Search Articles
Recent Comments
Power Supply/Battery Specs and FAQ
power supply battery ac dc drain amp rechargeable specs require
Français
Deutsch
Q: Which power supply works with each Line 6 device?
Attached Image: power supply chart.PNG
Q: What are the specs for the Line 6 Power Supplies?
DC-1: (Tone Core Pedals, Pocket POD) 9.6V DC, 200mA, Center Pin: (-). The DC-1 has been discontinued and was replaced by the DC-1g.
DC-1g: (X2: XDS-Plus/XDR 95, Relay G30/G50/G90 - XD-V70/30, M5 Stompbox Modeler): 9V DC, 500mA, Center Pin: 2.1mm.
PX-2/PX-2g AC: (Stomp modelers, All PODs, XT, and X3 series, XPS, Micro Spider): Output: 9V AC, 2000mA. Plug Length: 10.5mm, Diameter: 5.5mm, Center Pin: 2.5mm.
DC-3g: (POD HD 300/400/500/500X and HD Bean): 9V DC, 3A (3000mA) Plug length: 15mm, Diameter: 5mm, Center Pin: 2mm.
I.T.E.: (Relay G70/G75/G10): USB A - USB Micro form factor; Input: 100-240V 50/60Hz Output: 5V 1.0A.
Line 6 power supplies are available at your local dealer or at our Online Store.
Q: I want to power more than one Line 6 unit from the same power supply. How can I achieve this?
A: The Voodolab Pedal Power II Plus can power up to 6 Tonecore pedals and two Modeling pedals at once, and the Voodoo Lab Pedal Power AC can power up to four Modeling pedals. Other power supplies may not deliver consistent voltage and are not supported by Line 6.
Voodoo Lab Pedal Power 2 Plus
Voodoo Lab Pedal power AC
Q: I am traveling overseas. How should I power my Line 6 device?
A: You can buy any adapter that converts your country's power to these specs and it will work. Any electronics store in your country should be able to sell you one, or you can contact your local Line 6 dealer. Be aware that the DC-1g and DC-3g power supplies are “universal” across all voltage and power standards around the world, and you will only need the appropriate adapter for a new region rather than a different power supply or transformer.
There are certain products that operate over a range of power supplied and don't require any conversion:
Helix Floor/Rack, Firehawk 1500: 100-240V AC
Relay G90: 90-250V AC
POD HD Pro/Pro X: 100-240V AC
POD X3 Pro: 100-240V AC
Q: What if I do not have the Line 6 power supply?
A: If it is not possible for you to obtain an official Line 6 power supply, then any other power supply with the same specifications should suffice (but is not supported).
Q: I am outside the United States, what do I need to power my Line 6 unit?
Option 1: We recommended that the proper Line 6 power supply be used. Please contact an authorized Line 6 Distributor for the appropriate region. To acquire the proper Line 6 power supply for a desired country, please visit the Authorized Line 6 Dealers page to find an one near you.
Option 2: You will need a travel voltage converter. These will work with our products provided they output the currents and voltages specified on your Line 6 devices or power supplies.
Q: I purchased my internally powered Line 6 unit in a region that has "XXX" voltage, and now I am relocating to a region that has different power. Can my Line 6 unit be modified or do I need to use a external transformer?
A: Many Line 6 products can be internally modified at an Authorized Line 6 Service Center to the power needs in your new region. Spider amplifiers require that the transformer be replaced along with internal modification. Please note that this is a non-warranty modification and will not be covered under any warranty agreement.
Q: What are some of the common power situations around the world?
A: Always verify your voltage and frequency BEFORE plugging your unit in, as damage could result if the unit is improperly powered. Although there can be variations to power, here are some common voltage and frequency situations found around the world:
United States: 120V AC/60 HZ
Europe: 230V AC/50Hz
United Kingdom: 230V AC/50Hz
Australia: 230V AC/50Hz
Japan: 100V AC/60Hz
Here are some examples available on the web:
https://en.wikipedia...city_by_country
http://www.world-imp...ransformers.htm
Q: What is the warranty on a Line 6 power supply?
