team creates instruments of incomparable beauty and feel.
“Beyond trying to satisfy the customers, I have to make sure that James Tyler will be happy… He holds extremely high standards for his work.” —Tim Wilson
“My philosophy is that there’s a right way to do things, and a wrong way. Pretty simple, do it the right way.” —Bruce Hamilton
“Without skill and expertise, you can turn that nicely machined part into firewood in a heartbeat.” —Jeff Callahan
Head-turning Looks
The Extra Mile
