2467 Views 3 Replies Latest reply: May 27, 2010 7:36 AM by PA_Woody RSS
donross Just Startin' 1 posts since
Sep 2, 2009
Sep 2, 2009 5:34 PM
6 black boxes on spider iii 75
i just finished building and setting up a guitar and i wanted to test it, but when i turned the amp on the black boxes of death appeared.
i have had this problem before, but turning the amp off for a few minutes rectified it. Now it won't work at all. I tried the factory reset, but it didn't reset.
if at all possible i would like to fix it myself, because im a do it myself no matter how complicated or difficult it is guy, and i'm cheap.
  • laplayantonio Guru 2,435 posts since
    Sep 26, 2006
    Sep 3, 2009 3:15 AM (in response to donross)
    Re: 6 black boxes on spider iii 75
    I'm afraid there's only one answer for this...: http://line6.com/support/serviceCenters/
    if it's still under warranty, then contact your L6 dealer instead
    cheers!!!
  • Bluestone Iknowathingortwo 1,194 posts since
    Feb 11, 2007
    Sep 3, 2009 9:17 AM (in response to donross)
    HI
    Bypass the dealer and call Line 6 directly....they'll get you fixed up a lot faster....
    It's a drag..I know...but the good news is that L6 will cover you no matter how long you've owned the amp...the black boxes are fatal..and L6 will help you...call them....  818-575-3600
    OM
    • PA_Woody Just Startin' 1 posts since
      May 23, 2010
      May 27, 2010 7:36 AM (in response to Bluestone)
      Bluestone, I have recently experienced the same problem and, unfortunately, that's not correct. I called that number and, IME, if your warranty is expired, Line 6 will direct you to a service center and tell you "good luck". You will have to pay for the parts and labor. The main board will run you about $90-$100 US. Labor varies from shop to shop but it will probably run you at least $75 for the shop labor. You could easily pay more for the repair than the amp is worth. My 2 1/2 year old Spider III 75 which is in mint condition except for the black box problem, is going on the scrap heap. I'll probably strip it for any useable parts (speaker, handle, corner protectors, knobs, grill clothe, etc) and trash the rest. This has been my first experience with Line 6 products and it's been rather disappointing. I've had much cheaper amps that have lasted much longer (and are still working). Live and learn.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