A: 90 days from the purchase date. This applies to power supplies purchased separately and were not included with a Line 6 device.
Q: What is the difference between alkaline and rechargeable batteries?
A: Rechargeable batteries will usually last about half the time of alkaline batteries, and can have an inconsistent power drain after each recharge. We recommend using alkaline batteries when powering your Line 6 product. Not all rechargables are true AA size and may not fit correctly.
Quelle alimentation pour quel appareil Line 6?
Quels sont les spécifications des alimentations ?
DC-1 : (pour les pédales Tone Core et le Pocket POD) 9.6V DC, 200mA. Le DC-1 a été discontinué. Le DC-1G remplace le modèle DC-1:
DC-1G : (pour X2 : XDS-Plus/XDR 95, Relay G30/G50/G90 – XD-V70/30, M5 Stompbox Modeler) 9V DC, 500mA, broche : 5mm.
PX-2/PX-2g AC : (pour les Stomp Modelers, tous les POD, séries XT et X3, XPS et Micro Spider) 9V AC, 2000mA, longueur de la fiche : 10,5mm, diamètre : 5,5mm, broche : 2,1mm.
DC-3g : (pour les POD HD 300, 400, 500 et HD Bean) 9V DC, 3000mA, longueur de la fiche : 15mm, diamètre : 5mm, broche : 2mm.
Vous pouvez acheter les alimentations du revendeur ou de notre boutique en ligne :
Online Store.
Je veux alimenter plus qu’un seul appareil avec une alimentation, comment est-ce que je réalise ca ?
Le Pedal Power II Plus de Voodoo Lab peut alimenter jusqu'à 6 pédales Tonecore et 2 pédales modélisations en même temps. Et le Pedal Power AC de Voodoo Lab peut alimenter jusqu'à 4 pédales de modélisation. Autres alimentations ne sont pas soutenues de Line 6.
Je suis à l’étranger, comment est-ce que je peux alimenter mon appareil Line 6 ?
Vous devez acheter un convertisseur ou contacter votre revendeur Line 6. L’alimentation DC-1g est universel donc vous n’avez pas besoin d’un transformateur ou une autre alimentation, seulement d’un adaptateur.
Il y en a quelques appareils qui n’ont pas besoin d’un transformateur :
POD HD Pro 100-240V AC, POD X3 Pro 100-240V AC, Relay G90 90-250V AC.
Contactez un des revendeurs officiels de Line 6 si vous avez besoin d’une alimentation différente : www.fr.line6.com/support/dealers/
Et si je n’ai aucune alimentation Line 6? Qu’est-ce que je fais ?
Si vous n’avez pas d’accès à une alimentation Line 6. Une alimentation de tires fonctionne aussi, si cette alimentation a les mêmes spécifications. Attention, ces alimentations ne sont pas soutiens de Line 6.
J’ai acheté un appareil Line 6 avec alimentation intégrée et maintenant je vais à l’étranger avec cet appareil, est-ce qu’on peut modifier mon appareil ou est ce que j’ai besoin d’un transformateur ?
Beaucoup d’appareils Line 6 peuvent être modifiés à un centre de service Line 6 autorisé. Le transformateur des amplis Spider doit être remplacé. Attention, ces modifications ne sont pas des modifications en garantie, donc vous devez payer pour ceux.
Attention, vérifiez la tension et fréquence AVANT de brancher les appareils.
Ici quelques tensions :
États-Unis: 120V AC 60Hz
Europe: 230V AC 50Hz
Australie: 230V AC 50Hz
Japon: 100V AC. Est: 50Hz. Ouest: 60Hz.
Quelle est la garantie sur les alimentations Line 6 ?
90 jours pour les alimentations achetés séparément.
Quelle est la différence entre les batteries Alkaline et les batteries rechargeables ?
Les batteries rechargeables durent environ la moitié du temps des batteries Alkalines. Et parfois, les batteries rechargeables ont un drain de puissance incompatible. Nous recommandons les batteries Alkalines pour les produits Line 6.
Welches Netzteil brauche ich für mein Line 6 Gerät?
