Can you change the order of the effects in the signal chain?
Sometimes I've seen for example the Equalizer at the very end of the chain, other times most usually I've seen it appear much earlier in the signal chain. Almost leads me to believe you can somehow change the order of the effects in the XT Pro signal chain.
Can anyone shed some light on this?
Hey there,
With the XT series you can "to an extent" change the order but only pre/post for some fx (mod, delay) and the volume control. So it is pretty limited compared to an HD but still enough to make some good tones. Check out page 1-6 of the manual and it will give you a visual signal flow graphic.
Hope that helps!
Bill
