Search Articles
Recent Comments
Amplifiers Archives
Pinned  Firehawk 1500 FAQ
Feb 01 2016 10:15 AM | line6will in Firehawk 1500
Full List and Descriptions of FIREHAWK 1500 Amps, Cabs, and Effects  FIREHAWK 1500 Specs · 29 HD Amp Models· 25 HD Effects Models· 78 POD Farm Amp Models· 95 POD Farm Effects Models· 8 simultaneous effects· 128 Onboard Presets· 5 FX on/off...
Images:
Read story →    0 comments    -----    firehawk, 1500, faq, specs and 3 more...
[Video Tutorial] Spider III and Spider Valve Fa...
Oct 18 2010 03:09 PM | Line6Tony in Spider Valve
Images:
Read story →    0 comments    *****    factory, reset, patch, spider and 3 more...
[Video Tutorial] Line 6 Head and Cabinet Connec...
Oct 18 2010 03:10 PM | Line6Tony in Spider Valve
Part 1: Spider, Spider Valve, HD147, and Vetta heads into the original Line 6 Stereo cabinet and Spider cabinet. http://www.youtube.com/watch?feature=player_embedded&v=q_HwbppSMlAPart 2: Spider, Spider Valve, HD147, and Vetta heads into the Line...
Images:
Read story →    0 comments    *****    head, cabinet, connections, vetta and 4 more...
[Video Tutorial] How to Update the Flash Memory...
Oct 18 2010 03:19 PM | Line6Tony in Spider IV/Spider Online
Images:
Read story →    0 comments    *****    update, fbv, monkey, amplifier and 3 more...
[Video Tutorial] Getting Started With Your FBV...
Feb 11 2011 11:04 AM | Line6Tony in Spider IV/Spider Online
Images:
Read story →    0 comments    *****    fbv, amp, express, amplifier and 2 more...
VIDEO: Getting Started With Spider Jam
Oct 15 2012 10:00 AM | Line6Tony in Spider Jam
Images:
Read story →    0 comments    *****    spider, jam, spiderjam, amp and 4 more...
Vetta Trouble Shooting F.A.Q.s
Nov 07 2006 02:47 AM | Line6Tony in Vetta
Q: I have a blank screen on my Vetta? A: If you can't see any characters on your Vetta when you are going through the update, please angle your Vetta or look very closely at the screen at an angle. You should see a faint readout on the screen. If you...
Images:
Read story →    0 comments    *****    vetta, box, reset, update, variax and 3 more...
Vetta Setup and Connection F.A.Q.
Q: Can I go direct from the Vetta to a recording console or PA system? A: Yes,the Vetta II can be used with or without speakers in a studio or live performance application directly through the board. Page 4.32 of the Vetta II Pilot's Handbook it de...
Images:
Read story →    0 comments    *****    vetta, box, effect, fx, insert and 2 more...
Vetta Application F.A.Q.
Q: How do I go about bypassing the amps and cabs in my Vetta? A: The amp models can be bypassed on any preset channel, simply turn the amp model knob to the left to amp model "1" this is amp model bypass, then "Save". With the amp model in bypass t...
Images:
Read story →    0 comments    *****    application, pedal, vetta and 2 more...
Vetta 2.5 Known Issues
Apr 09 2007 02:05 PM | Line6Tony in Vetta
Vetta II Post Delay Mix Issue On some patches with POST DELAY active, you will notice that if you turn DELAY off/on, the perceived mix will jump to %100. Please follow the steps below when the problem patch is active to resolve this issue: Select FOOT...
Images:
Read story →    0 comments    *****    bug, pedal, vetta, mix, delay and 5 more...
Using MIDI to Change Amp Settings on the DT50/D...
Nov 21 2012 11:59 AM | Line6Tony in DT50/DT25
La version française. Zur deutschen Version. en With the latest v2.0 update for the DT25/DT50 amplifiers, you must send MIDI parameters to the amp to change the settings such as the preamp models. Here are the links to the MIDI documentation to referen...
Images: Attached Image: 1.JPG Attached Image: 2.JPG Attached Image: DT25-50 MIDI CC Value reference.JPG Attached Image: DT25-50 MIDI CC Value reference 2.JPG Attached Image: dt midi1.PNG Attached Image: dt midi2.PNG
Read story →    0 comments    *****    midi, midiox, dt50, dt25, amp and 5 more...
Updating the Spider Valve Mk II using Line 6 Mo...
Mar 11 2010 02:55 PM | Line6Tony in Spider Valve
This document explains how to update the flash memory of the Spider Valve Mk II using the FBV Mk II and Line 6 Monkey on Windows XP, Vista, 7 and Mac OSX 10.4.11, 10.5.8 and 10.6.x. Before you get started, you will need to have your Spider Valve Mk II...
