Computer Based Recording
Pinned  Line 6 License Manager FAQ
May 09 2011 12:44 PM | Line6Tony in Computer Audio Set Up and Troubleshooting
Line 6 License Manager Video Tutorial.
Read story →    0 comments    *****    line 6, license, manager, faq and 5 more...
Pinned  USB Audio Troubleshooting
Nov 07 2006 02:47 AM | Line6Tony in Computer Audio Set Up and Troubleshooting
USB Audio Troubleshooting.
Audio optimization.
Read story →    0 comments    *****    usb, audio, troubleshooting and 7 more...
POD Farm 2 Dual Tone Presets within Reason'...
Nov 22 2013 11:19 AM | Line6Hugo in POD Farm / POD Studio / TonePort
Français Deutsch The Line 6 Guitar Amp within Reason can only handle single tone presets, there is no way to load a POD Farm 2 Dual Tone preset into a single Line 6 Guitar Amp device.However, if you were to split the Dual tones and save each tone as it...
Read story →    0 comments    -----    pod, farm, preset, reason, record and 2 more...
Reason Limited Registration and ID Redemption
Oct 23 2013 02:07 PM | Line6Don in POD Farm / POD Studio / TonePort
Deutsch Français For POD Studio GX/UX1/UX2/KB37 owners who are having trouble receiving their bundled Reason Limited ID number please follow the steps below.If your POD Studio bundle included a Reason Limited Registration Code Card such as the one belo...
Read story →    0 comments    *****    reason, limited, pod studio, ux1 and 6 more...
POD Studio / TonePort : No Audio From Microphon...
Feb 26 2007 10:21 AM | Line6Tony in POD Farm / POD Studio / TonePort
English:The most common reason you would get no sound from your microphone is that you do not have the "Source Select" drop down menu set to Mic 1.This is located in the upper left hand corner of Gearbox (middle of the POD Farm application window, to t...
Read story →    0 comments    *****    pod, studio, toneport, audio and 3 more...
Line 6 Monkey Installation and F.A.Q.
Deutsch Français en Q: What is Line 6 Monkey? A: Line 6 Monkey is the intelligent updater for your Line 6 hardware and software products.Q: Is Line 6 Monkey compatible with my computer? A: The latest version of Line 6 Monkey is compatible on...
Read story →    0 comments    *****    monkey, line 6, update, flash and 6 more...
USB Compatibility with Line 6 Devices
Jun 10 2009 01:15 PM | Line6Tony in Computer Audio Set Up and Troubleshooting
Français Deutsch Q: Which type of USB is my Line 6 device compatible with? A: Most Line 6 USB products are compatible with USB 1.x and 2.0. The UX8 and POD X3 USB Devices are USB 2.0 exclusive devices. Connecting these to USB 1.x ports will result in...
Read story →    0 comments    *****    usb, compatibility, line 6 and 2 more...
Computer System Audio Optimization
Français Deutsch Q: How do I set up my computer to work with Line 6 gear? Make sure your Line 6 device is powered by the same power source as the computer (when applicable). Be sure that your system exceeds the minimum requirements listed on the p...
Read story →    0 comments    *****    usb, audio, optimization and 5 more...
Line 6 Edit FAQ
Français Deutsch Q: What is Line 6 Edit? A: Line 6 Edit is a free software application from Line 6 that provides complete editor/librarian features for the following products: POD XT/XTLive/Pro Bass POD XT/XTLive/Pro Vetta II Combo/Head Flextone II/...
Read story →    0 comments    *****    edit, faq, podxt, vetta, pod and 5 more...
The Line 6 Audio-MIDI Control Panel FAQ
Jan 23 2008 04:45 PM | Line6Tony in Computer Audio Set Up and Troubleshooting
Français Deutsch Explained below is a definition of the Line 6 Audio-MIDI Control Panel. It explains and defines the function of each setting within the application.The "Driver" tab Driver Operating at: The "Driver operating at:" status actually shows...
Read story →    0 comments    *****    driver, line 6, audio, midi and 3 more...
MAC OSX - Assigning Sound Card
May 14 2009 08:13 AM | Line6Tony in Computer Audio Set Up and Troubleshooting
Français Deutsch Once you have installed Line 6 Monkey and the applicable drivers for your Line 6 device, you will be able to assign your USB capable device as the sound card for your computer. See the following instructions for assigning your Line 6 d...
Read story →    0 comments    *****    mac, sound, card, assignment and 2 more...
How To Uninstall Line 6 Drivers From MAC OSX
Jan 26 2012 09:29 AM | Line6Tony in Computer Audio Set Up and Troubleshooting
Deutsch Français en To uninstall the Line 6 Drivers from a MAC OSX computer, use the Line 6 Driver Uninstaller that is located on the computer at following file location: Applications/Line 6/Drivers/Driver uninstaller If you have used the Driver...
