As many of you have seen by now, our forum communities were SPAMMED, starting on March 3. Since we were made aware of it, we attempted to address the issue in a number of different ways. As a last resort, we've restricted the ability to post to the forums to accounts created before the SPAM started. We do plan to allow full access to all users in the coming weeks.
If you have a technical question that our documentation does not answer, please create a support ticket at http://line6.com/support/.
We truly apologize for any inconvenience this issue may have caused you.
Line 6 Customer Service
Expiring the announcement will not delete it but will remove it from the public announcement list. Are you sure you want to expire this announcement?
Are you sure you want to delete this announcement?
Top 200 Tags in Stompbox Modelers / ToneCore
- 4
- 6
- aa
- ac
- adapter
- aes
- amp
- amps
- and
- bass
- battieries
- blinking
- board
- broken
- button
- buzz
- bypass
- clearing
- compressor
- connection
- constrictor
- contact
- control
- core
- crunchtone
- current
- daisy_chain
- dc
- delay
- died
- distortion
- distorto
- dl
- dl-4
- dl4
- dm4
- dock
- dont_work
- drop
- drop_out
- dry
- e
- echo
- echo_park
- effect
- effects
- ex-1
- expansions
- expression
- f.a.q.
- failure
- faulty
- firmware
- fix
- flashing
- fm-4
- fm4
- forbidden
- framptone
- freeze
- fried
- functions
- funtivities
- fw410
- fx
- gradually
- guitar
- guitarport
- help
- help!
- hex
- hiss
- imac
- input
- issue
- issues
- jack_output
- jam
- jm4
- jumping
- key
- keys
- line
- line6
- line_6
- locks
- loop
- looper
- loose
- low
- m13
- m13_stompbox_modeler
- m9
- max887
- memory
- metal
- midi
- mkii
- mm-4
- mm4
- mode
- modeler
- modeling
- modulation
- monkey
- mono
- muffled
- multi-head
- multiple
- no
- noise
- noise_problem
- not
- on
- output
- park
- parts
- peavey_blazer_158
- pedal
- phasing
- plus
- pod
- podxtlive
- popping
- pots
- power
- power_supply
- preset_not
- preset_not_working
- presets
- pro
- problem
- problems
- px-2
- question
- questions
- r32
- release
- repair
- repeat
- resistor
- reverb
- routing
- sampler
- serial
- settings
- signal
- size
- solder
- solution
- solutions
- sp3
- spider
- spill
- squeeze
- static
- stereo
- stereo_output
- stomp
- stomp_box
- stompbox
- stompbox_modeler
- supply
- support
- switch
- switching
- tap
- tap_tempo
- taptempo
- tempo
- the
- tone
- tonecore
- trails
- tremolo
- troubles
- troubleshoot
- true
- turn
- tweak
- uber
- uber_metal
- update
- usb
- ux8
- valve
- verbzilla
- verbzilla™
- volume
- volume_loss
- voodoo
- warranty
- water
- wiring
- won't
- working
- works
- wrench
- yellow
About
Follow
Subscribe
