Like (0)
Currently Being ModeratedOct 7, 2009 1:52 PM (in response to Mark21)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
Someone from line 6 will see this and open up a support ticket for you. Give them a little time and they will get to you. They work pacific coast hours.
- Report Abuse
Like (0)
Currently Being ModeratedOct 7, 2009 2:51 PM (in response to Mark21)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
Mark21 wrote:
...Ive registered the serial (and i dont know how i did) but when i go to delete my reg. it says :
error: 528: There's a service attached to this device
That means the previous owner had somethihng like GuitarPort (a subscription service) registered with the device. He will have to transfer his registration to another device (or cancel it) before you can remove your registration. Line 6 tech support can help you with that, but why do you want to remove the registration if it's already (somehow) successfully registered to you? If you're lucky and the previous owner no longer has any Line 6 defvices maybe you can persuade Line 6 to allow the remainder of his subscription time to remain on your account.
ive tried to connect my pod by using an new usb cable (1,5m) to my mac (intel 2.4ghz leopard 2.0usb)
The POD X3 series is not yet supported on the leopard OS. See one of the Announcements on the X3 Discussions home page
....and on my Windows Vista but nothing seems to work...
Now this is a problem. Vista should work for you. Make sure your PC has USB 2.0 ports, and that you're not using a USB hub - even an internal hub. Try differnet USB ports, preferably one in the back of the PC rather than the front panel. Use Line 6 Monket to update all X3 software, and let us know if that works. If it fails please provide exact details on where the process is breaking down.
- Report Abuse
Like (0)
Currently Being ModeratedOct 7, 2009 3:13 PM (in response to silverhead)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
I read that topic...but Leopard is supported but NOT Snow Leopard that's different!
On vista, im trying even right now to install the drivesr with monkey.
It downs the drivers...so i click ok,agree,next, then i reach a windows saying "plug in the usb device" and vista will get on screen another window that ill have to click on "trust always line 6 programs" and "install" but no windows appears... only an error that says "driver not found - error PV-M2TV321U" ... then i click ok and the line 6 install program says "you have been succefully installed drivers" but it dosnt...
When i re-open monkey no drivers was installed and i have to do that again...
Im using a macbook (vista is on bootcamp)...
- Report Abuse
Like (0)
Currently Being ModeratedOct 7, 2009 3:23 PM (in response to Mark21)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
Sorry - my bad about Leopard vs. Snow Leopard. As you can tell I'm not a mac user - so I'll drop out and hopefully others can help more.
- Report Abuse
Like (0)
Currently Being ModeratedOct 7, 2009 3:30 PM (in response to silverhead)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
thnks anyway silverhead!!!
- Report Abuse
Like (0)
Currently Being ModeratedOct 7, 2009 4:40 PM (in response to Mark21)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
Some of the USB ports on a macbook are on an internal hub.Try changing USB ports. Some of them are actually on an internal hub. Only one usb port offers a full powered, full speed bus. I think is is the front one is the one you should use. I do know the one in the back in on the same internal hub as the keyboard, trackpad, bluetooth, and camera.
- Report Abuse
Like (0)
Currently Being ModeratedOct 7, 2009 5:31 PM (in response to Jay_A)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
tried... nothing
now here its 2.29am so... 2morrow im gonna install on 2 different pcs..- Report Abuse
Like (0)
Currently Being ModeratedOct 7, 2009 5:43 PM (in response to Mark21)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
On your vista box, you might want to try uninstalling any line 6 software including monkey and start over. You might have a corrupt dirver.
- Report Abuse
Like (0)
Currently Being ModeratedOct 8, 2009 4:00 AM (in response to Jay_A)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
:/ nothing...
- Report Abuse
Like (0)
Currently Being ModeratedOct 8, 2009 7:15 AM (in response to Mark21)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
Go into device manager in vista:
Open Device Manager by clicking the Start button, clicking Control Panel, clicking System and Maintenance, and then clicking Device Manager.
