Computer Based Recording
POD Farm 2.5 Frequently Asked Questions
May 16 2011 03:55 PM | Line6Tony in POD Farm / POD Studio / TonePort
Pod Farm iLok Licenses are not subject to model pack purchases. Only Pod Farm Standard for iLok and Pod Farm Platinum for iLok are applicable to iLok licensing and model pack additions do not apply. What is it? POD Farm 2.5 and POD Farm 2.5 Platinum a...
Read story →    0 comments    *****    pod, farm, faq, line 6
Using POD Farm 1 and POD Farm 2.51 on the same...
Jul 07 2011 11:48 AM | Line6Tony in POD Farm / POD Studio / TonePort
Installing POD Farm 1 after installing POD Farm 2 can corrupt the POD Farm system files. This will cause all versions of POD Farm 1 and 2 not function correctly. The workaround is to uninstall both versions of POD Farm 1 and 2, and then install POD Far...
Read story →    0 comments    *****    pod, farm, same, computer, line 6
TonePort / POD Studio KB37: FAQ
Apr 23 2008 11:19 AM | Line6Tony in POD Farm / POD Studio / TonePort
Q: What is the KB37 used primarily for? A: It is a 37-key USB MIDI keyboard/control surface and TonePort USB audio interface. The KB37 will be able to send and receive MIDI CC information and process audio input and output across the USB connection...
Read story →    0 comments    *****    kb37, pod, studio, toneport, farm and 3 more...
TonePort UX8: A/D Converters
Oct 24 2007 09:43 AM | Line6Tony in POD Farm / POD Studio / TonePort
Q: What quality are the UX8's A/D converters? A: The UX-8 uses the same converter chip that the Apogee Ensemble ($1949), Echo Audiofire 12 ($699), Focusrite Saffire Pro ($699) and probably more use. A/D Conversion: 16-bit & 24-bit 44.1, 48,...
Read story →    0 comments    *****    toneport, ux8, a/d, converter and 1 more...
TonePort UX8: FAQ
Oct 01 2007 03:32 PM | Line6Tony in POD Farm / POD Studio / TonePort
TonePort UX8 Frequently Asked Questions Q: Is TonePort™ UX8 an audio interface or software? Does it record? A: TonePort UX8 is a USB audio interface. Every TonePort audio interface works with the included GearBox™ modeling software as an integrat...
Read story →    0 comments    *****    toneport, ux8, line 6, windows and 5 more...
Using Dual Inputs with Ableton Live Lite &...
Feb 14 2007 09:24 AM | Line6Tony in POD Farm / POD Studio / TonePort
Please use the directions below in order to record two inputs from a TonePort/POD Studio UX1/UX2 USB device from POD Farm simultaneously:In POD Farm: Create a dual tone input in POD Farm (i.e. Mic 1 & 2, Line 1 & 2, Inst & Mic, etc).In Your...
Read story →    0 comments    *****    dual, input, daw, abletone and 3 more...
Ableton Live Lite: Lost Activation Key
Feb 06 2007 04:22 PM | Line6Tony in POD Farm / POD Studio / TonePort
Please send an e-mail to: orders@ableton.com Subject: "Lost my Ableton Live Lite serial number". Body: The name of the Line 6 USB hardware device that your copy of Live Lite came bundled with. Attachment: Proof of purchase of Line 6 USB hardware de...
Read story →    0 comments    *****    ableton, live, lite, activation and 3 more...
Uninstall USB Filter Driver to Avoid Blue Scree...
Mar 07 2011 10:44 AM | Line6Tony in Computer Audio Set Up and Troubleshooting
There is a known compatibility issue with current Line 6 drivers and the AMD USB Filter driver that comes preinstalled on several AMD computers including HP and Compaq. This issue materializes in the form of constant blue screens when connecting a Line...
Read story →    0 comments    ***--    usb, amd, filter, blue, screen and 3 more...
No Output from POD Studio / TonePort Interface
Nov 07 2006 02:47 AM | Line6Tony in POD Farm / POD Studio / TonePort
Once you've installed the latest drivers for your Line 6 USB device on your computer's operating system, connect audio monitors/speakers to the audio outputs of your Line 6 USB device or use the headphone output jack. The built-in soundcard output of...
Read story →    0 comments    *****    pod, studio, toneport, no, output and 4 more...
Windows XP - Assigning Sound Card
May 13 2009 02:23 PM | Line6Tony in Computer Audio Set Up and Troubleshooting
Once you have installed Line 6 Monkey and the applicable drivers for your Line 6 device, you will be able to assign your USB capable device as the sound card for your computer. See the following instructions for assigning your Line 6 device as a sound...
Read story →    0 comments    *****    windows, xp, assigning, sound and 3 more...
Windows Vista - Assigning Sound Card
May 13 2009 02:40 PM | Line6Tony in Computer Audio Set Up and Troubleshooting
Read story →    0 comments    *****    windows, vista, assign, sound and 3 more...
POD Studio / TonePort : Phantom Power Explained
Feb 26 2007 10:27 AM | Line6Tony in POD Farm / POD Studio / TonePort
Phantom power is DC (or direct current) used to power certain microphones, the UX2 and KB37 offer 48-Volt signal to a condenser microphone by connecting it to the XLR input on the unit. The UX1 does not have phantom power, if you have a microphone tha...
