Search Articles
Recent Comments
Spider Valve Archives
[Video Tutorial] Spider III and Spider Valve Fa...
Oct 18 2010 03:09 PM | Line6Tony in Spider Valve
Images:
Read story →    0 comments    *****    factory, reset, patch, spider and 3 more...
[Video Tutorial] Line 6 Head and Cabinet Connec...
Oct 18 2010 03:10 PM | Line6Tony in Spider Valve
Part 1: Spider, Spider Valve, HD147, and Vetta heads into the original Line 6 Stereo cabinet and Spider cabinet. http://www.youtube.com/watch?feature=player_embedded&v=q_HwbppSMlAPart 2: Spider, Spider Valve, HD147, and Vetta heads into the Line...
Images:
Read story →    0 comments    *****    head, cabinet, connections, vetta and 4 more...
Updating the Spider Valve Mk II using Line 6 Mo...
Mar 11 2010 02:55 PM | Line6Tony in Spider Valve
This document explains how to update the flash memory of the Spider Valve Mk II using the FBV Mk II and Line 6 Monkey on Windows XP, Vista, 7 and Mac OSX 10.4.11, 10.5.8 and 10.6.x. Before you get started, you will need to have your Spider Valve Mk II...
Images: Attached Image: 1.PNG Attached Image: 2.PNG Attached Image: 3.PNG Attached Image: 4.PNG Attached Image: 5.PNG Attached Image: 6.PNG Attached Image: 7.PNG Attached Image: update process.PNG
Read story →    0 comments    *****    fx, ii, upgrade, amp, fbv, spider and 4 more...
Tube Troubleshooting and Replacement
Aug 29 2007 01:54 PM | Line6Tony in Spider Valve
Q: Is Biasing covered under warranty? A: Typically not. It should be considered as part of the routine maintenance in keeping your amplifier at its peak performance. However, if re-biasing is required as part of other warranty service, it will be cover...
Images:
Read story →    0 comments    *****    repair, service, warranty, tube and 2 more...
Tube F.A.Q.
May 12 2008 12:43 PM | Line6Tony in Spider Valve
Q: What is the difference in power rating between tube and solid-state power amplifiers? A: Tube power outputs can peak 200 to 400% above solid-state, so a 50watt tube power amp can output a volume equivalent to a 100-200w solid-state amplifier output....
Images:
Read story →    0 comments    *****    power, tube, pre, 12, valve, 5881 and 3 more...
Spider Valve Presets, Specs, and FAQ
Aug 29 2007 01:39 PM | Line6Tony in Spider Valve
Application Q: What are the presets on my Spider Valve amplifier? A: The user presets and artist/song presets for the Spider Valve are listed as attachments at the bottom of this document (please be aware that they are identical to the Spider III w...
Images:
Read story →    0 comments    *****    faq, presets, amp, power, mono and 4 more...
Spider Valve MKII FX Infusion Update (2.0)
Sep 30 2010 08:34 AM | Line6Tony in Spider Valve
Spider Valve MKII FX INFUSION v2.0 is a free firmware upgrade for your Spider Valve MKII 112, 212 and HD100. This new firmware features:  A total of 56 FX Models, bringing the total in your updated amp to 76! (All the FX from Spider FX Infusion 1...
Images:
Read story →    0 comments    *****    update, firmware, spider and 3 more...
Spider Valve Mk II Presets, Specs, and FAQ
Sep 25 2009 02:51 PM | Line6Tony in Spider Valve
Application  Q: What are the presets on my Spider Valve Mk II amplifier? A: There are 64 presets (16 banks of 4) programmed into the amplifier at the factory, and 64 “empty” preset locations for an end user to program. The “empty” 64 preset lo...
Images:
Read story →    0 comments    *****    ii, presets, amp, amplifier, cab and 5 more...
Spider Valve Mk II Popping When Changing Presets
Sep 11 2013 09:11 AM | Line6Hugo in Spider Valve
The Spider Valve Mk II series of amplifiers are designed for live performance environments, especially the 100 watt version of the amp. There are rare use cases where, when the volume is set very low ( like an apartment, or bedroom), and specific com...
Images:
Read story →    0 comments    ****-    popping, noise, sound
Spider Valve Mk II Firmware Update Instructions
Jun 29 2012 10:34 AM | Line6Tony in Spider Valve
Update Instructions: All Spider Valve Mk II 112, 212 and HD100 amplifiers can be updated using an FBV MkII Express, FBV MkII Shortboard, or via MIDI with a USB to MIDI interface as follows: Connect your FBV MkII to your Spider Valve MKII using a stan...
Images:
Read story →    0 comments    *****    usb, midi, ii, interface, flash and 4 more...
Spider Valve Edit FAQs
Mar 11 2010 08:46 AM | Line6Tony in Spider Valve
Q: What is Spider Valve Edit? A: Spider Valve Edit is offered as a free software editor for all Spider Valve Mk II (112, 212, HD) amplifiers owners. Spider Valve Edit requires either a MIDI to USB connection from the amp to a computer, or a and CAT-5...
Images:
Read story →    0 comments    *****    spider, valve, edit, mkii, 112 and 3 more...
Dialing In Spider Valve MKII Tones
Nov 03 2011 01:04 PM | Line6Tony in Spider Valve
This is 4-part video tutorial for Spider Valve MKII users on dialing in tones created by Line 6 Expert, Rowbi. Dialing In Spider Valve MKII Tones (Parts 1-4)
Images:
Read story →    0 comments    *****    software, tones, edit, spider and 4 more...
