128 Views 5 Replies Latest reply: Mar 19, 2013 8:23 AM by HDProJohn RSS
gibb1337 Just Startin' 3 posts since
Dec 28, 2009
Mar 19, 2013 6:12 AM
POD HD Pro Live Setup
Hi folks,
Trying to figure something out and couldn't find an answer from any existing posts so I thought I'd make a new one!
I'm planning on running my POD HD Pro to the PA at gigs but I'm a little concerned that the monitors at some of the venues I play at are pretty poor. In an effort to avoid using any IEM systems to hear myself I was wondering if I could take a line from the POD into a power amp (whilst also going to the PA system) and then into a cab onstage to provide something onstage for me to hear. Might stick the cab to one side of me just as a personal monitor. Is this do-able? Also is it going to sound nasty because I can't turn off the Cab + Mic sims to the Cab whilst leaving them on going to the PA? I'm not overly fussed about the quality of the sound coming out of the cab because as I said its more just so I can hear myself.
Any help would be muchly appreciated!
  • silverhead Expert Line 6 User 9,592 posts since
    Apr 1, 2009
    Mar 19, 2013 6:41 AM (in response to gibb1337)
    Re: POD HD Pro Live Setup
    Yes - that is doable. Since you are going direct to PA for the house sound you will want your Output Mode set to Studio. As you say, this could end up giving you a double-cab effect through the onstage cab/monitor. Accordingly, you'll get the best results if your cab/monitor is as close to FRFR as possible. You might consider a keyboard amp for this purpose, or a good studio monitor.
  • HDProJohn Just Startin' 38 posts since
    Feb 16, 2012
    Mar 19, 2013 8:23 AM (in response to gibb1337)
    Not going to argue the FRFR route, but running Stereo mode into a power amp + cab does not sound bad at all (cheapish option since you already have a cab). Also, check out the 1U Rocktron power amp, it supposedly has good reviews and is cheap. The setup you described is exactly how I run live though - stereo to FOH and stereo to cab. Don't forget, you can throw in an FX block at the end of your chain and use this for additional outputs. I use the FX loop, but only in mono for effects. By using the right side of the loop, I can send my signal to a sound card on stage so that the drummer can have me direct for his IEM mix too. It's a lot of outputs! Ha.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
