Line 6 - Support
5288 Views 4 Replies Latest reply: Oct 20, 2011 6:06 PM by billygiii RSS
DaveDrums Just Startin' 3 posts since
Jun 24, 2009
Jun 28, 2009 11:15 AM
POD Studio UX2 drivers - ASIO vs WDM question
I recently purchaced my first Line 6 product, the POD Studio UX2.  My current recording set-up includes: a Dell running XP (SP2) / M-Audio Delta 1010 / Sonar 5.  I have spent many hours over the last few days trying to get everthing working together and my question is about UX2 drivers.
Here is a description of what I have figured out so far:
When I have the driver mode in Sonar set to ASIO I can enable the drivers for 1 sound card at a time.  As a result I can use either the Delta 1010 OR the UX2 but not at the same time.  In this configuration (i.e., the UX2 using ASIO drivers) the UX2 will record with a bit depth of 24 and it supports a sample rate of 48000hz.
When I have the driver mode in Sonar set to WDM, I can enable both the Delta 1010 AND the UX2 but when I do this, the whole project is reset to a sample rate of 44100Hz.
My question is this:
Do the WDM drivers for the for the UX2 support a sample rate of 44100Hz?  I am assuming they do and I am just missing something obvious.
Thanks in advance for any help,
Dave
    • murphmusik Just Startin' 4 posts since
      Oct 11, 2006
      Dec 22, 2009 8:11 AM (in response to DaveDrums)
      Re: POD Studio UX2 drivers - ASIO vs WDM question
      This is not an answer for you...but I am having a similar problem.
      I use an M-Audio 1814 and I am having the same problem where Sonar only recognizes the UX2 as the
      audio driver and I cannot select an M-Audio input.
      Did did you actually have access to, and use the POD Farm when you changed to WDM and selected your M-Audio interface?
  • billygiii Just Startin' 1 posts since
    Mar 29, 2006
    Oct 20, 2011 6:06 PM (in response to DaveDrums)
    Try running line 6 UX2 on pod farm and take the output of your line 6 and run the analogue outs into the delta 1010.
    This allows the asio drivers for the line 6 to run and the asio drivers for the delta 1010 to run.
    Thats the way I got the signals clean -no pops if I remember
    I think this is how I had it set up.
    I now run my line 6 on a separate laptop computer usually.
