Search Articles
Recent Comments
cab cabinet ohm connection load resistance external speaker head wiring stereo
Deutsch
Français
Q: What are the common ohm ratings for guitar speaker cabinets?
A: The common ohm ratings are 16, 8, and 4 ohms. It is important to look at the cabinet inputs to correctly match the rating for your setup to ensure the optimal output and performance of your amplifier. While some ohm mismatches are acceptable, other ohm mismatches can cause failure in your amplifier's power amp section.
REMEMBER: Impedance is measured in ) ohms. Impedance determines how much current will flow through a component. A very high impedance allows a small amount of current to flow (i.e. a 16 ohm speaker load draws less current than an 8 ohm amp is ready to supply, but it will work safely). A very low impedance allows a large amount of current to flow (i.e. a 4 ohm speaker load draws too much current from an 8 ohm amp, ultimately overheating the amp).
Unacceptable Ohm Mismatches: When connecting any amplifier to an external cabinet it is important to keep in mind that the ohm load of your cabinet should not be lower in number than the ohm rating of your amplifier (which can cause the amplifier to fail). I.e. - If the amp output has an overall rating of 8 ohms DO NOT run with an external cab that has an overall rating of 4 ohms.
Acceptable Ohm Mismatches: It is acceptable to run the overall ohm load output of an amplifier to a cabinet that is higher in number. I.e. If your amp output has an overall output rating of 8 ohms you can run into an external cabinet that has an overall rating of 16 ohms. Be aware that you will lose ~15-20 percent of perceived volume with solid state power amplifiers when running this type of ohm mismatch, but you will suffer no failures.
Q: Can I run two cabinets with different ohm ratings?
A: We do not recommend running cabinets with different ohm ratings, as it may create an ohm load that your amplifier will not recognize and can possibly damage the power amp output section.
Q: How do I connect my Line 6 amplifier to the external speaker cabinet?
A: Your manual should explain most situations you would run into. Feel free to contact us and ask questions re: specific setups not covered in the manual and we will add them to this document. For example:
Attached Image: cabinet connection example.PNG
Q: Can I run my Line 6 amplifier without a speaker load (i.e. not connected to a speaker)
A: All Line 6 amplifiers (with the exception of the Spider valve series) are safe to run without any speaker load connected. The DT series and Spider Valve series amps **must have a speaker load connected to avoid damage to the output transformer.**
Spider II, III, IV Cabinet Wiring
- The Spider II & III HD150s are set up with 8 ohm stereo outputs to match the Spider cabs. You will want to use two speaker cables to connect to both jacks of the cabinet. If you do not connect both speaker outputs to an 8 ohm load (or higher) you can suffer a power amp failure.
- Spider II & III HD75s runs 4 ohms mono. You will want to use two speaker cables to run the 8 ohms stereo cabinet from the head to the cab (creating a 4 ohm load) If you only use one cable, you may only get two of the four speakers to function.
- Please consult the labeling on the cabinet or use a multi-meter to measure the ohm rating to ensure you will not induce failure with an incorrect connection.
Q: Is there a video tutorial where I can see different cabinet connection options?
A: Line 6 Head and Cabinet Connections
Q: I am running my Spider HD with a cabinet from a different manufacturer which has a different ohm configuration that what the Spider HD needs. What can I do?
A: Please see the previous information on acceptable ohm mismatches. If the ohm mismatch is not acceptable you may need to have your cabinet modified to conform to the needs of the Spider HD series. Please have this modification performed at your nearest Line 6 Service Center.
Q: What are the wattage outputs and ohm loads on the Line 6 amplifiers not already discussed?
Vetta/Vetta II HD
300W:4/8/16 ohms
HD147
300W:4/8/16 ohms
Flextone II HD
200W 2X12:4/8/16 ohms
Flextone HD
300W:4/8/16 ohm
Duoverb HD
100W:4/8 ohm
F.A.Q.: Boxenverbindungen und Ohm
Welche sind die üblichen Impedanzen für Gitarren Lautsprecherboxen?
Die üblichen Impedanzen sind 16, 8 und 4 Ω. Es ist wichtig, sich die Eingänge der Box genau anzusehen um die Impedanz optimal auf Ihr Setup anzupassen und so eine optimale Ausgangsleistung des Verstärkers zu erhalten. Während manche Ohm-Diskrepanzen akzeptabel sind, können wiederum andere zum Versagen der Endstufe führen.