Die Spezifikationen der verschiedenen Line 6 Netzteile:
DC-1: (Tone Core Pedale, Pocket POD) 9,6V Gleichstrom, 200mA. Die Herstellung des DC-1 wurde eingestellt. Dieses Netzteil wurde mit dem folgenden ersetzt:
DC-1G: (X2: XDS-Plus/XDR 95, Relay G30/G50/G90 – XD-V70/30, M5 Stompbox Modeler): 9V Gleichstrom; 500mA; 2,1mm Pin.
PX-2/PX-2G AC: (Stomp Modeler, alle POD, XT und X3 Serien sowie XPS und Micro Spider): 9V Wechselstrom, 2000mA. Stecker: Länge: 10,5mm. Durchmesser: 5,5mm. Pin: 2,5mm
DC-3G: (POD HD 300/400/500 und HD Bean): 9V Gleichstrom, 3A. Stecker: Länge: 15mm. Durchmesser: 5mm. Pin: 2mm.
Line 6 Netzteile können Sie bei Line 6 Händlern sowie in unserem Webstore kaufen.
Wie kann ich mehrere Line 6 Geräte an ein einziges Netzteil anschließen?
Das Voodoolab Pedal Power II Plus kann bis zu 6 Tonecore Pedale und 2 Modeling Pedale mit Strom versorgen und das Voodoolab Pedal Power AC kann bis zu 4 Modeling Pedale mit Strom versorgen. Andere Netzteile könnten eventuell keine beständige Voltzahl liefern und sind nicht von Line 6 unterstützt.
Ich reise ins Ausland, wie kann ich dort meine Line 6 Geräte mit Strom versorgen?
Sie können sich einen Adapter kaufen, der den Strom im Ausland in den Ihres Heimatlandes umwandelt. Jeder Elektronikladen sollte diese Adapter verkaufen, ansonsten können Sie auch Ihren Line 6 Händler kontaktieren. Der DC-1G ist universal verwendbar, für dieses Netzteil brauchen Sie also nur Adapteraufsatz und kein neues Netzteil oder Transformator.
Manche Geräte laufen auf mehreren Voltzahlen:
POD HD Pro 100-240 Volt Wechselstrom. POD X3 Pro 100-240 Volt Wechselstrom. Relay G90 90-250 Volt Wechselstrom.
Spannungswandler müssen 1,5 A und 100 Watt minimum liefern können.
Was kann ich tun wenn ich kein Line 6 Netzteil zur Verfügung habe?
In diesem Fall können Sie auch jedes andere Netzteil verwenden, welches die oben angegebenen Spezifikationen hat. Diese Netzteile werden nicht von Line 6 unterstützt.
Ich habe ein Line 6 Gerät mit internem Netzteil. Wenn ich nun aber in eine Region umziehe, in der die Spannung eine andere ist, kann ich mein Line 6 Gerät auch umbauen lassen oder brauche ich einen Transformator?
Viele Line 6 Geräte (wie Rack-PODs, Flextone oder Vetta) und Verstärker können von autorisierten Line 6 Service Centern modifiziert werden um der benötigten Spannung zu entsprechen. Spider Verstärker brauchen einen neuen Transformator. Diese Modifikationen sind nicht in der Garantie enthalten, Sie müssen also für sie bezahlen.
Gebräuchliche Stromspannungen und Frequenzen:
Vereinigte Staaten: 120V, AC, 60Hz.
Europa: 230V, AC, 50Hz.
Australien: 230V, AC, 50Hz.
Japan: 100V, AC, Osten: 50 Hz Westen: 60Hz.
Gibt es eine Garantie auf Line 6 Netzteile?
Ja, 90 Tage nach Kaufdatum. Diese Garantie zählt für separate Netzteile, die nicht bei Line 6 Geräten mitenthalten waren.
Was ist der Unterschied zwischen Alkaline und Nachladbaren Batterien?
Nachladbare Batterien halten ca. halb so lange durch wie Alkaline Batterien und können unter Umständen einen unbeständigen Stromfluss aufweisen. Wir empfeheln Alkaline Batterien.
0 Comments
