Line 6 - Support
2771 Views 6 Replies Latest reply: Oct 7, 2009 5:38 PM by PapaRomeo RSS
PapaRomeo Just Startin' 4 posts since
Feb 20, 2007
Oct 5, 2009 9:00 AM
Lowdown 300pro Overheat?
Is it possible for the 300 to overheat? Here's why I ask...
This weekend, I played at a neighborhood "Rocktoberfest" -- there were several other bands on the bill, with my band "headlining."  It was an outdoor gig, with a complicated stage setup, so to simplify things, I offered to let all the other bassists use my LowDown 300.  The show started around 1pm, with bands playing all day in the sunshine (temps were in the low 70sF).  The 300 performed like a champ all day -- every one of the other bassists remarked on how much they liked my amp (you'll probably sell a half dozen of them this week to the others that played it that day).  I was running the board for most of the day, and the direct-out sounded great through the PA.  The volume was set at around 5-6 all day (the amp was not on continuously -- it did get shut down in between bands), with no problems, including with the band immediately before mine -- I sat in with them and the amp sounded awesome.
But when my band took the stage, around 7pm, I plugged in and got nothing but nastiness -- farting digital-clipping distortion.  It sounded exactly like the noise I get when the battery on my Fender Deluxe Jazz bass dies, so I swapped out the battery for a new one, to no avail.  I tried a passive bass, and a new cable but nothing made a difference.  Tried all four of my presets and "manual mode" but still had the same problem.  I ended up having to use a DI box, and we had to shorten our set because of the time lost.
I brought the amp home, and the next morning, it worked perfectly (of course), with no sign of trouble.  I even left it on all day in my house, but it still sounded sweet.  The only thing I can think of is that some component overheated because of the long day outdoors.
I love my 300pro, and it almost never gets a workout like it did Saturday, but this experience shaken my confidence in the amp.
Any clues?
Thanks in advance for your help
PR
  • Line6Miller Line 6 11,613 posts since
    Mar 28, 2006
    Oct 6, 2009 12:23 PM (in response to PapaRomeo)
    Re: Lowdown 300pro Overheat?
    Hello,
    The amp could possibly overheat if the cooling fan is defective. The fan is supposed to kick on when the amp gets hot. Did you notice if it did or not? You may want to jam on it for a while and make sure the fan is kicking on ok.
    Line6Miller
  • Line6Andy Line 6 4,345 posts since
    Jun 5, 2006
    Oct 7, 2009 4:07 PM (in response to PapaRomeo)
    Hello,
      I just check our LD300, and the fan kicked in right away.  Was the amp exposed to daylight all day or was it under a cover?  Was there wind/dirt/leaves blowing around that could have  impacted the fan operation that would cause an overheat?
    Jun 5, 2006
    Oct 7, 2009 5:02 PM (in response to PapaRomeo)
    Hello,
      I am wondering if your amp may have been "stuck" in the "synth" model.  If input voltage is "low" (such as stage lighting being turned on?), this can cause the Line 6 amplifier amp models to react strangely and/or "lock up".  If you are not getting the same behavior at home, it may have been "venue specific".  You may want to invest in a power conditioner or voltage line regulator to avoid this situation in the future.
      Let us know if you have any other issues with your amplifier.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
