JTV-69-US
JTV-69-US
Expertly crafted in the United States, JTV-69-US places cutting-edge Variax® technology inside a premium instrument designed in the image of the first successful solidbody electrics. The classic ash or alder body, quarter-sawn maple neck with rosewood or maple fingerboard, and 25-1/2” scale length provide tonal richness and warmth while preserving the design's historic bright, percussive snap.
To make the most of this stunning tone, the humbucker in the bridge position complements the ‘60s-style single-coil pickups in the neck and middle positions. All pickups are loaded with alnico magnets and wound to James Tyler's specs. To complete the package, JTV-69-US features the comfortable Tyler ’59 neck profile; a James Tyler Custom Tremolo bridge; ultra-stable, quarter-sawn, three-piece maple neck; and your choice of classic and contemporary hand-sprayed finishes.
“From what you see in the guitars, you can tell that everybody involved in the process cares about what they do.” —Tim Wilson
Before your James Tyler® Variax® US Custom Series guitar reaches your hands, it passes through those of the most skilled woodworkers, painters and builders in the business. Representing over a century of experience, the talented team demonstrates deep passion, pride and guitar players’ sensibilities while bringing James Tyler’s designs to life. By delicately balancing cutting-edge manufacturing technology with painstaking hand craftsmanship, the US Custom Series team creates instruments of incomparable beauty and feel.
“Beyond trying to satisfy the customers, I have to make sure that James Tyler will be happy… He holds extremely high standards for his work.” —Tim Wilson
“My philosophy is that there’s a right way to do things, and a wrong way. Pretty simple, do it the right way.” —Bruce Hamilton
“Without skill and expertise, you can turn that nicely machined part into firewood in a heartbeat.” —Jeff Callahan
Head-turning Looks
The Extra Mile