Look for any "unknown devices" (try this with the x3 plugged in)
right click on unknown device or PV-M2TV321U and click Properties
Click on the Drivers tab at the top
Click Uninstall Driver
Try reinstalling monkey and then the drivers.
- Report Abuse
Like (0)
Currently Being ModeratedOct 8, 2009 10:24 AM (in response to Jay_A)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
Hi , today i tried installing on another portable ... but 0 . (portable was a toshiba with windows xp ice but in Virtual Machine mode).
So i decided to get an Usb 2.0 PCI device for my tower pc (windows xp) and trying on it.
It cant install the drivers at all.... when i plug the usb on my pc, it told me that a new devices is found... then it cant complete the driver installation.
So i go to user panel and tried to install manually --- find new device hardware --- expert mode i re-direct my pc on C:program/line6/tools/dirver archive/pod x3... but nothing, it tells me "no software founded" :/
Now i dont understand if its a software or harware problem... pls help me.
ps. i wish some moderators can read this post and get a ticket for 2 issues.
- Report Abuse
Like (0)
Currently Being ModeratedOct 8, 2009 11:26 AM (in response to Mark21)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
You are going to have problems installing drivers for USB devices a lot of the time in a virtual environment. It depends on a lot of issues that I am not going to get into here.
You are having a driver issue. Try downloading the drivers directly from http://www.line6.com/software/readeula.html?rid=2717 and see what happens.
- Report Abuse
Like (0)
Currently Being ModeratedOct 8, 2009 11:34 AM (in response to Jay_A)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
yes i know.. that why today i tried on my tower pc with windows xp.
I have already done that... but its not working.. i have installed even the previous driver (first one) for pod x3/live.
Im going to format my hard disk...
- Report Abuse
Like (0)
Currently Being ModeratedOct 9, 2009 4:15 PM (in response to Mark21)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
Hello,
1) You are in an evaluation state for guitarport.com, which is why it is giving you that message. If you want to cancel your subscription, you can do so by going to "my account", then "guitarport online".
2) Yes, you are having driver issues. Once you have reformatted your computer, Please go the following link to download/install the latest Gearbox software for your Operating System, which also includes the Line 6 monkey intelligent updater and the latest drivers for your Line 6 product.
Copy/paste the following links (beginning with http) into your internet browser for additional Line 6 software information (as you have multiple OSs I will give you a lot of links):
Line 6 Monkey Installation and F.A.Q.
http://line6.com/community/docs/DOC-3898
Installing Drivers For Your Line 6 Device
http://line6.com/community/docs/DOC-4427
Video Tutorial: Installing Line 6 Drivers & Monkey to a Windows XP System
http://line6.com/community/docs/DOC-1464
Video Tutorial: Installing Line 6 Drivers & Monkey to a Windows Vista System
http://line6.com/community/docs/DOC-1564#cf
Use the information in this link to optimize your computer to work with Line 6 Gear:
Computer System Audio Optimization
http://line6.com/community/docs/DOC-4201
Vista Tweaks and Optimizations: Video
http://line6.com/community/docs/DOC-1490
See your manual for more application information:
Gearbox Program manual
http://line6.com/community/docs/DOC-4839
See the following information for setting up your Line 6 device as the soundcard on your computer:
Setting up your Line 6 device as External Sound Card within Windows XP: Video Tutorial
http://line6.com/community/docs/DOC-1427
Assigning your Line 6 Device as a Sound Card on your Windows XP Computer: Screen Shot Tutorial
http://line6.com/community/docs/DOC-1452
Setting up your Line 6 device as the External Sound Card on Windows Vista: Video Tutorial
http://line6.com/community/docs/DOC-1486
Assigning your Line 6 Device as a Sound Card on your Windows Vista Computer: Screen Shot Tutorial
http://line6.com/community/docs/DOC-1453
Setting up Line 6 device as External Sound Card on a Mac Computer: Video Tutorial
http://line6.com/community/docs/DOC-1487
Assigning your Line 6 Device as a Sound Card on your Mac Computer
http://line6.com/community/docs/DOC-1454
Please be sure to award Helpful and/or Correct points to community members who respond with helpful or correct answers!