  • Impedanz wird in Ohm gemessen. Die Impedanz legt fest, wieviel Strom durch eine Komponente fließt. Eine sehr hohe Impedanz sorgt dafür, dass nur eine geringe Menge Strom fließt (z.B.: ein 16 Ω Lautsprecher braucht weniger Strom als ein 8 Verstärker leisten kann, funktioniert jedoch gefahrlos.). Eine sehr niederige Impedanz hingegen lässt eine große Menge Strom fließen (z.B.: ein 4 Ω Lautsprecher zieht zu viel Strom für einen 8 Ω Verstärker und führt zur Überhitzung des Verstärkers.).
Inakzeptable Ohm-Diskrepanzen: Wenn Sie einen Verstärker an eine externe Box anschließen ist es wichtig, dass die Impedanz der Box nicht tiefer ist als die des Verstärkers (was dazu führen kann, dass der Verstärker ausfällt.). Z.B.: Wenn die Ausgabe des Verstärkers eine Impedanz von 8 Ω hat, dürfen Sie AUF KEINEN FALL eine Lautsprecherbox benutzen, die nur 4 Ω Impedanz hat.
Akzeptable Ohm-Diskrepanzen: Eine Ohm-Diskrepanz ist akzeptabel, wenn die Impedanz eines Verstärkers, den Sie an eine Box anschließen niedriger ist als die der Box. Z.B.: Wenn die Ausgabe des Verstärkers eine Impedanz von 8 Ω hat, können Sie eine externe Box benutzen, mit 16 Ω Impedanz. Aber Achtung, Sie werden ca. 15-20% Lautstärke mit einer Transistorendstufe verlieren wenn Sie diese Art Setup benutzen, aber es wird ohne Ausfall funktionieren.
Kann ich zwei verschiedene Boxen benutzen, die verschiedene Impedanzen haben?
Wir empfehlen die Nutzung von Boxen mit verschiedenen Impedanzen NICHT, da dies eine Impedanz erzeugen kann, die der Verstärker nicht erkennt und kann so auch die Endstufe beschädigen.
Wie schließe ich meinen Line 6 Verstärker an eine externe Box an?
In Ihrem Benutzerhandbuch sollte dies für die meisten Situationen ausführlch beschrieben sein. Bitte kontaktieren Sie uns und stellen Sie jegliche Fragen über Setups die nicht im Benutzerhandbuch aufgeführt sind und wir werden diese an dieses Dokument anhängen. Z.B.:
Kann ich meinen Line 6 Verstärker ohne Box benutzen?
Alle Line 6 Geräte können auch betrieben werden ohne, dass eine Box an diesen angeschlossen ist (mit Ausnahme der Spider Valve Serie). **ACHTUNG, die DT und Spider Valve Serien müssen eine Box angeschlossen haben um jeglichen Schaden zu vermeiden.**
Verkabelung der Spider II, II, IV Boxen
  • Die Spider II & III HD 150 Boxen haben 8 Ω Ausgänge um den Spider Boxen zu entsprechen. Sie brauchen 2 Lautsprecherkabel, um diese an beide Klickenbuchsen der Box anzuschließen. Sollten Sie nicht beide Lautsprecherausgänge an eine 8 Ω Impedanz anschließen, kann Ihre Endstufe versagen.
  • Spider II & III HD 75 Boxen haben 4 Ω Mono Ausgänge. Sie brauchen 2 Lautsprecherkabel, um die 8 Ω Stereo Box zu benutzen (was einee 4 Ω Impedanz erzeugt). Sollten Sie hier nur ein Kabel benutzen funktionieren nur 2 der 4 Lautsprecher.
  • Benutzen Sie bitte die Beschriftung auf der Box oder ein Multimeter um die Impedanz zu messen. So können Sie einen Ausfall aufgrund falscher Impedanz ausschließen.
Gibt es ein Videotutorial über die verschiedenen Boxen Anschlüsse?
Line 6 Head and Cabinet Connections (Englisch)
Ich benutze mein Spider HD mit einer Box eines anderen Herstellers, welche eine unterschiedliche Impedanz hat als die, die mein Spider HD braucht. Was kann ich tun?
Bitte schauen Sie sich dazu die vorherigen Informationen über akzeptable und inakzeptable Ohm-Diskrepazen an, wenn diese inakzeptabel ist kann es sein, dass Sie Ihre Box modifizieren müssen, damit Sie dem Spider HD entspricht. Bitte lassen Sie diese Modifikation im nächstgelegenen Line 6 Service Center durchführen.
Welche ist die Wattleistung und Impedanz anderer, noch nicht beschriebener, Line 6 Verstärker?
Vetta/Vetta II HD
300W; 4/8/16 Ω
HD147
300W; 4/8/16 Ω
Flextone II HD
200W 2X12; 4/8/16 Ω
Flextone HD
300W; 4/8/16 Ω
Duoverb HD
100W; 4/8 Ω
F.A.Q.: Haut-parleur et ohm:
Quels sont les impédances communes pour les baffles guitare?
