Line 6 - Support
4181 Views 5 Replies Latest reply: Nov 21, 2009 12:36 PM by Schoppe84 RSS
plumkzy Just Startin' 2 posts since
Feb 14, 2007
Aug 18, 2009 6:01 PM
FBV short board compatibility
I own a Spider III 150 and I have the fbv short board. Is the older FBV short board compatible with the new Spider IV? I am thinking of upgrading due to the fact that the newer amp has a seperate chorus, which is the only thing I dont like about my Spider III.
Thank you
Joe
  • fester2000 Iknowathingortwo 1,050 posts since
    Oct 30, 2006
    Aug 19, 2009 4:40 AM (in response to plumkzy)
    Re: FBV short board compatibility
    From here: http://line6.com/community/thread/14992?start=15&tstart=0
    Hey guys,
      Just something I wanted to point out - While we cannot comment on future releases, and I can tell you the following holds true for the Spider IV (from the new FAQs):
    Q: I already have an original FBV controller, will this work on the Spider IV 75-150 series?
    A: The FBV (Mk I) controllers will control most of the standard functions on the Spider IV 75-150 series with a few limitations.  Here is a breakdown of the limitations:
    FBV Express
    1) The FBV Express (Mk I) cannot punch in and out overdubs. It just starts record once for a single pass.  The FBV Express Mk II can control the overdub feature.
      2) The FBV Express (Mk I) cannot arm the Quick Loop. The quick loop must be armed by pressing the amp front panel. The FBV Express MkII can arm the Quick Loop by pressing down either the A+B or C+D footswitches. This is what takes you out of Looper mode as well.
    FBV Shortboard
    1) The FBV Shortboard (Mk I) cannot arm the Quick Loop.  The quick loop must be armed by pressing the Quick Loop button on the front panel.  The FBV Shortboard MkII can arm the Quick Loop by pressing the (new) Function 2 button. Overdubbing works on both original and current Shortboards.
    All other functions are available on the FBV Mk I pedals as their Mk II counterparts.  Due to the new effects layout, the FBV Shortboard FX Loop button will activate the Boost setting in the Spider IV 75-150. On the FBV Shortboard Mk II this button is labeled “Function 1”.
    Hope this helps!
    Cheers,
    Fester2k
  • Line6Sach Gear Head 1,352 posts since
    Oct 31, 2008
    Aug 19, 2009 2:58 PM (in response to plumkzy)
    +1...the link to that FAQ: http://www.line6.com/community/docs/DOC-1538.
    Thanks
    Line6Sach
    • sliptallica Just Startin' 3 posts since
      Apr 25, 2007
      Sep 9, 2009 8:10 AM (in response to Line6Sach)
      For clarification, the FBV EXPRESS™ MkII can control the quick loop? I have a Spider IV 75 I just bought and should arrive on Friday and I am trying to figure out which FBV pedal to buy. The main thing I want the FBV pedal for is to start/stop recording of the quick loop and turning on and off distortion (whether by changing channel or turning on and off the effect, I don't know how the Spider works yet).
  • Schoppe84 Just Startin' 4 posts since
    Jul 26, 2009
    Nov 21, 2009 12:36 PM (in response to plumkzy)
    Just like a FYI, you need the Footcontrollers MkII series to update the Spider IV, you cannot do it with the MkI
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
