Search Articles
Recent Comments
Relay/XD-V Digital Wireless
Pinned  Relay G10 FAQ
Mar 21 2016 09:08 AM | line6will in Relay/XD-V Digital Wireless
LED States:  Transmitter Green when in guitar: On Red flashing when in guitar: Less than 30 minutes battery life left  Green when docked: Fully chargedGreen flashing when docked: Charging Red flashing when docked: Less than 30 minutes bat...
Read story →    0 comments    *----    range, battery, charge, led and 5 more...
Pinned  Relay G50/G55/G90 Series FAQs
Apr 23 2010 03:56 PM | Line6Tony in Relay/XD-V Digital Wireless
Deutsch Français en Q: Can I use multiple transmitters with 1 receiver? A: Yes, you can use multiple transmitters with 1 receiver, however not at the same time on the same channel. The best practice for that type of usage is to have Transmitter A o...
Read story →    0 comments    -----    relay, g50, g90, faq, line 6 and 5 more...
Pinned  Relay G10 Guitar Compatibility (Fit/Electronics)
May 25 2016 03:16 PM | Line6Tony in Relay/XD-V Digital Wireless
We have designed the G10 transmitter to fit into almost any guitar. However, we anticipate that there will be some rare cases where the transmitter does not fit into a given guitar. If the G10 transmitter is inserted into your guitar and the transmitte...
Read story →    0 comments    *****    g10, g10t, compatibility, active and 4 more...
Pinned  Digital Wireless Audio Troubleshooting
Dec 12 2011 04:41 PM | Line6Tony in Relay/XD-V Digital Wireless
Deutsch Français  en Please review this link as a further explanation on topics that are covered in the document below: http://www.churchproduction.com/story/main/a-small-churchs-guide-to-working-with-wireless/3  As the environment is...
Read story →    0 comments    -----    relay, wireless, troubleshooting and 7 more...
Pinned  RF1/RF2 Mode Switching & Frequencies
Nov 26 2012 02:10 PM | Line6Tony in Relay/XD-V Digital Wireless
Français Deutsch 日本語  Below is a chart of the carrier frequencies for each channel in RF1 and RF2 mode. There are 2 frequencies in RF2 mode, because each channel has 2 carrier frequencies per channel. At the same time, each channel in RF1 mode ha...
Read story →    0 comments    -----    relay, digital, wireless, rf1 and 5 more...
Using G70/75 with other Line 6 wireless (RF Co-...
Nov 18 2015 10:42 AM | line6will in Relay/XD-V Digital Wireless
Even with RF2/ RF3 co-habitability - that does not necessarily mean that every channel will work in the same environment. Check out this chart as to what channels are available when using our other Relay products.    Note:  The G70/7...
Read story →    0 comments    -----    relay, g70, g75, rf, channels and 1 more...
Relay G10 Tutorial
Mar 03 2016 02:24 PM | line6will in Relay/XD-V Digital Wireless
Read story →    0 comments    -----    relay, g10, g10t, tutorial, faq and 3 more...
Relay G10 compatibility with older Variax models
Mar 16 2016 09:29 AM | line6will in Relay/XD-V Digital Wireless
We have designed the G10 transmitter to fit into almost any guitar. However, we anticipate that there will be some rare cases where the transmitter does not fit into a given guitar.  In some rare cases, the guitar’s active electronics are wired...
Read story →    0 comments    -----    relay, g10, variax, transmitter and 1 more...
Relay G10 Channel Scan
Mar 16 2016 09:27 AM | line6will in Relay/XD-V Digital Wireless
The Relay G10 utilizes 14 RF2 channels for transmission. The system performs a channel scan and sets itself to best channel every time the transmitter is docked into the receiver. This can take up to 15 seconds.  If you are using G10 in a setup w...
Read story →    0 comments    -----    relay, g10, channel, scan, rf2 and 1 more...
How To Update Relay G70/75 transmitter and rece...
Mar 16 2016 12:56 PM | line6will in Relay/XD-V Digital Wireless
Step-by-step update instructions for downloading the Line 6 Updater application, updating the Relay TB516 G Transmitter, and updating the Relay G70 Receiver.
Read story →    0 comments    -----    relay, g70, g75, transmitter and 6 more...
