JTV-89F-US
Expertly crafted in the United States, JTV-89F-US is an electric guitar of the highest caliber. This hard-rocking powerhouse marries incredible Variax technology with a sculpted mahogany body and a quarter-sawn, three-piece maple neck with 24-fret rosewood fingerboard.
A pair of custom, high-output, alnico humbucking pickups—wound to James Tyler's specs—translate this powerful instrument to the amp of your choice. The Floyd Rose® licensed, double-locking tremolo bridge by Graph Tech provides rock-solid tuning stability through massive pitch changes. Even with heavy distortion, the deepest lows and velvety highs emerge with exceptional definition.
*Floyd Rose is a registered trademark of Floyd Rose Industries.
See Full Features
Head-turning Looks
The Extra Mile