Read story →    0 comments    *****    uninstall, mac, driver, line 6
Mac: USB Driver Installation
Aug 15 2013 02:29 PM | Line6Hugo in Computer Audio Set Up and Troubleshooting
Deutsch Français en In order for your computer to recognize your device when you are connected via USB, you will first need to install the appropriate drivers. Here is what you will need to do to install drivers on a Mac computer: 1) Download and...
Read story →    0 comments    *****    mac, driver, install, monkey and 3 more...
Windows: USB Device Driver Installation
Aug 15 2013 02:16 PM | Line6Hugo in Computer Audio Set Up and Troubleshooting
Deutsch Français en In order for your computer to recognize your device when you are connected via USB, you will first need to install the appropriate drivers. Here is what you will need to do to install drivers on a Windows computer: 1) Download...
Read story →    0 comments    *****    usb, driver, installation and 3 more...
POD Farm 2.5 Troubleshooting
May 27 2011 07:57 AM | Line6Tony in POD Farm / POD Studio / TonePort
Deutsch Français en 1. No Audio Input/Output from POD Farm 2.5 Standalone using a Line 6 Audio Interface This was a problem with POD Farm 2.50 that was fixed in 2.51. Windows Completely uninstall POD Farm 2.50, then, download and install POD F...
Read story →    0 comments    *****    pod, farm, troubleshooting and 1 more...
POD Farm 2.5 Setup
Jun 20 2012 09:01 AM | Line6Tony in POD Farm / POD Studio / TonePort
Deutsch Français en The POD Farm 2.5 software license, when purchased from our website online store, is a license that is placed on your Line 6 account. Nothing will be sent by mail. You can download the latest POD Farm 2.5x software free from o...
Read story →    0 comments    *****    pod, farm, 2.5, setup and 5 more...
OSX 10.9/GarageBand 10 won't authorize POD Farm 2
Feb 11 2014 02:38 PM | Line6Tony in POD Farm / POD Studio / TonePort
Version française. Deutsche Version. en We have discovered that even if you've authorized your POD Farm 2 license with Line 6 License Manager, GarageBand 10 on OSX 10.9 will not allow you to use POD Farm as an AU plug-in on an audio track. The plug-in...
Windows 7/8 Performance Settings
Nov 15 2013 04:17 PM | Line6Don in Computer Based Recording
Here are some helpful settings for both Windows 7 and Windows 8 that you can use to increase your peformance: In Windows 7 : - Go to the computer's Control Panel from the Start button menu.- 'View By' in top right corner should be changed to large o...
Read story →    0 comments    *****    windows, performance, settings and 2 more...
Installing Line 6 Software for a Macintosh (Tig...
May 07 2010 10:49 AM | Line6Tony in Computer Audio Set Up and Troubleshooting
These step-by-step instructions show how to install the necessary software to your Macintosh computer and properly connect your Line 6 device. This document will provide a great deal of information in terms of compatibility with your computer/audio har...
Read story →    0 comments    *****    software, installation, mac and 3 more...
Windows XP - Installing Line 6 Software
Aug 19 2009 10:44 AM | Line6Tony in Computer Audio Set Up and Troubleshooting
These step-by-step instructions show how to install the necessary software to your Windows XP computer and properly connect your Line 6 device. This document will also provide you with a great deal of information in terms of compatibility with your com...
Read story →    0 comments    *****    software, installation, xp and 4 more...
Windows Vista - Installing Line 6 Software
May 07 2010 10:14 AM | Line6Tony in Computer Audio Set Up and Troubleshooting
These step-by-step instructions show how to install the necessary software to your Windows Vista computer and properly connect your Line 6 device. This document will also provide a great deal of information in terms of compatibility with your computer/...
Read story →    0 comments    *****    software, installation, windows and 4 more...
Windows 7 - Installing Line 6 Software
May 07 2010 10:40 AM | Line6Tony in Computer Audio Set Up and Troubleshooting
These step-by-step instructions show how to install the necessary software to your Windows 7 computer and properly connect your Line 6 device. This document will provide a great deal of information in terms of compatibility with your computer/audio har...
Read story →    0 comments    *****    software, installation, program and 3 more...
POD Farm 2 General FAQ
Apr 30 2010 09:32 AM | Line6Tony in POD Farm / POD Studio / TonePort
Q: I purchased model packs for my Line 6 device. If I upgrade to POD Farm 2 do I lose my model packs? A: As long as you purchase a Line 6 license key upgrade for POD Farm 2 then all of your previously purchased model packs will work within POD Farm 2...
Read story →    0 comments    *****    pod, farm, faq, line 6
POD Farm 1.12: Release Notes and Known Issues
Apr 05 2010 08:31 AM | Line6Tony in POD Farm / POD Studio / TonePort
This installer provides a complete software package for POD Farm, the powerful amp and effects modeling plug-in for recording guitarists, delivering the industry-standard tone of POD to your DAW. Also included is the POD Farm standalone application, wh...
