Computer Audio Set Up and Troubleshooting
Pinned  Line 6 License Manager FAQ
May 09 2011 12:44 PM | Line6Tony in Computer Audio Set Up and Troubleshooting
Line 6 License Manager Video Tutorial.
Read story →    0 comments    *****    line 6, license, manager, faq and 5 more...
Pinned  USB Audio Troubleshooting
Nov 07 2006 02:47 AM | Line6Tony in Computer Audio Set Up and Troubleshooting
USB Audio Troubleshooting.
Audio optimization.
Read story →    0 comments    *****    usb, audio, troubleshooting and 7 more...
MAC OSX - Assigning Sound Card
May 14 2009 08:13 AM | Line6Tony in Computer Audio Set Up and Troubleshooting
Français Deutsch Once you have installed Line 6 Monkey and the applicable drivers for your Line 6 device, you will be able to assign your USB capable device as the sound card for your computer. See the following instructions for assigning your Line 6 d...
Read story →    0 comments    *****    mac, sound, card, assignment and 2 more...
Deutsch Français en Q: What is Line 6 Monkey? A: Line 6 Monkey is the intelligent updater for your Line 6 hardware and software products.Q: Is Line 6 Monkey compatible with my computer? A: The latest version of Line 6 Monkey is compatible on...
Read story →    0 comments    *****    monkey, line 6, update, flash and 6 more...
USB Compatibility with Line 6 Devices
Jun 10 2009 01:15 PM | Line6Tony in Computer Audio Set Up and Troubleshooting
Français Deutsch Q: Which type of USB is my Line 6 device compatible with? A: Most Line 6 USB products are compatible with USB 1.x and 2.0. The UX8 and POD X3 USB Devices are USB 2.0 exclusive devices. Connecting these to USB 1.x ports will result in...
Read story →    0 comments    *****    usb, compatibility, line 6 and 2 more...
Computer System Audio Optimization
Français Deutsch Q: How do I set up my computer to work with Line 6 gear? Make sure your Line 6 device is powered by the same power source as the computer (when applicable). Be sure that your system exceeds the minimum requirements listed on the p...
Read story →    0 comments    *****    usb, audio, optimization and 5 more...
Line 6 Edit FAQ
Français Deutsch Q: What is Line 6 Edit? A: Line 6 Edit is a free software application from Line 6 that provides complete editor/librarian features for the following products: POD XT/XTLive/Pro Bass POD XT/XTLive/Pro Vetta II Combo/Head Flextone II/...
Read story →    0 comments    *****    edit, faq, podxt, vetta, pod and 5 more...
The Line 6 Audio-MIDI Control Panel FAQ
Jan 23 2008 04:45 PM | Line6Tony in Computer Audio Set Up and Troubleshooting
Français Deutsch Explained below is a definition of the Line 6 Audio-MIDI Control Panel. It explains and defines the function of each setting within the application.The "Driver" tab Driver Operating at: The "Driver operating at:" status actually shows...
Read story →    0 comments    *****    driver, line 6, audio, midi and 3 more...
How To Uninstall Line 6 Drivers From MAC OSX
Jan 26 2012 09:29 AM | Line6Tony in Computer Audio Set Up and Troubleshooting
Deutsch Français en To uninstall the Line 6 Drivers from a MAC OSX computer, use the Line 6 Driver Uninstaller that is located on the computer at following file location: Applications/Line 6/Drivers/Driver uninstaller If you have used the Driver...
Read story →    0 comments    *****    uninstall, mac, driver, line 6
Mac: USB Driver Installation
Aug 15 2013 02:29 PM | Line6Hugo in Computer Audio Set Up and Troubleshooting
Deutsch Français en In order for your computer to recognize your device when you are connected via USB, you will first need to install the appropriate drivers. Here is what you will need to do to install drivers on a Mac computer: 1) Download and...
Read story →    0 comments    *****    mac, driver, install, monkey and 3 more...
Windows: USB Device Driver Installation
Aug 15 2013 02:16 PM | Line6Hugo in Computer Audio Set Up and Troubleshooting
Deutsch Français en In order for your computer to recognize your device when you are connected via USB, you will first need to install the appropriate drivers. Here is what you will need to do to install drivers on a Windows computer: 1) Download...
Read story →    0 comments    *****    usb, driver, installation and 3 more...
Installing Line 6 Software for a Macintosh (Tig...
May 07 2010 10:49 AM | Line6Tony in Computer Audio Set Up and Troubleshooting
These step-by-step instructions show how to install the necessary software to your Macintosh computer and properly connect your Line 6 device. This document will provide a great deal of information in terms of compatibility with your computer/audio har...
Read story →    0 comments    *****    software, installation, mac and 3 more...
