2537 Views 3 Replies Latest reply: Mar 16, 2010 5:42 AM by ajwebber RSS
willthefirst Just Startin' 13 posts since
Oct 3, 2008
Oct 8, 2009 9:44 PM
Effects looping trouble
Hello,
I have just purchased a beautiful new Fender Hot Rod Deluxe tube amp. I want to combine the amps warm sound with the Pod X3 Live's effects.
My wiring setup is:
Guitar --> Amp input --> Preamp out --> FX Return (on Pod X3) --> FX Send (on X3) --> Power amp in --> Out main speaker.
However, for some reason, I can barely hear the guitar sound come out of the amp. It is barely audible, even if I turn the amp up (where I definetly hear a loud buzzing, so the amp is fine). Its getting the guitar tone, just really soft.
Troubleshooting steps I took:
- Amp has full tone, works.
- Guitar --> Pod X3 --> Amp input works fine, but doesn't sound as good (obviously)
- Messed around with "Loop" setting, nothing happened.
HELP I HAVE A GIG on SATURDAY AND NEED THIS TO WORK!!
Will
  • Crusty_Old_Rocker Expert Line 6 User 3,096 posts since
    Jan 24, 2007
    Oct 9, 2009 2:19 AM (in response to willthefirst)
    Re: Effects looping trouble
    The best way to wire up your system is to have your stomp effects and wah before the Fender preamp and delay, modulation and reverb effects after.
    To achieve this, use the 4 cable method.
    Guitar -> POD guitar in -> POD loop send -> Amp guitar input -> Amp preamp out -> POD loop return - POD output -> Amp power amp input
    Give that a go.  Now your distortion and wah will be in front of the Fender's tone stack and the modulation, delay and reverb will be after.
    Cheers,
    Crusty
      • ajwebber Just Startin' 10 posts since
        Oct 30, 2007
        Mar 16, 2010 5:42 AM (in response to willthefirst)
        Hi there,
        Came across your post when asking a question about how to split effects between post and pre-amp stages of a valve amp myself!
        I think I know why your problem might be arising, it could be down to an impedance mismatch, (see my post at http://line6.com/community/message/129125). Hopefully we'll both get some answers from the gurus out there.
        PS - Sorry my post wasn't in time for your gig - hope it went well nonetheless!
        best/AL
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
