6841 Views 14 Replies Latest reply: Jan 15, 2013 6:10 AM by fflbrgst RSS
Sandman1832 Just Startin' 6 posts since
Mar 4, 2009
Mar 14, 2009 4:14 PM
Line6 Spider III 150
I just got a Spider III 150 and its been great until recently. I turned it on today to play it and after about 30min to 1hr it started shutting off, but the amp itself did not power off, its almost as if it was reseting itself or something. I don't want to asume its over heating because the cooling fins in the back were not hot to the touch. I there a breaker problem or is it a simple fix. I bought it directly from Line6 and not a local dealer. This has never happened before. To be spicific on what happens, Im jamming out then the sound total shuts off  and all the lights that light up on the presets shut off along with the sound for about 2 to 3 seconds then comes back on, but like I said before the power itself does not shut off. Again its as if you would be holding a reset switch in for that amount of time and then releasing it. It may be just getting warm but I have another amp that is tubed and that thing can get piping hot in the back sometimes and it does not do this. HELP PLEASE, I dont really want to send this out for repairs if there is nothing wrong with it and Im being paranoid, by the way I do have a warrenty just incase.        Thanks, Sam
  • lcg8080 Just Startin' 2 posts since
    May 6, 2007
    Mar 15, 2009 6:15 PM (in response to Sandman1832)
    Re: Line6 Spider III 150
    I'm having the same problem with my spider III 75.
    any ideas what's causing this???
  • Line6Sach Gear Head 1,351 posts since
    Oct 31, 2008
    Mar 16, 2009 4:01 PM (in response to Sandman1832)
    -Try switching out the power cable. The IEC cable it uses is the same kind used on a computer.
    -Try a different outlet / circuit at your house / venue.
    -Try a factory reset: power the unit on while holding the A channel button down. You should see 'Factory Reset' in the display. Be aware that this will erase any custom presets you have saved.
    If none of that helps you need to take it to an authorized service center which you can find here: http://line6.com/support/serviceCenters/. With your purchase receipt you have a one year parts & labor warranty. If you JUST purchased the unit and are still within your return period, you may want to replace it with them to minimize your turnaround time on a repair.
    Line6Sach
    • dspmax Just Startin' 2 posts since
      Mar 2, 2009
      Mar 19, 2009 5:59 PM (in response to Line6Sach)
      I had just picked up a Line 6 Spider III 75W from zzounds, and had the same exact thing happen to me after about 10 minutes of playing.  Tried several outlets in my house, tried swapping the cable out.  Finally because I didn't want to wait for repairs, I sent it back to zzounds for an exchange.
      2 days later (amazing), I recieve a replacement.  And to my shock - the same exact thing is happening!  I've been using these outlets for everything in my home studio, and have never seen this problem: keyboards, preamps, amplified studio monitors, pc, printers, other amps - without any problems.  My house is new construction, so the wiring is new, my studio is on 2 isolated circuits, tried them both - same thing.  So what do I do, do I send it back to zzounds for yet another exchange?  Is this normal?
      I noticed that if I shut the unit off for about 10 mintes, and then start it up again - I can get about 5 minutes of playing in - and then it starts power cycling again.  The longer the amp is plugged in, the more frequent the cycles get.  The red lights wont even come on after being plugged in for about 20 minutes.  I thought that perhaps it's getting over heated, but all parts are cool to the touch, are not near ventilators or any heat sources.
      Line 6 - please help.  Amp sounds good, but there's so much of back & forth one can take.  Will a 3rd one work or is there anythign else I can try?  I've also tried surge protectors that regulate power, tried a different higher quality cable.  Tried this in both 15 and 20 amp plugs, tried other rooms in the house.  No go.  I hope there's something that can be done because now I'm almost certain the 3rd one will have the same problem.
      I have owned so many line 6 products, and have never experienced a problem, and now two identical problems in the row.  Perhaps it's catching up with me??
      Video of the problem attached.
      • Spyfunker Just Startin' 53 posts since
        Feb 2, 2007
        Mar 20, 2009 7:37 AM (in response to dspmax)
        I assume you tried this, posted from above....
        Are you SURE they sent you a different amp?
        Have you tried different guitars?
        Do you have active pickups in the guitar?
        Do you live in a house thats been haunted by ex-L6 employees?
        ~S
          Mar 2, 2009
          Mar 20, 2009 8:12 AM (in response to Spyfunker)
          Spyfunker, thank you for your response:
          Yup - have tried the factory reset, this was the first thing that the Line 6 technician had suggested when I phoned this problem in.
          Definately a different amp.  I had initially purchased a "blemished" spider iii from zzounds.  It looked fine on the outsize, but i noticed the speaker was loose, one of the screws was out of the hole and on the magnet :-).  I do rememember some of the imperfections on the original one.  Zzounds.com didn't have another blemished, so they were kind to replace it with a new one, it was easy to tell.
          I didn't try another guitar, but I did try unplugging the guitar entirely and power cycling the amp.  The problem came back in minutes.  I'm using an epiphone les paul custom silverburst with a pair of humbuckers (also using planet waves cables)
          I hope not, for all the line 6 stuff that I've used - this is the first time I've run into a problem; so havent had a chance to **** anyone off yet.  At this time, I'm using the line 6 gearbox gold as the interface - and have never had any problems with the guitar
      • s0c9 Iknowathingortwo 319 posts since
        Feb 9, 2007
        Mar 21, 2009 7:02 AM (in response to Sandman1832)
        I'm surprised you haven't been given the stock support answer to most issues presented here ... !!
        "Time to take it to a Line6 Service Center"....
        And now I realized that had already been suggested.. so I tried to DELETE my post..
        NOT !!!  yet another thing I'd like back from the old forum ...
        this is reallyy getting old !
  • darin506 Just Startin' 2 posts since
    May 2, 2009
    May 5, 2009 1:50 AM (in response to Sandman1832)
    im having the same problems with my 120,i tried a different power cable and that kinda worked (it doesnt do it as often)..i took a fan and set it to blow behind the amp and keep everything cool and that seems to work,ive played for 6 hours straight with the fan blowing and it never shut off like it normaly does.i know a few people personaly that say the spider 3's are known for getting hot but i dont know...try putting a fan behind it and see what that does
  • Stevotnt Just Startin' 1 posts since
    Sep 16, 2009
    Sep 16, 2009 5:21 PM (in response to Sandman1832)
    I recently bought three line 6 spider amps... and one has started to give the same problem as described here.. the amp keeps powering back on... I need help since I live in trinidad
Incoming Links
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
