Search Articles
Recent Comments
Headphone F.A.Q.
headphone earbud ohm jack output
Die deutsche Version finden Sie unter der englischen.
Vous pouvez trouver la version française dessous l'allemand.
Q: What size are the headphone outputs on my Line 6 device?
A: The majority of the headphone jacks on Line 6 products are 1/4". The Floorpod series, Pocket POD, Pocket POD Express, Guitarport, and POD Studio/Toneport GX have a 3.5mm (1/8") headphone jack.
Q: What is the recommended headphone ohm rating for use with Line 6 products?
A: For devices with a 1/4" output, we recommend headphones rated between 150-600 ohm (pro or semi-pro level) studio headphones for best results. For those with an 1/8" output, headphones designed for MP3 player usage are usually a good match. Results may vary between headphone models and manufacturers.
Q: Can I use smaller earbud-style (i.e. iPod) headphones with my Line 6 gear?
A: Earbud-style headphones (typically under 150 ohms) are not recommended for devices with a 1/4" output. Some users of earbud-style headphones have experienced a "motorboat" sound in the headphones. Results may vary between between headphone models and manufacturers.
Q: I noticed that when I plug my headphones into my Line 6 amplifier, there is no sound from the speaker. Is this intended?
A: Yes, inserting a plug into the headphone jack will mute the speaker.
Q: My Line 6 amp headphone jack is also labeled direct/recording output. Can I use the speaker and the headphone jack at the same time?
A: There is no way to have both the speaker and headphone jack/DI output active at the same time.
F.A.Q.: Kopfhörer:
Welchen Durchmesser haben die Kopfhörer-Ausgänge meiner Line 6 Geräte?
Die meiste Line 6 Geräte haben einen 6.35mm (1/4") Klinkenbuchsen-Ausgang. Die Floorpod Serie, Pocket POD, Pocket POD Express sowie GuitarPort und POD Studio/Toneport GX haben eine 3.5mm (1/8") Buchse.
Was ist die empfohlene Kopfhörer-Impedanz zur Nutzung mit meinen Line 6 Produkten?
Für Geräte mit einem 6.35mm Ausgang empfehlen wir die Nutzung von Studio-Kopfhörern zwischen 150 und 600 Ω. Für Geräte mit 3.5mm Ausgang können alle Kopfhörer benutzt werden, die für die Nutzung mit einem MP3 Player konzipiert sind. Ergebnisse können hier jedoch unterschiedlich ausfallen je nach Kopfhörer Modell und Hersteller.
Kann ich auch die kleineren InEar-Kopfhörer (wie beim iPod) mit meinem Line 6 Gerät benutzten?
InEar Kopfhörer (meist unter 150 Ω) sind nicht empfohlen für Geräte mit 6.35mm Anschlüssen. Manche Benutzer haben hier ein Motorboot Geräusch in ihren Kopfhörern festegestellt. Ergebnisse können hier jedoch unterschiedlich ausfallen je nach Kopfhörer Modell und Hersteller.
Wenn ich meine Kopfhörer in den Line 6 Verstärker einstecke kommt kein Ton mehr aus dem Lautsprecher. Ist das beabsichtigt?
Ja, sobald man einen Stecker in den Kopfhörer-Eingang einsteckt schaltet sich der Lautsprecher automatisch stumm.
Auf meiner Line 6 Verstärker Kopfhörer-Buchse steht außerdem "direct/recording output". Kann ich den Lautsprecher und die Kopfhörer-Buchse gleichzeitig benutzen?
Es gibt keine Möglichkeit, den Lautsprecher und den Kopfhörer Ausgang gleichzeitig zu benutzen.
F.A.Q.: Écouteurs
Quelle taille est-ce que les sorties écouteurs ont sur mon appareil Line 6?
La majorité des jacks écouteurs des appareils Line 6 sont 6.35mm (1/4"). La série Floorpod, Pocket POD, Pocket POD Express, GuitarPort et POD Studio/Toneport GX ont un jack 3.5mm (1/8").
Quelle est l'impédance recommandée des écouteurs pour l'utilisation avec les produits Line 6?
Pour les appareils avec un jack 6.35mm (1/4"), nous recommandons des écouteurs de studio 150 à 600 Ω pour les résultats meilleurs. Pour les appareils qui ont un jack de sortie 3.5mm, les écouteurs pour un lecteur MP3 sont un bon match. Les résultats peuvent varier entre les modèles et fabricants des écouteurs.
Est-ce que je peux utiliser des écouteurs plus petits, intra-auriculaires (comme les écouteurs iPod) avec mon produit Line6?
Les écouteurs intra-auriculaires (normalement sous 150 Ω) ne sont pas recommandés pour les appareils avec sortie 6.35mm (1/4"). Quelques utilisateurs des écouteurs intra-auriculaires ont connu des sons " bateau à moteur" dans ces écouteurs. Ces résultats peuvent varier entre les modèles et fabricants des écouteurs.
Si je branche mes écouteurs dans mon ampli Line 6, je n'ai aucun son du haut-parleur. Est-ce que c'est voulu?
Oui, si vous branchez une prise dans le jack écouteurs, cela désactivera le haut-parleur.
La sortie des écouteurs de mon ampli Line 6 est étiqueté "direct/recording output". Est-ce que je peux utiliser l'haut-parleur et le jack écouteurs en même temps?
Vous ne pouvez pas avoir les deux, l'haut-parleur et le jack de sortie écouteurs, actives en même temps.
0 Comments