Windows XP - Installing Line 6 Software
Aug 19 2009 10:44 AM | Line6Tony in Computer Audio Set Up and Troubleshooting
These step-by-step instructions show how to install the necessary software to your Windows XP computer and properly connect your Line 6 device. This document will also provide you with a great deal of information in terms of compatibility with your com...
Read story →    0 comments    *****    software, installation, xp and 4 more...
Windows Vista - Installing Line 6 Software
May 07 2010 10:14 AM | Line6Tony in Computer Audio Set Up and Troubleshooting
These step-by-step instructions show how to install the necessary software to your Windows Vista computer and properly connect your Line 6 device. This document will also provide a great deal of information in terms of compatibility with your computer/...
Read story →    0 comments    *****    software, installation, windows and 4 more...
Windows 7 - Installing Line 6 Software
May 07 2010 10:40 AM | Line6Tony in Computer Audio Set Up and Troubleshooting
These step-by-step instructions show how to install the necessary software to your Windows 7 computer and properly connect your Line 6 device. This document will provide a great deal of information in terms of compatibility with your computer/audio har...
Read story →    0 comments    *****    software, installation, program and 3 more...
Uninstall USB Filter Driver to Avoid Blue Scree...
Mar 07 2011 10:44 AM | Line6Tony in Computer Audio Set Up and Troubleshooting
There is a known compatibility issue with current Line 6 drivers and the AMD USB Filter driver that comes preinstalled on several AMD computers including HP and Compaq. This issue materializes in the form of constant blue screens when connecting a Line...
Read story →    0 comments    ***--    usb, amd, filter, blue, screen and 3 more...
Windows XP - Assigning Sound Card
May 13 2009 02:23 PM | Line6Tony in Computer Audio Set Up and Troubleshooting
Once you have installed Line 6 Monkey and the applicable drivers for your Line 6 device, you will be able to assign your USB capable device as the sound card for your computer. See the following instructions for assigning your Line 6 device as a sound...
Read story →    0 comments    *****    windows, xp, assigning, sound and 3 more...
Windows Vista - Assigning Sound Card
May 13 2009 02:40 PM | Line6Tony in Computer Audio Set Up and Troubleshooting
Read story →    0 comments    *****    windows, vista, assign, sound and 3 more...
GuitarPort Online Complete Troubleshooting Guid...
Mar 27 2009 08:00 AM | Line6Tony in Computer Audio Set Up and Troubleshooting
IMPORTANT ANNOUNCEMENT: We're sad to say that GuitarPort Online is no longer accepting new subscriptions, and will be closing its doors on July 31st, 2012. Why is GuitarPort going away? Since the release of GuitarPort Online, many other companies...
Read story →    0 comments    *****    gpo, guitar, port, online and 3 more...
Tablet PC
Jun 17 2009 03:34 PM | Line6Tony in Computer Audio Set Up and Troubleshooting
Currently, Line 6 does not test any of our products on Tablet or Netbook style PC's. While it may be possible to get the hardware and software to work together or separately, we cannot guarantee that your Line 6 USB device can be used as intended on th...
Read story →    0 comments    *****    tablet, compatibility, line 6 and 1 more...
64-Bit Operating System Support
Dec 21 2007 10:48 AM | Line6Tony in Computer Audio Set Up and Troubleshooting
Q: Does Line 6 offer a 64-bit driver for stand-alone applications? A: Line 6 offers a 64-bit compatible driver for Windows XP, Vista and 7 platforms as well as compatible drivers for 64 bit Kernel installs of Mac OSX. You can download the latest com...
Read story →    0 comments    *****    64bit, compatibility, operating and 7 more...
Software/Hardware Compatibility Chart
Apr 14 2009 09:37 AM | Line6Tony in Computer Audio Set Up and Troubleshooting
Attached is a downloadable .pdf file of our software/hardware compatibility between Line 6 devices: Line 6 Software Descriptions Gearbox : is an interface and editing software for GuitarPort, TonePort, POD Studio, PODxt and POD X3 series devices. Ge...
Read story →    0 comments    *****    software, hardware, compatibility and 3 more...
Line 6 Tone File Compatibility Chart
Aug 14 2013 07:09 AM | Line6Hugo in Computer Audio Set Up and Troubleshooting
TONE COMPATIBILITY CHART Below is a .pdf file that contains tone file type compatibility between Line 6 hardware and software. Misc. Notes: - POD Farm 1 tones work with Gearbox when connected to X3 but not PF2 tones - Tones created in POD Farm Plug-In...
Read story →    0 comments    *****    tone, file, compatibility, chart and 2 more...
Line 6 Edit: Transferring Patches (Downloaded o...
Step 1 : First, you will need to know where your tones reside on your computer. In this example, the path/location will be: C:\Documents and Settings\(User Account Name)\My Documents\Line 6\Tones\Line 6 Edit\Downloaded Tones. Keep in mind that "Downloa...
Read story →    0 comments    *****    edit, transfer, presets, patches and 6 more...
