Search Articles
Recent Comments
DT50/DT25 Archives
Using MIDI to Change Amp Settings on the DT50/D...
Nov 21 2012 11:59 AM | Line6Tony in DT50/DT25
La version française. Zur deutschen Version. en With the latest v2.0 update for the DT25/DT50 amplifiers, you must send MIDI parameters to the amp to change the settings such as the preamp models. Here are the links to the MIDI documentation to referen...
Images: Attached Image: 1.JPG Attached Image: 2.JPG Attached Image: DT25-50 MIDI CC Value reference.JPG Attached Image: DT25-50 MIDI CC Value reference 2.JPG Attached Image: dt midi1.PNG Attached Image: dt midi2.PNG
Read story →    0 comments    *****    midi, midiox, dt50, dt25, amp and 5 more...
DT50/DT25: Terminology
Nov 03 2010 01:42 PM | Line6Tony in DT50/DT25
Zur deutschen Version. La version française. en DT50/DT25 Terminology FAQ Headroom: how much signal “room” you have before encountering distortion, particularly saturation. If you have more headroom, the amp will feel like it responds to your playing...
Images:
Read story →    0 comments    *****    loop, feedback, amp, tube, class and 5 more...
DT50/DT25: FAQ
Nov 03 2010 02:27 PM | Line6Tony in DT50/DT25
Zur deutschen Version. La version française.  en Please read through the DT50/DT25 Terminology FAQ first, to familiarize yourself with the terms that will be referenced here. Application Q: Are there any presets on the DT50/DT25 amplifier i...
Images:
Read story →    0 comments    *****    dt25, dt50, topology, dt_faq and 6 more...
DT50/DT25 Weights and Dimensions
Nov 16 2010 04:11 PM | Line6Tony in DT50/DT25
The following values are out-of-box measurements:DT50 Weights / Dimensions: Height, Width, Depth, Weight 112: 21.75", 26.00", 10.75", 63.1 lbs212: 22.50", 27.50", 10.75", 76.2 lbsHD: 11.00", 27.50", 10.75", 39.8 lbs412 Cabinet: 30.70", 29.90", 14....
Images:
Read story →    0 comments    *****    dt, head, weights, dimensions and 4 more...
DT25/DT50 Firmware Installation Instructions
Aug 16 2012 10:54 AM | Line6Tony in DT50/DT25
Version française. Deutsche version. en DT25/DT50 FIRMWARE INSTALLATION INSTRUCTIONS NEEDED: A MIDI interface that connects to your computer via USB (download the current Driver for it if you don't have it installed) 2 MIDI cables (or a MIDI interfac...
Images:
Read story →    0 comments    *****    update, firmware, dt50, dt25 and 4 more...