- Report Abuse
Like (0)
Currently Being ModeratedOct 12, 2009 3:44 PM (in response to Mark21)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
With this pod x3 im done. I ve done almost everything to get the things work but i failed.
I gonna sold it and get an pod xt... itll probably work better with my old-hardware... sorry!
- Report Abuse
Like (0)
Currently Being ModeratedOct 13, 2009 9:49 AM (in response to Mark21)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
I have a question for you. On the XP machine, when you tried to install the POD drivers, what did your Device Manager look like?
Did you see any kind of yellow question marks or exclamation points anywhere in your device manager?
Did the device manager window sort of blink when you plugged the pod in? I really think we are just missing something obvious here.
Line6Miller
- Report Abuse
Like (0)
Currently Being ModeratedOct 13, 2009 10:52 AM (in response to Line6Miller)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
Here it is the desktop screen when i plug usb cable into my pc.
- Report Abuse
Like (0)
Currently Being ModeratedOct 13, 2009 10:56 AM (in response to Mark21)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
OK. That's a good sign! That means Windows at least acknowledges that you have a device plugged into it.
Have you looked at the following Video Tutorial? Can you watch it and let me know at which point exactly you run into problems?
Line6Miller
- Report Abuse
Like (0)
Currently Being ModeratedOct 13, 2009 11:38 AM (in response to Line6Miller)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
its at 4:10.
I click on "search auto drivers into the pc" then it says no software for that hardware found. Impossible to install the application. (or something like that)
Then i try to install it manual, selecting C:/prog/line6/archive drivers/podx3 and i got same.
However tomorrow ill get xt live... with 1.1usb ... cross fingers...- Report Abuse
Like (0)
Currently Being ModeratedOct 13, 2009 12:13 PM (in response to Mark21)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
OK. Instead of clicking on Install Software Automatically, can you select Install from a list or specific Location?
Try that and then choose "Don't search. I will choose the driver to install."
there should be a white box on the next page that should display your hardware drivers. Do you see that?
Also, in your device manager under Universal Serial Bus Controllers, do you see anything that says "Enhanced Host Controller"?
Line6Miller
- Report Abuse
Like (0)
Currently Being ModeratedOct 13, 2009 12:33 PM (in response to Line6Miller)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
I dont have podx3 now , so im going by memories.
I got a list of my hardware in the white box(installed and not), one of that is at the top of the list witch is signed in this way "?(icon)USB Device" .
is that right?
- Report Abuse
Like (0)
Currently Being ModeratedOct 13, 2009 12:56 PM (in response to Mark21)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
- Report Abuse
Like (0)
Currently Being ModeratedOct 13, 2009 1:49 PM (in response to Line6Miller)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
- Report Abuse
Like (0)
Currently Being ModeratedOct 13, 2009 12:53 PM (in response to Mark21)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
That "USB Device" is most likely your POD. Now, can you tell me if your computer has USB 2.0 ports installed on it? That's why I asked if in your Device Manager you see anything that says "Enhanced USB Host Controller". Here, take a look at my screen shot.
Line6Miller
- Report Abuse
Like (0)
Currently Being ModeratedOct 13, 2009 2:53 PM (in response to Mark21)Re: Got problem with my pod x3 registration serial (error 528) and mac usb connection
OK. Well you have USB 2.0 ports so that's not the problem.
If you get a chance, can you plug your POD into your computer and go to your device manager and under Sounds Video and Game Controllers show me what that looks like as well?
Line6Miller
- Report Abuse
Like (0)
Actions
- Retrieving data ...
Legend
- Correct Answers - 5 points
- Helpful Answers - 3 points
About
Follow
Subscribe
