4036 Views 6 Replies Latest reply: May 5, 2012 7:05 AM by Crazypain RSS
DFlynn666 Just Startin' 73 posts since
Apr 19, 2008
Oct 6, 2009 2:59 PM
Spider III and Pod X3 Live - Getting the best out of them together.
Hi everyone, this is a new thread about making the spider II and pod x3 live working together efficiantly
Here, you can share any knowlege or tips on how to do this with the rest of the community.
However to start the thread, I have a question. . . . .
I own both the Spider III HD150 with 4x12 cab, and now the Pod X3 Live. I want to use the x3 live in conjunction with all my custom presets on my spider. Pretty much using the pod as a pedal board for live purposes.
right now, I am running the pod through the instrument input jack on the amp so the amp can be used. on the pod, all modeling is turned off (being the amp and cab models) to allow the amp to do the modelling. The only modelling the pod is doing is the stompboxes, effects and wah, which are only turned on by tapping the footswitches, like a normal pedalboard.
Only problem is, when the pod is used, the spider has become very trebley, and high end. I have tryed to solve this with EQ's, output changes on the pod and other things which i cannot remember right now. If anyone has this problem and solved it, or if Line 6 knows the exact way to solve this, then if you can tell me how to solve this as I am very enthusiactic about making the 2 products work in unison with each other.
exact settings for the pod to fix this problem would be much appreciated, however, if one person can only point in the right direction, this would be awesome as well.
Dont forget, any other ways to set up the pair to work together is also appreciated for the tread.
  • Line6Andy Line 6 4,345 posts since
    Jun 5, 2006
    Hello,
      You may want to try different "output" settings.  Start with Stack front" and try the EQ option on the POD X3 to see if you can get a sound that works for you.  Se chapter 6 in the manual for more information.
  • Crazypain Just Startin' 4 posts since
    Aug 8, 2011
    There is a trick to spider to get an clear amp
    Hold tap button and turn the power on
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
