Line 6 - Support
7109 Views 10 Replies Latest reply: Jul 8, 2009 11:09 AM by silverhead RSS
thiagocoracini Just Startin' 5 posts since
Jan 22, 2008
Jul 8, 2009 9:04 AM
POD Farm, record and playback volume control doesn't work
I'm having a problem with my new POD X3 Live. I had a POD XT Live and I loved, so I decided to buy the Line 6 top line pedalboard. But I'm desapointed.
The software works painful. First: POD Farm doesn't work. It does not recognize my X3: "Non authorized device connected...." Second: When POD X3 become a windows audio device, the master volume (for recording and playback) does not work. Just work the "Wave" channell. There are so many other things, like, in gearbox, when you move the wah pedal, it does not refresh the actual position knob in screen, when you turn up the POD and the amp, if the amp is connected and the amp volume is set a little high, you can hear a very loud peak noise that could probabily damage the speaker. And how can the Windows sound output to the amp (as podxt) and NOT to the phone out?
Please, is that an isolated problem or more people are suffering with this too?
Someone knows how to fix all of this?
I need support please
Thiago Coracini
Brazil
  • silverhead Expert Line 6 User 7,230 posts since
    Apr 1, 2009
    Let's take things one at a time. I think most can be resolved, but we'll see .......
    Pod Farm does not work as a standalone editor with the X3. It only works as a plugin to your DAW. Try it with your recording software.
    Try adjusting the monitor level in the Line 6 Midi - Audio devices control panel. It appears on the Inputs and Recording tab, I think.
    I don't know about this one; maybe other responders can help
    Yes, it can be touchy to control tones and levels when using the X3's amp/cab modeling along with an actual amp. For best results, try to make your amp as neutral as possible and let the X3 do all the tonal colouring as much as possible. Search this forum for other threads on the topic of "X3 and amp". Many users get good results from what's called a 4-cable method. Alternatively, turn OFF the X3's am/cab modelling (select no amp/cab) and see how it sounds.
    Set your X3 as the cound card for your computer (seehttp://line6.com/community/docs/DOC-1453 for Vista; other docs for other systems are in the same /docs location). Then connect the X3 outputs to your amp/speakers.
    I think there are a number of different isolated things (not necessarily problems) that can be resolved. I think it's just a learning curve. Once you get past these things I think you'll be happy with your X3.
        Apr 1, 2009
        You're right - the control panel only adjusts the monitor level. The record level, as well as the selections of dry/wet signal options, are controlled within your recording program. Gearbox has nothing to do with recording. Configure the audio settings in your recording software to use the X3's ASIO interface as audio input/ouput. When you arm a track for recording you will be able to select from 8 incoming signals provided by hte X3. When being used by the recording program I believe the X3's tone volume controls do affect all but the dry signals.
        Re: separating amp from monitors for jam/playback: what type of X3 do you have? The input/output options are different between the X3 Bean, Live, and Pro.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
