5074 Views 13 Replies Latest reply: Aug 15, 2009 9:35 PM by kr0n0s RSS
kr0n0s Just Startin' 8 posts since
Jul 1, 2009
Jul 30, 2009 3:31 PM
Turn off Mic SIM in Editor?
I checked FAQ and couldnt find this answer, is the a way to turn off the mic simulation in the Line 6 Editor, the other modules can  be clicked on off but i cant seem to find a way to remove the Mic module from the sounds. I have only just got the amp, its an older Flextone III with no XLR outs or extra speaker out. thanks in advance.
  • Crusty_Old_Rocker Expert Line 6 User 3,096 posts since
    Jan 24, 2007
    Jul 30, 2009 3:36 PM (in response to kr0n0s)
    Re: Turn off Mic SIM in Editor?
    The Mic simulation is tied to the cabinet simulation.  You can only switch off the mic simulation by selecting no cabinet, but then the amp model sounds all wrong.
    Cheers,
    Crusty
  • spaceatl Expert Line 6 User 4,456 posts since
    Jan 24, 2007
    Jul 31, 2009 11:30 AM (in response to kr0n0s)
    Hey Crusty, there's a workaround...
    That is something that changed in the 3.0 Edit for the Flextone III...You actually can turn off the mic with the setting of "No mic"...But that is only available in the 2.x versions of Edit....Or you can go to VettaVille and get Tweakwizard...It let's you do this...
    There is a way to do it in Edit 3.0....There is a bug in 3.0 that when you select the On Axis 57....that is actually the no mic setting....another good reason to NOT use 3.0 with a Flextone III...Revert to 2.x or Tweakwizard with your Flexy...
        Jan 24, 2007
        Aug 4, 2009 7:51 AM (in response to kr0n0s)
        Welcome!
        Get ready to spend some time with it...I think the Flextone 3 benefits greatly from a little outboard gear. One real popular approach is to stick a stereo EQ in the FX Loop a global room correction EQ...Makes it a bit easier to tweak at a gig and leaves the patches untouched. I also think the amp really benefits from putting a more transparent speaker in it...I don't think the stock OEM Celestion Seventy80s are a good choice for open backs...They work pretty well at lower volumes, it's when you get to gig volume that those things can start farting...And they eventually will...The Spyders are not rigid enough for open backs...But this has more to do with using the cab models...Some guys like to turn that off and get the Seventy80 color...This is sorta where everything gets subjective to personal taste, much like guitar pickups...But here is what I did with my Flextone III XL...
        I went pretty overboard when I was using my 3XL as my main amp.
        GTR->ADA Mp-1->Boss BCB-60 (AW-3->DS-1->FZ-5->LM-3->DM-3)->Flextone III XL GTR Input
        FX Loop
        10 channel midiman mixer (makes the loop parallel)
        Effectron 1024
        Effectron II 1024
        Yamaha SPX-90
        Yamaha SPX-990
        The stomps on the BCB60 are mostly gain stomps (exception: AutoWah & DM-3(Dedicated Pre-delay))...The ADA is controlled via midi from the Flextone and my use of it was more as an EQ and programmable tube screamer...When you push the model with a stomp, the behavior is very consistent with the real thing...The SPXs also change with midi from the flexy...I have bypass switches for all four so I could change things around in the loop.
        I was in a cover band at that time doing a very wide variety of music...With that rig I could just about nail any tone I needed. It took me almost a year to get it completely built and I did change the speakers in the amp and modified it to support a sealed 212 in tandem. I set out to make the amp consistent with the XLR outs so that it could render a 412 model at gig volume...
        That is the most "flexible" rig I have ever had. I have since downsized and now use an SV112 with a 212 cab and the Flextone III XL in tandem....The Flextone III is my dedicated FX amp and the SV is pretty much dry tone...Still use the BCB60...Gotta have my gain stomps...
            Jan 24, 2007
            Aug 6, 2009 2:30 PM (in response to kr0n0s)
            Valve amps...Yes sir, right there with you...I still use the Flextone, but now it is dedicated to being an FX amp...I getting my main tone off an SV112 that I run in tandem with the Flextone...All controlled from a single FBV Shortboard...The rack is in my studio now...I still have all the peices...I have just re-allocated because I am in an original band now and not doing the cover gig anymore...If I were to do a cover gig again, I would put this rig back together again...
            FX Loop
            That rig was a bit of a throwback to the 80s with the rack...The Effectrons and Spxs are pretty old units but I like them still...They basically pickup the slack for FX the Flextone can't do like pitch change...Basically if you put a mixer in an FX loop it makes it parallel os you can run the FX 100% wet and use the volume parameter in the particular effect itself to adjust the ratio...I use an FBV shortboard to control the Flextone...That kicks the program change on the midi out of the Flextone and changes the SPXs and the ADA (That in front of the amp)...I use the FX Loop button to enable/disable...The Effectrons don't have midi so they are whatever I left them at or bypass them (footswitches)...Those are generally for special use delays, chorus or flanging...I don't use them much but what they do is pretty unique sounding...generally, time based stuff is going to work better in the loop (Delays, Flangers, Reverbs)
            A global EQ in the loop is a different matter...That is a convienient way to get correction without diving into the patches...The EQ on the Flextone is good but can be a bit agravating...It has just enough control, but tends to need just a little help IMO...I got really great results when I tried my ADA Mp-1 in front of the amp. I have of others using everything from a dual 15 band dbx to little Boss GEQ-7...
            There is also a mod where folks close off and port the back of the amp...That mod gets a lot kudos around here...It tightens up the bottom end and gives you a nicer thump...
            Yours is really not that different from a 3plus or XL...A 3plus is actually an XL...The only real difference is the extra speaker in the XL...Yours is different in that it has a mono power amp and no XLRs....The modeling hardware is exactly the same...You are still stereo in the headphones...
                Jan 24, 2007
                Aug 10, 2009 7:57 AM (in response to kr0n0s)
                Your welcome...
                You will not hear the mic models in the speaker...You do hear it in the headphones. There are so many combinations of amp and cab...Some are great...Some really suck...My favorite clean on the Flextone III is the AC30, Treadplate cab and 57 off-axis...I pretty much always have a cab and mic model because I use the XLR outs...
                The only thing I can suggest on checking out the cabs is to leave the EQ flat and go for the cab that is the closest to what you a looking for qwith the EQ flat, then go from there...The mic model also affects this but you don't hear that in the speakers...I thinking putting a mic on it is probably going to work out better for you to start with...You basically have a guitar cabinet in the Flextone and the approach of not using cab modeling when micing the amp is quite common...I think you are on the right track...
                    Jan 24, 2007
                    Aug 10, 2009 2:52 PM (in response to kr0n0s)
                    That's a great way to get to know the amp...I spent a month or so doing that when I first got mine...A lot of combinations in there...
                    The Loudness EQ correction in Tweakwizard was an experiment...Basically the idea is you turn it on when you are playing low volume...Version 3 was when it first appeared and that seems to have been the end of Tweakwizard...I never tried it so I am not sure how well it works...
  • Line6Andy Line 6 4,345 posts since
    Jun 5, 2006
    Aug 4, 2009 11:27 AM (in response to kr0n0s)
    Thanks Space...
    Please be sure to award Helpful and/or Correct points to community members who respond with helpful or correct answers!
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
