JTV-69S-US
JTV-69S-US
Expertly crafted in the United States, JTV-69S-US places cutting-edge Variax® technology inside a premium instrument designed in the image of the first successful solidbody electrics. The classic ash or alder body, quarter-sawn maple neck with rosewood or maple fingerboard, and 25-1/2” scale length provide tonal richness and warmth while preserving the design's historic bright, percussive snap.
To make the most of this stunning tone, the SSS pickup configuration features three ‘60s-style single-coil pickups loaded with alnico magnets and wound to James Tyler's specs. To complete the package, JTV-69-US features the comfortable Tyler ’59 neck profile; a James Tyler Custom Tremolo bridge; ultra-stable, quarter-sawn, three-piece maple neck; and jaw-dropping looks in your choice of classic and contemporary hand-sprayed finishes.
“From what you see in the guitars, you can tell that everybody involved in the process cares about what they do.” —Tim Wilson
Before your James Tyler® Variax® US Custom Series guitar reaches your hands, it passes through those of the most skilled woodworkers, painters and builders in the business. Representing over a century of experience, the talented team demonstrates deep passion, pride and guitar players’ sensibilities while bringing James Tyler’s designs to life. By delicately balancing cutting-edge manufacturing technology with painstaking hand craftsmanship, the US Custom Series team creates instruments of incomparable beauty and feel.
“Beyond trying to satisfy the customers, I have to make sure that James Tyler will be happy… He holds extremely high standards for his work.” —Tim Wilson
“My philosophy is that there’s a right way to do things, and a wrong way. Pretty simple, do it the right way.” —Bruce Hamilton
“Without skill and expertise, you can turn that nicely machined part into firewood in a heartbeat.” —Jeff Callahan
Head-turning Looks
The Extra Mile
