187 Views 5 Replies Latest reply: Mar 18, 2013 7:00 AM by BlueViolince RSS
BlueViolince Just Startin' 55 posts since
Dec 15, 2008
Mar 15, 2013 11:22 AM
DIY expression pedal
I just whipped up an expression pedal for my HD500, with a wah, one additional pot, and even added custom grip to the treadle.  Used a Dunlop GCB-95, a 75K pot, and adhesive diamond pattern grip tape for the top.  I cut out the guts(PCB, and left the stock pot intact.  The 75K pot was wired in parallel with the wah pot, and I installed a standard mono jack in one of the holes left by the stock jacks(they were board mounted, so I couldn't use them).  The additional pot was adjusted so that the Pod would see 10K at heel down, and 0 at toe down.  Wired it all the jack, and it works great!  Just taped the secondary pot to the inside of the case, and if I decide to use the pedal with another processor that requires a different range, I can just adjust that pot to the required resistance.  Hope this helps someone who doesn't have the cash for a custom made expression pedal.  I think I saw the 2 potentiometer trick on another guitar forum, but I can't remember where.
  • chagmaier Just Startin' 5 posts since
    Feb 24, 2013
    Mar 17, 2013 1:00 PM (in response to BlueViolince)
    Re: DIY expression pedal
    I also have a GCB 95 cry baby that rarely gets used...  Do you think its possible to do this while keeping the stock components?  For example, install a 3rd TS jack on the side, and connect it directly to the pot.  Would that be feasable?
  • jimsreynolds Power User 2,227 posts since
    Jun 27, 43450
    Mar 18, 2013 1:01 AM (in response to BlueViolince)
    Nice work Blue!  Thanks for sharing.
