Add Site to Community
Close
To install the "Add to Community" button, simply drag the button to the left to the bookmark toolbar in your browser.
Tip: If you do not see your bookmark toolbar, select View -> Toolbars -> Bookmarks Toolbar from your browser menu.
Drag this to your bookmark toolbar.
Tip: If you do not see your bookmark toolbar, select View -> Show Bookmarks Toolbar from your browser menu.
Right-click this button and Add to your IE Favorites.
To install the "Add to Community" button, first right click the button above and select "Add to Favorites".
Next, when the browser prompts where to place the Favorite, select the "Links" folder.
Tip: If you receive a Security Alert, select "Yes" to continue to install the button.
When step 2 is complete, you will be able to view the button in the Links toolbar.
Tip: If you do not see your Links toolbar, make sure there is a check mark next to View -> Toolbars -> Links in your browser toolbar.
Tip: If your Links toolbar is hiding, select View -> Toolbars and uncheck "Lock Toolbars", then you will be able to drag your Links into view (illustrated below).
line6jonb's Bookmarks
About
Follow
Subscribe
