Jul 27, 2009 1:36 PM
Line 6 Spider 3 full stack?
Like (0)
This is a stupid question, but I'm assuming I can make my Spider 3 HD150 half stack into a full stack? Will that increase the power of the amp, and how would I hook that up if I had to Line 6 cabs? I don't quite understand ohms and all of that junk and I definitely don't want to blow anything up, so any help would be GREAT. Thanks!
Gabe
Hello,
You would need to have a service center internally modify each cabinet for an 8 or 16 ohm load (depending on the type of cabinet you are using). You would then connect each output of the head to a 16 or 8 ohm connection. See the following link for more info:
Cabinet Connection and Ohm F.A.Q.
http://line6.com/community/docs/DOC-4410
No it will give u a fuller sound fatter sound
