5621 Views 11 Replies Latest reply: Jan 20, 2010 1:17 PM by RaulRiera RSS
HydroPonick Just Startin' 12 posts since
Aug 30, 2007
Mar 15, 2009 11:52 AM
POD Farm vs. GearBox? What's the difference?
I'm just wondering if the Pod Farm plug-in does anything differently than GearBox that would justify having both.
I have the Pod XT live, all 5 model packs, Riffworks, GearBox Plugin, and a Guitar Port Online subscription.
Needless to say, I'm a line 6 junkie. (2 amps, and pod 2.0 as well).
The stand-alone PodFarm I have (email promotion - it seems I don't qualify for the free upgrade that works as a plug-in) doesn't work with the XT live, so all I can tell is that the interface is awesome, and looks easy.
So, does it do anything the GearBox plug-in doesn't?
At $50 bucks, seems cheap enough to try, but will it be redundant?
As always, Thanks in advance
  • MartinBrunnberg Just Startin' 7 posts since
    Dec 25, 2008
    Mar 15, 2009 1:07 PM (in response to HydroPonick)
    Re: POD Farm vs. GearBox? What's the difference?
    That's an interesting question! Maybe someone from the Line6 sells team could give us some good reasons? :-)
    /martin
  • malhavok Just Startin' 60 posts since
    Jan 27, 2007
    Mar 15, 2009 11:37 PM (in response to HydroPonick)
    If you own the Gearbox plugin then you automatically get the equivalent POD Farm plugin for free. You can have both installed and use both at the same time. I have used Gearbox Plugin and POD Farm Plugin successfully within the same project in REAPER. The sound of each is a bit different, and of course POD Farm allows you to do dual tones without running two instances of the plugin.
    POD patches, tips & tricks, and home recording advice
  • Line6Andy Line 6 4,345 posts since
    Jun 5, 2006
    Mar 17, 2009 10:15 AM (in response to HydroPonick)
    Hello,
      If you purchased the Gearbox plugin you are entitled to a free upgrade.  The POD Farm software will allow you two use two amp simulations at the same time, see the product link for more details.  See the following links for the upgrade information:
    http://line6.com/podfarm/
    How do I activate my POD Farm Upgrade?
    http://line6.com/community/docs/DOC-4784
    POD Farm General Questions
    http://line6.com/community/docs/DOC-4780
    POD Farm Upgrade and Pricing Questions
    http://line6.com/community/docs/DOC-4782
    POD Basic Farm user Guide:
    http://line6.com/data/l/0a060072fbd6490f140ce227e/application/pdf/POD%20Farm%20User%20Guide%20(Rev%20D)%20-%20English.pdf
    POD Farm user Guide:
    POD Farm Installation Guide:
    http://line6.com/data/l/0a060072c7a4494c0070dbae0/application/pdf/POD%20Farm%20Installer%20Guide%20(Rev%20B)%20-%20English.pdf
    Line6Andy
    Please be sure to award Helpful and Correct points to community members who respond with helpful or correct answers!
        Jan 27, 2007
        Mar 17, 2009 1:04 PM (in response to HydroPonick)
        Iv'e tried every possible update, refresh, whatever you want to call 'em scenario's, and can't find the plug-in in Cubase. (GearBox is there)
        So from what I've read the only difference I can make of it, is that the interface is much better
        I wouldn't call the interface better, just prettier. IMO the POD Farm interface is way harder to navigate and tweak new patches than Gearbox.
        POD Farm won't show up in your DAW by default when installed because Line 6 don't install the .dll file to your vstplugins directory. It is installed somewhere by default that can't be read by your DAW. You either have to point your DAW directly at the dll (possibly sacrificing all your other vst plugins in the process) or manually copy/move the dll to your plugin directory.
  • ze371 Just Startin' 11 posts since
    Jul 27, 2007
    Mar 17, 2009 3:05 PM (in response to HydroPonick)
    well, reamping and not having the feeling of playing with a playskool interface.
  • eirikhh Just Startin' 20 posts since
    Feb 25, 2007
    Mar 18, 2009 7:41 AM (in response to HydroPonick)
    well..to answer your question.
    As I see it, the only real difference between Gearbox and PF (except the interface, and the dual amp feature), is PF's MUCH better sound.
    I was hoping gearbox would do it for me when I got it, but found other plugins to be much better. When PF came, I was relieved cos its much more CPU friendly, and sound far better than the Gearbox VST.
    • RaulRiera Just Startin' 1 posts since
      Jan 8, 2010
      Jan 20, 2010 1:17 PM (in response to HydroPonick)
      I'd like to add: Gearbox has a "Hum remover" tool. This tool is missing in Podfarm. But as long as I've never used it, Im not sure how useful it is. My choice is Podfarm just because of the better interface (if I have to stare at something for that much time, may it look nice at least). Nice thread, hope the Line 6 people give some use to this info.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
