2763 Views 5 Replies Latest reply: Mar 13, 2009 3:33 PM by Line6Andy RSS
JackMills Just Startin' 5 posts since
Mar 12, 2009
Mar 12, 2009 7:05 PM
Backtrack mic firmware update step by step?
BackTrack mic firmware update o1 to o3, need to dumb it down, step by step. for mac, Thanks
  • Jeraxle Just Startin' 184 posts since
    Nov 28, 2007
    Mar 12, 2009 10:57 PM (in response to JackMills)
    Re: Backtrack mic firmware update step by step?
    1, Go here:  http://www.line6.com/software/index.html  and download v1.03.
    2,  Run the downloaded program
    3,  Connect your Backtrack + Mic to your computer and verify that it installed properly.
    As of right now, the firmware for the BT+Mic is version 1.01 I believe (I don't have it with me at the moment).  That should be what was installed at the factory.  If not, you'll need to contact Line6 Support and have them send you the proper firmware.
    If you were referring to v1.03 of the setup utility, the above process with take care of you.
  • Kneehow UberGuru 6,750 posts since
    Dec 26, 2007
    Mar 13, 2009 11:30 AM (in response to JackMills)
    You might try a hard reset on the BackTrack unit itself:
    To perform a hard reset you'll need to manually press a small object like a paper clip into the small hole on the side of the Backtrack. The hole is located on the opposite side of all the UI controls (Backtrack) or on the side opposite the microphone (Backtrack + Mic). Hold the button down for three seconds and then remove the paperclip. The LED on the device will glow white, blink a few times, and then begin blinking blue. You have now successfully reset your Backtrack.
  • Line6Andy Line 6 4,345 posts since
    Jun 5, 2006
    Mar 13, 2009 3:33 PM (in response to JackMills)
    Hello,
    Please see your support ticket for more information:
    http://line6.com/account/tickets/view/
    Line6Andy
    Please be sure to award Helpful and Correct points to community members who respond with helpful or correct answers!
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
