billlorentzen Posted December 26, 2014 Share Posted December 26, 2014 I bought one of the Line6 expression pedals, and I'm trying to get it to have a better gradation from low to high (or left to right). My built-in pedal works fine, and I know how to calibrate it. The root problem is the pedal is a ridiculous POS. The pot inside actually passes 100% and then goes up again at the end of its rotation. Additionally the mechanical design sucks and the action of the pedal is jerky - totally not pro gear. It was cheap though! Does anyone know of a calibration method for the auxiliary pedal in the HD itself? Quote Link to comment Share on other sites More sharing options...
Brazzy Posted December 26, 2014 Share Posted December 26, 2014 There's known issues with the EX-1. I use one and it works ok for what I do. The Mission Engineering Pedal is the one to look at. They make quite a few pedals. There's a fix for the EX-1 somewhere on the net if you search you should find something about adding resistors to open up the range of motion. 1 Quote Link to comment Share on other sites More sharing options...
Palico Posted December 26, 2014 Share Posted December 26, 2014 Don't know about the percentage problem. I have one and it works on that aspect fine. If you loose the nut a bit where the pedal itself attaches then you get jerkness out of it, or taylor the smoothness a bit. To cabrate it you unplug it and calibarte the on-board pedal. Since it supposed to function just a Ex-2 then it should get it as close as it's gonna get. And yep, it's a plastic piece of junk. Quote Link to comment Share on other sites More sharing options...
BlueViolince Posted December 26, 2014 Share Posted December 26, 2014 No software adjustment inside the Pod for this, if that's what you're asking. Quote Link to comment Share on other sites More sharing options...
billlorentzen Posted December 26, 2014 Author Share Posted December 26, 2014 Thanks, guys. I guess if I want accurate control, it's the Mission pedal. Quote Link to comment Share on other sites More sharing options...