Read story →    0 comments    *****    pod, farm, release, notes, known and 1 more...
POD Farm 2.0 Upgrade Paths
Mar 25 2010 10:07 AM | Line6Tony in POD Farm / POD Studio / TonePort
Below you can find the different POD Farm 2.0 upgrade scenarios based on when and how you purchased POD Farm version 1. Please see the Line 6 web store for all discount prices that you qualify for. For pricing details please click on the link to the on...
Read story →    0 comments    *****    pod, farm, upgrade, paths, line 6
POD Farm 2.0: Release Notes and Known Issues
Mar 25 2010 08:12 AM | Line6Tony in POD Farm / POD Studio / TonePort
This installer provides a complete software package for POD Farm 2, the powerful amp and effects modeling plug-in for recording guitarists, delivering the industry-standard tone of POD to your DAW. Also included is the POD Farm standalone application,...
Read story →    0 comments    *****    pod, farm, release, notes, known and 2 more...
ProTools & POD Studio Hardware Devices
Feb 17 2010 10:06 AM | Line6Tony in POD Farm / POD Studio / TonePort
Many new users have contacted us with questions regarding the usage of Line 6 POD Studio USB audio interfaces in conjunction with AVID's ProTools recording software. Here are a few important things to be aware of: ProTools version 8.05 or earlier re...
Read story →    0 comments    *****    pro, tools, pod, studio and 3 more...
POD Farm DAW Compatibility
Jun 23 2009 01:53 PM | Line6Tony in POD Farm / POD Studio / TonePort
Line 6 generally tests with software Digital Audio Workstations (DAW) that are the latest and the last freely upgradeable versions. Line 6 does not test on 3rd party applications that are no longer supported by their own developers. While we use a wid...
Read story →    0 comments    *****    pod, farm, daw, compatibility and 1 more...
Ableton Live Lite 7: Known Documentation Point...
Jan 27 2009 11:43 AM | Line6Tony in POD Farm / POD Studio / TonePort
For those getting started with a POD Studio GX/UX1/UX2 device and following through the Ableton Live Lite 7 tutorial, there has been some inquiries of confusion regarding page 5/12 in the starting tutorial. There is reference to the Line 6 Audio-MIDI...
Read story →    0 comments    *****    ableton, midi, cc, mapping and 3 more...
iLok General FAQ and Deposit Process
Dec 17 2008 05:43 PM | Line6Tony in POD Farm / POD Studio / TonePort
Q: What is an iLok? A: The iLok is a proprietary USB hardware dongle that holds licenses for software protected by PACE Anti-Piracy's Interlok.About The iLok : https://www.ilok.com/ilok.html Q: How do I activate my POD Farm iLok purchase? A: After y...
Read story →    0 comments    *****    ilok, faq, deposit, pod, farm and 1 more...
POD Farm Platinum: Product Definition
Nov 01 2008 12:05 PM | Line6Tony in POD Farm / POD Studio / TonePort
Before we get into defining "Platinum", it's important to know that POD Farm comes in two distinct flavors: 1. As a plug in tied to a Line 6 device OR 2. As a plug in tied to an iLok key The difference between POD Farm and POD Farm Platinum, rega...
Read story →    0 comments    *****    pod, farm, platinum, definition and 1 more...
POD Farm 1: Upgrade & Pricing Questions
Oct 29 2008 10:58 AM | Line6Tony in POD Farm / POD Studio / TonePort
Q: How do I get the POD Farm Plug-in? A: POD Farm is now a factory-enabled feature available free for POD X3, POD X3 Live, POD X3 Pro, TonePort DI, TonePort UX8, and all of the POD Studio computer interfaces. Use the Line 6 License Manager software t...
Read story →    0 comments    *****    pod, farm, upgrade, pricing and 1 more...
POD Farm 1 FAQ
Oct 29 2008 10:16 AM | Line6Tony in POD Farm / POD Studio / TonePort
Q: What is POD Farm? A: POD Farm is Line 6's new plug-in software platform that will offer POD tone to any DAW. For use with either a Line 6 hardware interface or iLok dongle, POD Farm can easily be used with all the major software recording platfo...
Read story →    0 comments    *****    pod, farm, general, questions and 1 more...
POD Farm 1: System Requirements
Oct 29 2008 09:59 AM | Line6Tony in POD Farm / POD Studio / TonePort
POD Farm 1.0 System Requirements Windows® Pentium 4 -1.2GHz or better (2.5 GHz or better, or multi-core CPU recommended) Windows® XP® (with SP2 or SP3), Windows® XP® X64, Windows® Vista® (including SP1), Windows® Vista® X64® 512 MB RAM minimum (1...
Read story →    0 comments    *****    pod, farm, system, requirements and 3 more...