Relay G70/75 FAQ
Mar 28 2017 01:07 PM | line6will in Relay/XD-V Digital Wireless
Q: How does the G70/75 system work with other Line 6 Wireless? Even with RF2/RF3 co-habitability, that does not necessarily mean that every channel will work in the same environment. Check out the chart below to see what channels are available when u...
Read story →    0 comments    -----    relay, g70, g75, faq, dimensions and 2 more...
XD-V Digital Wireless Microphones FAQ
Jul 15 2010 02:10 PM | Line6Tony in Relay/XD-V Digital Wireless
****If you recently purchased a Relay V75-SC Super Cardioid Microphone and that capsule does not have microphone models when placed on another XDV-75 handheld microphone body, then you will need to update the firmware on that handheld microphone to ver...
Read story →    0 comments    -----    line 6, xdv, wireless, digital and 4 more...
Are Line 6 Wireless Products Cross-compatible?
Sep 16 2016 12:51 PM | Line6Tony in Relay/XD-V Digital Wireless
All 3rd generation Line 6 digital wireless transmitters and receivers are designed to be cross-compatible with each other. For example, the six-channel Relay® G30 transmitter will work on channels 1 through 6 of the XD-V75 receiver. The units in questi...
Read story →    0 comments    -----    compatible, wireless, rf, band and 1 more...
Line 6 Digital Wireless System Comparison Docum...
Aug 07 2014 11:56 AM | line6jonb in Relay/XD-V Digital Wireless
Below are all the 2nd and 3rd generation wireless products in one document:  Wireless Comparison Sheet.xlsx 273.04KB 1597 downloads
Read story →    0 comments    -----    line 6, digital, wireless and 6 more...
How to Update the Relay G90 and XD-V70/75 Recei...
Jan 05 2012 08:10 AM | Line6Tony in Relay/XD-V Digital Wireless
The XD-V75 receiver firmware can be updated via the mini-USB port connection to a host computer (Windows XP or better, or Mac OSX 10.5 or better) using the Line 6 Monkey software application. In addition, the XD-V75 receiver can function as an "interfa...
Read story →    0 comments    -----    line 6, xd-v, digital, wireless and 6 more...
Device Positioning for Updating Transmitters an...
Jan 03 2012 09:10 AM | Line6Tony in Relay/XD-V Digital Wireless
The XD-V75 receiver firmware can be updated via the mini-USB port connection to a host computer (Windows XP/Vista/7 or Mac OSX 10.5/10.6/10.7) using the Line 6 Monkey software application. In addition, the XD-V75 receiver can function as an "interface"...
Read story →    0 comments    -----    line 6, digital, wireless and 7 more...
2.4GHz Wireless FAQ
Jun 30 2010 02:00 PM | Line6Tony in Relay/XD-V Digital Wireless
Deutsch Français  en Q: Why is the battery meter higher when I restart than when I shut off the transmitter? A: Line 6 2.4G wireless transmitters have a circuit that measures the actual real-time voltage of the installed batteries and transmi...
Read story →    0 comments    -----    line 6, relay, wireless, digital and 2 more...
Relay G55 FAQ
Oct 02 2012 03:20 PM | Line6Tony in Relay/XD-V Digital Wireless
Français Deutsch  en Q: What is the cable tone on my Relay G55 and what does it do?A: The cable tone button simulates the slight change in tone that happens when using cables of varying length. The cable tone length that the Relay 55 uses is...
Read story →    0 comments    -----    line 6, wireless, relay, digital and 2 more...
Relay G30/G50/G90 Device Firmware 2.0 Update
Mar 21 2012 09:14 AM | Line6Tony in Relay/XD-V Digital Wireless
German instructions: Deutsche Übersetzung ist unter  French instructions: Traduction française est ci-dessous  Relay G30/G50/G90 Device Firmware 2.0 Update Release Notes  This release is recommended for all G30/G50/G90 system owner...
Read story →    0 comments    -----    relay, line 6, digital, wireless and 3 more...
RELAY G10 or TB516G transmitter update failure
Jul 02 2015 08:53 AM | Line6Tony in Relay/XD-V Digital Wireless
In the event that you have connected a RELAY G10 or TB516G transmitter and observed text in the Line 6 Updater app stating that “ The transmitter was not detected correctly ”, it is likely that the computer has not completed the download of the a...
Read story →    0 comments    *----    tb516g, update, failure, cannot and 1 more...