Images: Attached Image: 1.PNG Attached Image: 2.PNG Attached Image: 3.PNG Attached Image: 4.PNG Attached Image: 5.PNG Attached Image: 6.PNG Attached Image: 7.PNG Attached Image: update process.PNG
Read story →    0 comments    *****    fx, ii, upgrade, amp, fbv, spider and 4 more...
Updating the Spider IV (75, 120, 150, 150HD) us...
Sep 01 2009 10:55 AM | Line6Tony in Spider IV/Spider Online
Deutsch Français en This document explains how to update the Spider IV (75, 120, 150, 150HD) using the FBV Mk II and Line 6 Monkey using Windows XP, Vista, 7, and Mac OSX 10.4.11, 10.5.8, and 10.6.x. Before you get started, you will need to have your S...
Images:
Read story →    0 comments    *****    spider iv, update, monkey, spider and 6 more...
Updating the Firehawk 1500 via USB on a Windows...
Feb 01 2016 11:14 AM | line6will in Firehawk 1500
Here is how to update the Firehawk 1500 step by step:  Note: The versions of the drivers and software may have older versions. Make sure to always select the latest versions.  For Windows 7, 8, or 10 systems, please start with step 1. For...
Images: Attached Image: ccs-1070239-0-61433200-1432835681.png Attached Image: ccs-1070239-0-88171400-1432835764.png Attached Image: ccs-1070239-0-10577100-1432837038.png Attached Image: ccs-1070239-0-79615600-1432836849.png Attached Image: ccs-1070239-0-39399600-1432837138.png Attached Image: ccs-1070239-0-37601600-1432837289.png Attached Image: ccs-1070239-0-87671200-1432837435.png Attached Image: ccs-1070239-0-35942800-1432837680.png Attached Image: ccs-1070239-0-61438600-1432837865.png Attached Image: ccs-1070239-0-51360600-1432837914.png Attached Image: ccs-1070239-0-15697600-1432838113.png Attached Image: ccs-1070239-0-93592900-1432838216.png
Read story →    0 comments    -----    firehawk 1500, usb, windows, osx and 5 more...
Tube Troubleshooting and Replacement
Aug 29 2007 01:54 PM | Line6Tony in Spider Valve
Q: Is Biasing covered under warranty? A: Typically not. It should be considered as part of the routine maintenance in keeping your amplifier at its peak performance. However, if re-biasing is required as part of other warranty service, it will be cover...
Images:
Read story →    0 comments    *****    repair, service, warranty, tube and 2 more...
Tube F.A.Q.
May 12 2008 12:43 PM | Line6Tony in Spider Valve
Q: What is the difference in power rating between tube and solid-state power amplifiers? A: Tube power outputs can peak 200 to 400% above solid-state, so a 50watt tube power amp can output a volume equivalent to a 100-200w solid-state amplifier output....
Images:
Read story →    0 comments    *****    power, tube, pre, 12, valve, 5881 and 3 more...
Spider Valve Presets, Specs, and FAQ
Aug 29 2007 01:39 PM | Line6Tony in Spider Valve
Application Q: What are the presets on my Spider Valve amplifier? A: The user presets and artist/song presets for the Spider Valve are listed as attachments at the bottom of this document (please be aware that they are identical to the Spider III w...
Images:
Read story →    0 comments    *****    faq, presets, amp, power, mono and 4 more...
Spider Valve MKII FX Infusion Update (2.0)
Sep 30 2010 08:34 AM | Line6Tony in Spider Valve
Spider Valve MKII FX INFUSION v2.0 is a free firmware upgrade for your Spider Valve MKII 112, 212 and HD100. This new firmware features:  A total of 56 FX Models, bringing the total in your updated amp to 76! (All the FX from Spider FX Infusion 1...
Images:
Read story →    0 comments    *****    update, firmware, spider and 3 more...
Spider Valve Mk II Presets, Specs, and FAQ
Sep 25 2009 02:51 PM | Line6Tony in Spider Valve
Application  Q: What are the presets on my Spider Valve Mk II amplifier? A: There are 64 presets (16 banks of 4) programmed into the amplifier at the factory, and 64 “empty” preset locations for an end user to program. The “empty” 64 preset lo...
Images:
Read story →    0 comments    *****    ii, presets, amp, amplifier, cab and 5 more...
Spider Valve Mk II Popping When Changing Presets
Sep 11 2013 09:11 AM | Line6Hugo in Spider Valve
The Spider Valve Mk II series of amplifiers are designed for live performance environments, especially the 100 watt version of the amp. There are rare use cases where, when the volume is set very low ( like an apartment, or bedroom), and specific com...
Images:
Read story →    0 comments    ****-    popping, noise, sound