Les impédances communes sont 16, 8 et 4 Ω. C'est important de vérifier l'impédance de l'entrée du baffle guitare pour égaler cette impédance à votre système afin de recevoir une sortie et performance optimale de l'ampli. Pendant que quelques discordances sont acceptables, autres peuvent causer un échec dans la section ampli de puissance.
  • L'impédance est mesurée en ohms Ω. L'impédance mesure la circulation du courant dans un composant. Une impédance très haute permet à une petite quantité de courant de circuler. (Par exemple, un haut-parleur de 16 Ω consommé moins de courant qu'un 8 Ω ampli peut fournir. Mais ce setup fonctionne en toute sécurité.) Une impédance très basse permet à une grande quantité de courant de circuler. (Par exemple, un haut-parleur de 4 Ω consommé trop de courant pour un ampli de 8 Ω. Ce setup surchauffe l'ampli.)
Discordances ohms inacceptables: Si vous connectez un amplificateur à un haut-parleur externe, c'est important de savoir que l'impédance du haut-parleur ne peut pas être plus basse que l'impédance de l'amplificateur. (Échec de l'ampli) Par exemple, si l'amplificateur a une impédance de sortie de 8 Ω, vous ne pouvez pas utiliser un haut-parleur externe de 4 Ω.
Discordances ohms acceptables: C'est acceptable d'avoir un haut-parleur avec une impédance d'entrée plus haut que la sortie de l'amplificateur. Par exemple: Si la sortie de l'ampli a une impédance de 8 Ω, vous pouvez utiliser un haut-parleur avec une impédance de 16 Ω. Attention, vous perdez 15-20% de volume avec un amplificateur de puissance à semi-conducteur si vous exécutez cette configuration mais vous ne souffrez aucun échec.
Est-ce que je peux utiliser deux haut-parleurs avec des impédances différents?
Nous ne recommandons pas l'utilisation de deux haut-parleurs avec des impédances différents. Ce peut causer une impédance, l'ampli ne sait pas reconnaitre et peut endommager la sortie de l'ampli de puissance.
Comment est-ce que je peux connecter mon ampli Line 6 à l'haut-parleur externe?
Le manuel d'utilisation devrait expliquer la plupart des situations. N'hésitez pas à nous contacter et poser des questions sur les configurations spécifiques et nous les ajoutons à ce document. Par exemple:
Est-ce que je peux utiliser mon ampli Line 6 sans impédance?
Tous les amplis Line 6 (série Spider Valce exceptée) peuvent-être utilisés sans impédance haut-parleur connecté. ** Les séries DT et Spider Valve doivent avoir connecté une impédance haut-parleur pour éviter les dommages au transformateur de sortie. **
Spider II, III et IV: câblage du haut-parleur
  • Les Spider II et II HD150s sont configurés avec des sorites 8 Ω stéréo pour correspondre aux haut-parleurs Spider. Vous avez besoin de deux câbles haut-parleurs pour connecter les deux jacks du haut-parleur. Si vous ne connectez pas les deux sorties à une impédance de 8 Ω, vous pouvez souffrir d'une insuffisance ampli de puissance.
  • Spider II et III HD75s sont configurés avec des sorties 4 Ω mono. Vous avez besoin de deux câbles haut-parleurs pour utiliser l'haut-parleur 8 Ω stéréo. (créant une impédance 4 Ω) Si vous utilisez un seul câble, seulement deux des quatre haut-parleurs fonctionnent.
  • Utilisez l'étiquetage sur l'haut-parleur ou un multimètre pour mesurer l'impédance pour vous assurer que vous ne provoquez aucun échec avec une connexion incorrecte.
Est-ce qu'il y en a un vidéo tutoriel concernant les options de connexion du haut-parleur?
Line 6 Head and Cabinet Connections (anglais)
J'utilise le Spider HD avec un haut-parleur d'un fabricant différent, ce haut-parleur a une configuration d'impédance différente que mon Spider HD a besoin. Qu'est-ce que je peux faire?
Veuillez consulter les informations précédentes sur les discordances ohms acceptables. Si la discordance ohm est inacceptable, c'est possible que vous avez besoin de modifier l'haut-parleur afin de le conformer au Spider HD. Veuillez faire effectuer cette modification au centre de service Line 6 le plus proche.
Quels sont les puissances en watts des sorties des amplis Line 6 pas encore discuté?
Vetta/Vetta II HD
300W; 4/8/16 Ω
HD147
300W; 4/8/16 Ω
Flextone II HD
200W; 2x12: 4/8/16 Ω
Flextone HD
300W; 4/8/16 Ω
Duoverb HD
100W; 4/8 Ω
0 Comments