Read story →    0 comments    *****    pod studio, toneport, phantom and 3 more...
GuitarPort Online Complete Troubleshooting Guid...
Mar 27 2009 08:00 AM | Line6Tony in Computer Audio Set Up and Troubleshooting
IMPORTANT ANNOUNCEMENT: We're sad to say that GuitarPort Online is no longer accepting new subscriptions, and will be closing its doors on July 31st, 2012. Why is GuitarPort going away? Since the release of GuitarPort Online, many other companies...
Read story →    0 comments    *****    gpo, guitar, port, online and 3 more...
Tablet PC
Jun 17 2009 03:34 PM | Line6Tony in Computer Audio Set Up and Troubleshooting
Currently, Line 6 does not test any of our products on Tablet or Netbook style PC's. While it may be possible to get the hardware and software to work together or separately, we cannot guarantee that your Line 6 USB device can be used as intended on th...
Read story →    0 comments    *****    tablet, compatibility, line 6 and 1 more...
Power PC and Intel Mac Driver Compatibility
Oct 23 2012 10:35 AM | Line6Tony in POD Farm / POD Studio / TonePort
Starting with Mac OS X driver 5.1.2 , our Mac drivers for our products are compatible with Intel Macs only . Unfortunately, it isn't practical for us to continiue to support platforms such as Power PC that the manufacturer (Apple) no longer supports. P...
Read story →    0 comments    *****    power pc, mac, os, macintosh and 3 more...
Mac OS X 10.8 Mountain Lion Audio Problems
Jan 15 2013 09:24 AM | Line6Tony in POD Farm / POD Studio / TonePort
A small number of Mac OS X 10.8 Mountain Lion customers have reported problems with noise or distortion occurring intermittently when recording or playing back audio over USB with Line 6 devices. Mac Driver 7.2.4 implements several changes which should...
Read story →    0 comments    *****    mac, os, mountain, lion, audio and 5 more...
64-Bit Operating System Support
Dec 21 2007 10:48 AM | Line6Tony in Computer Audio Set Up and Troubleshooting
Q: Does Line 6 offer a 64-bit driver for stand-alone applications? A: Line 6 offers a 64-bit compatible driver for Windows XP, Vista and 7 platforms as well as compatible drivers for 64 bit Kernel installs of Mac OSX. You can download the latest com...
Read story →    0 comments    *****    64bit, compatibility, operating and 7 more...
Software/Hardware Compatibility Chart
Apr 14 2009 09:37 AM | Line6Tony in Computer Audio Set Up and Troubleshooting
Attached is a downloadable .pdf file of our software/hardware compatibility between Line 6 devices: Line 6 Software Descriptions Gearbox : is an interface and editing software for GuitarPort, TonePort, POD Studio, PODxt and POD X3 series devices. Ge...
Read story →    0 comments    *****    software, hardware, compatibility and 3 more...
Line 6 Tone File Compatibility Chart
Aug 14 2013 07:09 AM | Line6Hugo in Computer Audio Set Up and Troubleshooting
TONE COMPATIBILITY CHART Below is a .pdf file that contains tone file type compatibility between Line 6 hardware and software. Misc. Notes: - POD Farm 1 tones work with Gearbox when connected to X3 but not PF2 tones - Tones created in POD Farm Plug-In...
Read story →    0 comments    *****    tone, file, compatibility, chart and 2 more...
RiffWorks Standard Installation FAQ
Oct 14 2009 03:15 PM | Line6Tony in Riffworks Line 6 / Standard Edition
This document covers the registration and installation of Riffworks Standard 2.5. 1) Once you have purchased the RiffWorks standard licence, locate your license under "software license keys" at the following link: http://line6.com/account/purchasehis...
Read story →    0 comments    *****    riffworks, standard, activation and 6 more...
RiffWorks 2 Line 6 Edition: Download and Activa...
Nov 07 2006 02:47 AM | Line6Tony in Riffworks Line 6 / Standard Edition
Line 6 is no longer selling license keys for Riffworks 1 or 2 Line 6 Edition. If you have previously purchased a license key for this software you can download the software from http://line6.com/software/ , however, license keys for these versions of R...
Read story →    0 comments    *****    riffworks, rifftracker and 6 more...
RiffWorks Line 6 Edition: FAQ
RiffWorks Application Support: For application usage support, please visit Sonoma Wire Works (the creators of RiffWorks Software) at: Sonoma Wire Works Support NOTES: RiffWorks Line 6 Edition is discontinued and the license can no longer be p...
Read story →    0 comments    *****    riffworks, drummers, activation and 7 more...
Line 6 Edit: Transferring Patches (Downloaded o...
Nov 07 2006 02:47 AM | Line6Tony in Computer Audio Set Up and Troubleshooting
Step 1 : First, you will need to know where your tones reside on your computer. In this example, the path/location will be: C:\Documents and Settings\(User Account Name)\My Documents\Line 6\Tones\Line 6 Edit\Downloaded Tones. Keep in mind that "Downloa...
Read story →    0 comments    *****    edit, transfer, presets, patches and 6 more...
